[活动专区]
【杰发科技AC7840x测评】+ CAN收发测试
3380|0
tlled|  楼主 | 2023-12-26 23:47 | 显示全部楼层 |只看大图 回帖奖励 |倒序浏览 |阅读模式
测试下开发板的CAN收发功能。
一、硬件部分
1.1、CAN收发器电路
1.2、CAN接口
CAN接口连接到PE4和PE5端口
1.3、芯片端口映射
PE4和PE5映射到CAN0
二、程序部分
2.1、can.c
#include "ac7840x.h"
#include "gpio_drv.h"
#include "can_drv.h"
#include "can/can.h"
#include "osif.h"
#include "clock_config.h"
/* ============================================  Define  ============================================ */
#define CAN_SOURCE_CLOCK             (60UL)         /* 时钟源选择60M */
#define CAN_MSG_HANDLE_DIRECT        (1UL)          /* 是否处理消息, 1 是, 0 否 */
#define CAN_TIME_STAMP_ENABLE        (0UL)          /* 使能/失能CAN时间戳, 1 使能, 0 失能 */
/* ===========================================  Typedef  ============================================ */
typedef struct
    uint32_t recvCount;                              /* 接收消息计数 */
    uint32_t sendCount;                              /* 发送消息计数*/
} can_cur_node_t;
/* ==========================================  Variables  =========================================== */
*  波特率和采样点计算公式:
*  tSeg1 = (S_SEG_1 + 2); tSeg2 = (S_SEG_2 + 1).
*  BandRate = (SRC_CLK / (S_PRESC + 1) / ((S_SEG_1 + 2) + (S_SEG_2 + 1))), SRC_CLK 为CAN模块时钟源
*  SamplePoint = (tSeg1 / (tSeg1 + tSeg2)).
#if (CAN_SOURCE_CLOCK == 80UL)  /*时钟源为80M*/
static const can_time_segment_t s_canBitrate[CAN_BITRATE_NUM] =
    {0x1C, 0x09, 0x09, 0x01},  /*   1M, 75% */
    {0x26, 0x09, 0x09, 0x01},  /* 800K, 80% */
    {0x1C, 0x09, 0x09, 0x03},  /* 500K, 75% */
    {0x1C, 0x09, 0x09, 0x07},  /* 250K, 75% */
    {0x1C, 0x09, 0x09, 0x0F},  /* 125K, 75% */
    {0x1C, 0x09, 0x09, 0x13},  /* 100K, 75% */
    {0x1C, 0x09, 0x09, 0x27},  /*  50K, 75% */
#elif (CAN_SOURCE_CLOCK == 60UL) /*时钟源为60M*/
    {0x0D, 0x04, 0x04, 0x02},  /*   1M, 75% */
    {0x12, 0x04, 0x04, 0x02},  /* 800K, 80% */
    {0x1C, 0x09, 0x09, 0x02},  /* 500K, 75% */
    {0x1C, 0x09, 0x09, 0x05},  /* 250K, 75% */
    {0x1C, 0x09, 0x09, 0x0B},  /* 125K, 75% */
    {0x1C, 0x09, 0x09, 0x0E},  /* 100K, 75% */
    {0x1C, 0x09, 0x09, 0x1D},  /*  50K, 75% */
#elif (CAN_SOURCE_CLOCK == 48UL) /* 时钟源为48M*/
    {0x22, 0x0B, 0x0B, 0x00},  /*   1M, 75% */
    {0x16, 0x05, 0x05, 0x01},  /* 800K, 80% */
    {0x22, 0x0B, 0x0B, 0x01},  /* 500K, 75%*/
    {0x22, 0x0B, 0x0B, 0x03},  /* 250K, 75% */
    {0x22, 0x0B, 0x0B, 0x07},  /* 125K, 75% */
    {0x22, 0x0B, 0x0B, 0x09},  /* 100K, 75% */
    {0x22, 0x0B, 0x0B, 0x13},  /*  50K, 75% */
#elif (CAN_SOURCE_CLOCK == 24UL) /* 时钟源为24M*/
    {0x10, 0x05, 0x05, 0x00},  /*   1M, 75% */
    {0x16, 0x05, 0x05, 0x00},  /* 800K, 80% */
    {0x10, 0x05, 0x05, 0x01},  /* 500K, 75% */
    {0x10, 0x05, 0x05, 0x03},  /* 250K, 75% */
    {0x10, 0x05, 0x05, 0x07},  /* 125K, 75% */
    {0x10, 0x05, 0x05, 0x09},  /* 100K, 75% */
