[其他ST产品] STM32f105写U盘
2069|67
 楼主| yellow555 发表于 2023-10-28 21:11 | 显示全部楼层
/****************** C Compilers dependant keywords ****************************/
/* In HS mode and when the DMA is used, all variables and data structures dealing
   with the DMA during the transaction process should be 4-bytes aligned */
#ifdef USB_OTG_HS_INTERNAL_DMA_ENABLED
  #if defined   (__GNUC__)        /* GNU Compiler */
    #define __ALIGN_END    __attribute__ ((aligned (4)))
    #define __ALIGN_BEGIN
  #else
    #define __ALIGN_END
    #if defined   (__CC_ARM)      /* ARM Compiler */
      #define __ALIGN_BEGIN    __align(4)
    #elif defined (__ICCARM__)    /* IAR Compiler */
    #elif defined  (__TASKING__)  /* TASKING Compiler */
    #endif /* __CC_ARM */
  #endif /* __GNUC__ */
#else
  #define __ALIGN_END
#endif /* USB_OTG_HS_INTERNAL_DMA_ENABLED */
/* __packed keyword used to decrease the data type alignment to 1-byte */
  #define __packed    __packed
#elif defined   ( __GNUC__ )   /* GNU Compiler */
  #define __packed    __attribute__ ((__packed__))
  #define __packed    __unaligned
 楼主| yellow555 发表于 2023-10-28 21:12 | 显示全部楼层
/** @defgroup USB_CONF_Exported_Types
/** @defgroup USB_CONF_Exported_Macros
/** @defgroup USB_CONF_Exported_Variables
/** @defgroup USB_CONF_Exported_FunctionsPrototype
#endif //__USB_CONF__H__
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
修改dikio.c
/* Low level disk I/O module skeleton for FatFs     (C)ChaN, 2016        */
/* If a working storage control module is available, it should be        */
/* attached to the FatFs via a glue function rather than modifying it.   */
/* This is an example of glue functions to attach various exsisting      */
/* storage control modules to the FatFs module with a defined API.       */
#include "diskio.h"            /* FatFs lower layer API */
//#include "ftl.h"
#include "usbh_usr.h"
//V1.1 20160124
//新增对U盘的支持
//#define SD_CARD     3              //SD卡,卷标为0
//#define EX_FLASH     1            //外部spi flash,卷标为1
//#define EX_NAND      2            //外部nand flash,卷标为2
#define USB_DISK    0            //U盘,卷标为0
//对于W25Q256
//前25M字节给fatfs用,25M字节后,用于存放字库,字库占用6.01M.    剩余部分,给客户自己用
#define FLASH_SECTOR_SIZE     512
#define FLASH_SECTOR_COUNT     1024*25*2    //W25Q256,前25M字节给FATFS占用
#define FLASH_BLOCK_SIZE       8             //每个BLOCK有8个扇区
//获得磁盘状态
DSTATUS disk_status (
    BYTE pdrv        /* Physical drive nmuber to identify the drive */
    return RES_OK;
//初始化磁盘
DSTATUS disk_initialize (
    u8 res=0;
    switch(pdrv)
        case USB_DISK:        //U盘
              res=!USBH_UDISK_Status();//U盘连接成功,则返回1.否则返回0
            break;
        default:
            res=1;
    if(res)return  STA_NOINIT;
    else return 0; //初始化成功
//读扇区
//pdrv:磁盘编号0~9
//*buff:数据接收缓冲首地址
//sector:扇区地址
//count:需要读取的扇区数
DRESULT disk_read (
    BYTE pdrv,        /* Physical drive nmuber to identify the drive */
    BYTE *buff,        /* Data buffer to store read data */
    DWORD sector,    /* Sector address in LBA */
    UINT count        /* Number of sectors to read */
    u8 res=0;
    if (!count)return RES_PARERR;//count不能等于0,否则返回参数错误
    switch(pdrv)
          case USB_DISK:    //U盘
            res=USBH_UDISK_Read(buff,sector,count);
            break;
        default:
            res=1;
   //处理返回值,将SPI_SD_driver.c的返回值转成ff.c的返回值
    if(res==0x00)return RES_OK;
    else return RES_ERROR;
//写扇区
//pdrv:磁盘编号0~9
//*buff:发送数据首地址
//sector:扇区地址
//count:需要写入的扇区数
DRESULT disk_write (
    const BYTE *buff,    /* Data to be written */
    UINT count            /* Number of sectors to write */
 楼主| yellow555 发表于 2023-10-28 21:13 | 显示全部楼层
    u8 res=0;
    switch(pdrv)
