led.c
- #include "led.h"
- #define GPIOD_MODER (*(volatile unsigned long *)0x40020C00)
- #define GPIOD_OTYPER (*(volatile unsigned long *)0x40020C04)
- #define GPIOD_PUPDR (*(volatile unsigned long *)0x40020C0C)
- #define GPIOD_IDR (*(volatile unsigned long *)0x40020C10)
- #define GPIOD_ODR (*(volatile unsigned long *)0x40020C14)
- #define RCC_AHB1ENR (*(volatile unsigned long *)0x40023830)
- //LED状态输出初始化
- void led_set_init(){
- //1、使能GPIOD时钟
- RCC_AHB1ENR |= (0x01<<3);
- //2、后八位置为 01010101 PD0~PD3通用输出
- GPIOD_MODER = (GPIOD_MODER|0x000000ff)&0xffffff55;
- //3、PD0~PD3设为推挽输出
- GPIOD_OTYPER = GPIOD_OTYPER & 0xfffffff0;
- void led_on(unsigned char site){
- led_set_init();
- switch(site){
- case 0:
- GPIOD_ODR &= ~(0x01); //PD0置0
- break;
- case 1:
- GPIOD_ODR &= ~(0x01<<1); //PD1置0
- break;
- case 2:
- GPIOD_ODR &= ~(0x01<<2); //PD2置0
- break;
- case 3:
- GPIOD_ODR &= ~(0x01<<3); //PD3置0
- break;
- default:
- break;
- void led_off(unsigned char site){
- led_set_init();
- switch(site){
- case 0:
- GPIOD_ODR |= (0x01); //PD0置1
- break;
- case 1:
- GPIOD_ODR |= (0x01<<1); //PD1置1
- break;
- case 2:
- GPIOD_ODR |= (0x01<<2); //PD2置1
- break;
- case 3:
- GPIOD_ODR |= (0x01<<3); //PD3置1
- break;
- default:
- break;
- char get_led_status(unsigned char site){
- switch(site){
- case 0:
- return (GPIOD_IDR >> 0) & (0x01);
- case 1:
- return (GPIOD_IDR >> 1) & (0x01);
- case 2:
- return (GPIOD_IDR >> 2) & (0x01);
- case 3:
- return (GPIOD_IDR >> 3) & (0x01);
- default:
- return -1;
- //on_off 0:开灯 1:关灯
- void led_operate(unsigned char site,unsigned char on_off){
- if(on_off == 0){
- led_on(site);
- }else if(on_off == 1){
- led_off(site);