    {0x10, 0x05, 0x05, 0x13},  /*  50K, 75% */
#elif (CAN_SOURCE_CLOCK == 8UL) /*时钟源为8M*/
    {0x04, 0x01, 0x01, 0x00},  /*   1M,75% */
    {0x06, 0x01, 0x01, 0x00},  /* 800K, 80% */
    {0x0A, 0x03, 0x03, 0x00},  /* 500K,75% */
    {0x0A, 0x03, 0x03, 0x01},  /* 250K,75% */
    {0x0A, 0x03, 0x03, 0x03},  /* 125K,75% */
    {0x0D, 0x04, 0x03, 0x03},  /* 100K,75% */
    {0x0D, 0x04, 0x03, 0x07},  /*  50K,75% */
#endif
static const can_filter_config_t s_canFilterList[16] =  /* 过滤器配置*/
    {0x00000001, 0x00000000, CAN_MSG_ID_BOTH},         /* 只接收ID 0x0000_0001和0x001的数据 */
    {0x00000002, 0x00000000, CAN_MSG_ID_STD},          /* 只接收ID 0x002的标准帧数据 */
    {0x00000013, 0x00000000, CAN_MSG_ID_EXT},          /* 只接收ID 0x0000_0013的扩展帧数据 */
    {0x00000124, 0x00000000, CAN_MSG_ID_BOTH},         /* 只接收ID 0x0000_0124和0x124的数据 */
    {0x00000050, 0x1FFFFF0F, CAN_MSG_ID_BOTH},         /* 可接收ID 0xXXXX_XX5X 或 0xX5X的数据,X为任意值 */
    {0x00000060, 0x1FFFFF0F, CAN_MSG_ID_BOTH},         /* 可接收ID 0xXXXX_XX6X 或 0xX6X的数据,X为任意值 */
    {0x00000007, 0x1FFFFFF0, CAN_MSG_ID_BOTH},         /* 可接收ID 0xXXXX_XXX7 或 0xXX7的数据,X为任意值 */
    {0x00000008, 0x1FFFFFF0, CAN_MSG_ID_BOTH},         /* 可接收ID 0xXXXX_XXX8 或 0xXX8的数据,X为任意值 */
    {0x00000009, 0x1FFFFFF0, CAN_MSG_ID_STD},          /* 可接收ID 0xXX9的标准帧数据,X为任意值 */
    {0x0000000a, 0x1FFFFFF0, CAN_MSG_ID_EXT},          /* 可接收ID 0xXXXX_XXXa的扩展帧数据,X为任意值 */
    {0x00000700, 0x1FFFF0FF, CAN_MSG_ID_BOTH},         /* 可接收ID 0xXXXX_X7XX 或 0x7XX的数据,X为任意值 */
    {0x0000c000, 0x1FFF0FFF, CAN_MSG_ID_EXT},          /* 可接收ID 0xXXXX_CXXX 的扩展帧数据,X为任意值 */
    {0x000d0000, 0x1FF0FFFF, CAN_MSG_ID_EXT},          /* 可接收ID 0xXXXX_DXXX 的扩展帧数据,X为任意值 */
    {0x00e00000, 0x1F0FFFFF, CAN_MSG_ID_EXT},          /* 可接收ID 0xXXEX_XXXX 的扩展帧数据,X为任意值 */
    {0x0f000000, 0x10FFFFFF, CAN_MSG_ID_EXT},          /* 可接收ID 0xXXXX_XXXX 的扩展帧数据,X为任意值 */
    {0x10000000, 0x0FFFFFFF, CAN_MSG_ID_EXT},          /* 可接收ID 0xXXXX_XXXX 的扩展帧数据,X为任意值 */
static can_cur_node_t s_canCurNode[CAN_INSTANCE_MAX] = {0}; /* 接收信息*/
* [url=home.php?mod=space&uid=247401]@brief[/url] GPIO 初始化
* @param[in] instance: CAN 模块通道
* [url=home.php?mod=space&uid=266161]@return[/url] none
void CAN_InitGPIO(uint8_t instance)
    if (0U == instance)
        GPIO_DRV_SetMuxModeSel(PORTE, 4U, PORT_MUX_ALT5);           /* CAN0_RX */
        GPIO_DRV_SetMuxModeSel(PORTE, 5U, PORT_MUX_ALT5);           /* CAN0_TX */
        GPIO_DRV_SetMuxModeSel(PORTE, 10U, PORT_MUX_ALT5);          /* 配置收发器standby功能*/
    else if (1U == instance)
        GPIO_DRV_SetMuxModeSel(PORTC, 6U, PORT_MUX_ALT3);           /* CAN1_RX */
        GPIO_DRV_SetMuxModeSel(PORTC, 7U, PORT_MUX_ALT3);           /* CAN1_TX */
        GPIO_DRV_SetMuxModeSel(PORTE, 6U, PORT_MUX_ALT5);           /* 配置收发器standby功能*/
    else if (2U == instance)