        case USB_DISK:    //U盘
            res=USBH_UDISK_Write((u8*)buff,sector,count);
            break;
        default:
            res=1;
    if(res == 0x00)return RES_OK;
//其他表参数的获得
//pdrv:磁盘编号0~9
//ctrl:控制代码
//*buff:发送/接收缓冲区指针
DRESULT disk_ioctl (
    BYTE pdrv,        /* Physical drive nmuber (0..) */
    BYTE cmd,        /* Control code */
    void *buff        /* Buffer to send/receive control data */
DRESULT res;
     if(pdrv==USB_DISK)    //U盘
        switch(cmd)
            case CTRL_SYNC:
                res = RES_OK;
                break;
            case GET_SECTOR_SIZE:
                *(WORD*)buff=512;
                res = RES_OK;
                break;
            case GET_BLOCK_SIZE:
                *(WORD*)buff=512;
                res = RES_OK;
                break;
            case GET_SECTOR_COUNT:
                *(DWORD*)buff=USBH_MSC_Param.MSCapacity;
                res = RES_OK;
                break;
            default:
                res = RES_PARERR;
                break;
    }else res=RES_ERROR;//其他的不支持
    return res;
//获得时间
//User defined function to give a current time to fatfs module      */
//31-25: Year(0-127 org.1980), 24-21: Month(1-12), 20-16: Day(1-31) */
//15-11: Hour(0-23), 10-5: Minute(0-59), 4-0: Second(0-29 *2) */
DWORD get_fattime (void)
    return 0;
//动态分配内存
void *ff_memalloc (UINT size)
//    return (void*)mymalloc(SRAMIN,size);
//释放内存
void ff_memfree (void* mf)
//    myfree(SRAMIN,mf);
最后我的ffconf配置
/  FatFs - FAT file system module configuration file  R0.12  (C)ChaN, 2016
#define _FFCONF 88100    /* Revision ID */
/ Function Configurations
#define _FS_READONLY    0
/* This option switches read-only configuration. (0:Read/Write or 1:Read-only)
/  Read-only configuration removes writing API functions, f_write(), f_sync(),
/  f_unlink(), f_mkdir(), f_chmod(), f_rename(), f_truncate(), f_getfree()
/  and optional writing functions as well. */
#define _FS_MINIMIZE    0
/* This option defines minimization level to remove some basic API functions.
/   0: All basic functions are enabled.
/   1: f_stat(), f_getfree(), f_unlink(), f_mkdir(), f_truncate() and f_rename()
/      are removed.
/   2: f_opendir(), f_readdir() and f_closedir() are removed in addition to 1.
/   3: f_lseek() function is removed in addition to 2. */
#define    _USE_STRFUNC    1
/* This option switches string functions, f_gets(), f_putc(), f_puts() and
/  f_printf().
/  0: Disable string functions.
/  1: Enable without LF-CRLF conversion.
/  2: Enable with LF-CRLF conversion. */
#define _USE_FIND        0
/* This option switches filtered directory read functions, f_findfirst() and
/  f_findnext(). (0:Disable, 1:Enable 2:Enable with matching altname[] too) */
#define    _USE_MKFS        1
/* This option switches f_mkfs() function. (0:Disable or 1:Enable) */
#define    _USE_FASTSEEK    1
/* This option switches fast seek function. (0:Disable or 1:Enable) */
#define    _USE_EXPAND        0
/* This option switches f_expand function. (0:Disable or 1:Enable) */
#define _USE_CHMOD        0
/* This option switches attribute manipulation functions, f_chmod() and f_utime().
/  (0:Disable or 1:Enable) Also _FS_READONLY needs to be 0 to enable this option. */
#define _USE_LABEL        1
/* This option switches volume label functions, f_getlabel() and f_setlabel().
/  (0:Disable or 1:Enable) */
#define    _USE_FORWARD    0
/* This option switches f_forward() function. (0:Disable or 1:Enable)
/  To enable it, also _FS_TINY need to be 1. */
/ Locale and Namespace Configurations
#define _CODE_PAGE    437
/* This option specifies the OEM code page to be used on the target system.