        GPIO_DRV_SetMuxModeSel(PORTC, 16U, PORT_MUX_ALT3);          /* CAN2_RX */
        GPIO_DRV_SetMuxModeSel(PORTC, 17U, PORT_MUX_ALT3);          /* CAN2_TX */
        GPIO_DRV_SetMuxModeSel(PORTC, 15U, PORT_MUX_ALT5);          /* 配置收发器standby功能 */
    else if (3U == instance)
        GPIO_DRV_SetMuxModeSel(PORTC, 12U, PORT_MUX_ALT5);          /* CAN3_RX */
        GPIO_DRV_SetMuxModeSel(PORTC, 13U, PORT_MUX_ALT5);          /* CAN3_TX */
        GPIO_DRV_SetMuxModeSel(PORTC, 11U, PORT_MUX_ALT5);          /* 配置收发器standby功能 */
* @brief CAN_GetNormalBitrate 获取波特率
* @param[in] index: 波特率索引
* @return 波特率配置
static can_time_segment_t CAN_GetNormalBitrate(can_bitrate_t index)
    can_time_segment_t bitrate = {0};
    if (index < CAN_BITRATE_NUM)
        bitrate = s_canBitrate[index];
    return bitrate;
* @brief CAN_HandleMsg 接收数据处理
* @param[in] msgInfo: 接收数据
* @return none
static void CAN_HandleMsg(uint8_t instance, const can_msg_info_t *msgInfo)
    uint8_t i = 0;
    s_canCurNode[instance].recvCount++;             /* 节点信息更新 */
#if CAN_MSG_HANDLE_DIRECT                           /* 处理数据*/
    if (msgInfo->IDE)
        printf("CAN[%d] RecvCount:%06d ID:%08x DLC:%d", instance, s_canCurNode[instance].recvCount, msgInfo->ID, msgInfo->DLC);
    else
        printf("CAN[%d] RecvCount:%06d  ID:%03x DLC:%d", instance, s_canCurNode[instance].recvCount, msgInfo->ID, msgInfo->DLC);
    if ((0 == msgInfo->RTR) && msgInfo->DLC)
        printf("\r\tData: ");
        for (i = 0; (i < msgInfo->DLC) && (i < 8); i++)
            printf(" %02x", msgInfo->DATA[i]);
    printf("\r\n");
#endif
* @brief CAN_EventCallback 中断回调函数, 可通过CAN_IRQHandler了解参数具体含义
* @param[in] event: 中断事件
* @param[in] koer: 错误类型
* @return 0: none
void CAN_EventCallback(uint8_t instance, uint32_t event, uint32_t koer)
    can_msg_info_t recvMsg = {0};
    uint8_t recvData[8] = {0};
    if (event & (uint32_t)CAN_EVENT_BUS_ERROR)         /* 发生错误后,打印错误消息,仅用于调试 */
        printf("CAN[%d]e: EVEN: %x  KOER: %x\r\n", instance, event, koer);
    if (event & (uint32_t)CAN_EVENT_RECEIVE_DONE)      /* 接收数据*/
        while (CAN_DRV_GetRbufStatus(instance))
            recvMsg.DATA = recvData;                   /* 为接收数据索引中的数据域分配空间, 如果未给接收数据索引的数据域分配空间,直操作会触发Haltfault */
            if (!CAN_DRV_Receive(instance, &recvMsg))
                CAN_HandleMsg(instance, &recvMsg);
void init_can(void)
        uint8_t instance = 0U;
        can_user_config_t canCfg = {0};
        can_bitrate_t bitrateIndex = CAN_BITRATE_500K;                 /* 低速波特率设置 */
        can_transmit_buff_t type = CAN_TRANSMIT_SECONDARY;             /* 发送缓存设置 */
        canCfg.filterNum = 0U;                                         /* 过滤器数量 */
        canCfg.canMode = CAN_NORMAL_MODE;                              /* 正常模式 */