/  Incorrect setting of the code page can cause a file open failure.
/   1   - ASCII (No extended character. Non-LFN cfg. only)
/   437 - U.S.
/   720 - Arabic
/   737 - Greek
/   771 - KBL
/   775 - Baltic
/   850 - Latin 1
/   852 - Latin 2
/   855 - Cyrillic
/   857 - Turkish
/   860 - Portuguese
/   861 - Icelandic
/   862 - Hebrew
/   863 - Canadian French
/   864 - Arabic
/   865 - Nordic
/   866 - Russian
/   869 - Greek 2
/   932 - Japanese (DBCS)
/   936 - Simplified Chinese (DBCS)
/   949 - Korean (DBCS)
/   950 - Traditional Chinese (DBCS)
 楼主| yellow555 发表于 2023-10-28 21:14 | 显示全部楼层
#define    _USE_LFN    1
#define    _MAX_LFN    255
/* The _USE_LFN switches the support of long file name (LFN).
/   0: Disable support of LFN. _MAX_LFN has no effect.
/   1: Enable LFN with static working buffer on the BSS. Always NOT thread-safe.
/   2: Enable LFN with dynamic working buffer on the STACK.
/   3: Enable LFN with dynamic working buffer on the HEAP.
/  To enable the LFN, Unicode handling functions (option/unicode.c) must be added
/  to the project. The working buffer occupies (_MAX_LFN + 1) * 2 bytes and
/  additional 608 bytes at exFAT enabled. _MAX_LFN can be in range from 12 to 255.
/  It should be set 255 to support full featured LFN operations.
/  When use stack for the working buffer, take care on stack overflow. When use heap
/  memory for the working buffer, memory management functions, ff_memalloc() and
/  ff_memfree(), must be added to the project. */
#define    _LFN_UNICODE    0
/* This option switches character encoding on the API. (0:ANSI/OEM or 1:Unicode)
/  To use Unicode string for the path name, enable LFN and set _LFN_UNICODE = 1.
/  This option also affects behavior of string I/O functions. */
#define _STRF_ENCODE    0
/* When _LFN_UNICODE == 1, this option selects the character encoding on the file to
/  be read/written via string I/O functions, f_gets(), f_putc(), f_puts and f_printf().
/  0: ANSI/OEM
/  1: UTF-16LE
/  2: UTF-16BE
/  3: UTF-8
/  This option has no effect when _LFN_UNICODE == 0. */
#define _FS_RPATH    0
/* This option configures support of relative path.
/   0: Disable relative path and remove related functions.
/   1: Enable relative path. f_chdir() and f_chdrive() are available.
/   2: f_getcwd() function is available in addition to 1.
/ Drive/Volume Configurations
#define _VOLUMES    4//支持4个磁盘
/* Number of volumes (logical drives) to be used. */
#define _STR_VOLUME_ID    0
#define _VOLUME_STRS    "RAM","NAND","CF","SD1","SD2","USB1","USB2","USB3"
/* _STR_VOLUME_ID switches string support of volume ID.
/  When _STR_VOLUME_ID is set to 1, also pre-defined strings can be used as drive
/  number in the path name. _VOLUME_STRS defines the drive ID strings for each
/  logical drives. Number of items must be equal to _VOLUMES. Valid characters for
/  the drive ID strings are: A-Z and 0-9. */
#define    _MULTI_PARTITION    0
/* This option switches support of multi-partition on a physical drive.
/  By default (0), each logical drive number is bound to the same physical drive
/  number and only an FAT volume found on the physical drive will be mounted.
/  When multi-partition is enabled (1), each logical drive number can be bound to
/  arbitrary physical drive and partition listed in the VolToPart[]. Also f_fdisk()
/  funciton will be available. */
#define    _MIN_SS        512
#define    _MAX_SS        512
/* These options configure the range of sector size to be supported. (512, 1024,
/  2048 or 4096) Always set both 512 for most systems, all type of memory cards and
/  harddisk. But a larger value may be required for on-board flash memory and some
/  type of optical media. When _MAX_SS is larger than _MIN_SS, FatFs is configured
/  to variable sector size and GET_SECTOR_SIZE command must be implemented to the
/  disk_ioctl() function. */
#define    _USE_TRIM    0
/* This option switches support of ATA-TRIM. (0:Disable or 1:Enable)
/  To enable Trim function, also CTRL_TRIM command should be implemented to the
#define _FS_NOFSINFO    0
/* If you need to know correct free space on the FAT32 volume, set bit 0 of this
/  option, and f_getfree() function at first time after volume mount will force
/  a full FAT scan. Bit 1 controls the use of last allocated cluster number.
/  bit0=0: Use free cluster count in the FSINFO if available.
/  bit0=1: Do not trust free cluster count in the FSINFO.
/  bit1=0: Use last allocated cluster number in the FSINFO if available.
/  bit1=1: Do not trust last allocated cluster number in the FSINFO.
/ System Configurations
#define    _FS_TINY    0
/* This option switches tiny buffer configuration. (0:Normal or 1:Tiny)
/  At the tiny configuration, size of the file object (FIL) is reduced _MAX_SS bytes.
/  Instead of private sector buffer eliminated from the file object, common sector
/  buffer in the file system object (FATFS) is used for the file data transfer. */
#define _FS_EXFAT    1
/* This option switches support of exFAT file system in addition to the traditional
/  FAT file system. (0:Disable or 1:Enable) To enable exFAT, also LFN must be enabled.
/  Note that enabling exFAT discards C89 compatibility. */
 楼主| yellow555 发表于 2023-10-28 21:15 | 显示全部楼层
#define _FS_NORTC    0
#define _NORTC_MON    3
#define _NORTC_MDAY    1
#define _NORTC_YEAR    2016
/* The option _FS_NORTC switches timestamp functiton. If the system does not have
/  any RTC function or valid timestamp is not needed, set _FS_NORTC = 1 to disable
/  the timestamp function. All objects modified by FatFs will have a fixed timestamp
/  defined by _NORTC_MON, _NORTC_MDAY and _NORTC_YEAR in local time.
/  To enable timestamp function (_FS_NORTC = 0), get_fattime() function need to be
/  added to the project to get current time form real-time clock. _NORTC_MON,
/  _NORTC_MDAY and _NORTC_YEAR have no effect.
/  These options have no effect at read-only configuration (_FS_READONLY = 1). */
#define    _FS_LOCK    0
/* The option _FS_LOCK switches file lock function to control duplicated file open
/  and illegal operation to open objects. This option must be 0 when _FS_READONLY
/  is 1.
/  0:  Disable file lock function. To avoid volume corruption, application program
/      should avoid illegal open, remove and rename to the open objects.
/  >0: Enable file lock function. The value defines how many files/sub-directories
/      can be opened simultaneously under file lock control. Note that the file
/      lock control is independent of re-entrancy. */
#define _FS_REENTRANT    0
#define _FS_TIMEOUT        1000
#define    _SYNC_t            HANDLE
/* The option _FS_REENTRANT switches the re-entrancy (thread safe) of the FatFs
/  module itself. Note that regardless of this option, file access to different
/  volume is always re-entrant and volume control functions, f_mount(), f_mkfs()
/  and f_fdisk() function, are always not re-entrant. Only file/directory access
/  to the same volume is under control of this function.
/   0: Disable re-entrancy. _FS_TIMEOUT and _SYNC_t have no effect.
/   1: Enable re-entrancy. Also user provided synchronization handlers,
/      ff_req_grant(), ff_rel_grant(), ff_del_syncobj() and ff_cre_syncobj()
/      function, must be added to the project. Samples are available in
/      option/syscall.c.
/  The _FS_TIMEOUT defines timeout period in unit of time tick.
/  The _SYNC_t defines O/S dependent sync object type. e.g. HANDLE, ID, OS_EVENT*,
/  SemaphoreHandle_t and etc.. A header file for O/S definitions needs to be
/  included somewhere in the scope of ff.c. */
/*--- End of configuration options ---*/
注意我没有支持中文,所以创建的名字,目录写的数据是不能写中文的否则会乱码,最后po一下实现的图片
周半梅 发表于 2024-2-9 08:03 | 显示全部楼层
整流器或功率开关管与每个电容端的连线长度和宽度都要一样
Pulitzer 发表于 2024-2-9 09:06 | 显示全部楼层
不要根据不同的参数类型走不同的代码逻辑