        canCfg.interruptEn = true;                                     /* 使能中断*/
        canCfg.tsMode = CAN_TSMODE_FIFO;                               /* 选择FIFO模式*/
        canCfg.tsAmount = CAN_TRANSMIT_SEC_ALL;                        /* TSALL*/
        canCfg.tpss = false;                                           /* 失能PTB单次发送 */
        canCfg.tsss = false;                                           /* 失能STB单次发送 */
        canCfg.rom = CAN_ROM_OVER_WRITE;                               /* 缓冲区溢出后,新数据会覆盖旧数据*/
        canCfg.errorWarningLimit = 0x0BU;                              /* 错误警告限制,当 TECNT|RECTN 超过这个限制,会触发EIF错误中断 */
#if CAN_TIME_STAMP_ENABLE
        canCfg.timeStampEn = true;                                     /* 时间戳使能 */
        canCfg.timeStampClkSrc = CAN_TIME_STAMP_CLK_SRC_EXT;           /* 时间戳时钟源选择 */
        canCfg.timeStampClkDiv = CAN_TIME_STAMP_CLK_DIV_8;             /* 时间戳时钟源分频 */
        canCfg.timeStampPos = CAN_TIME_STAMP_SOF;                      /* 时间区采样位置选择 */
#endif
        canCfg.dmaRecvEn = false;                                      /* 不使用DMA */
        canCfg.memEccEn = false;                                       /* 失能ECC */
        canCfg.wakeupIntEn = false;                                    /* 失能唤醒功能 */
        canCfg.busOffRecDisable = false;                               /* 失能自动总线关闭恢复, busoff产生后, 会遵循ISO 11898-规范 */
        canCfg.interruptMask = CAN_IRQ_ALL_ENABLE_MSK;                 /* 使能所有中断*/
        canCfg.bitrate = CAN_GetNormalBitrate(bitrateIndex);           /* 低速波特率配置*/
        canCfg.filterList = (can_filter_config_t *)s_canFilterList;    /* 过滤器配置*/
        canCfg.callback = (can_callback_t)CAN_EventCallback;
        CAN_InitGPIO(instance);                                        /* CAN模块IO口初始化 */
        CAN_DRV_Init(instance, &canCfg);                                                  /* CAN模块初始化 */
void can_senddat(uint8_t *dat)
    int32_t ret = 1;
    static can_msg_info_t s_sendMsg = {0};
    static uint8_t sendData[8] = {0};
    if (!CAN_DRV_IsTransmitBusy(0, CAN_TRANSMIT_SECONDARY))
        s_sendMsg.ID = 0x220;                        /* CAN ID*/
        s_sendMsg.IDE = 0;                           /* 标准帧*/
        s_sendMsg.RTR = 0;                           /* 非远程帧*/
        s_sendMsg.DLC = 8;                           /* 数据长度*/
        s_sendMsg.DATA = sendData;                   /* 分配空间*/
        s_sendMsg.DATA[0] = dat[0];                    /* 填充数据*/
        s_sendMsg.DATA[1] = dat[1];
        s_sendMsg.DATA[2] = dat[2];
        s_sendMsg.DATA[3] = dat[3];
        s_sendMsg.DATA[4] = dat[4];
        s_sendMsg.DATA[5] = dat[5];
        s_sendMsg.DATA[6] = dat[6];
        s_sendMsg.DATA[7] = dat[7];
        if (STATUS_SUCCESS == CAN_DRV_Send(0, &s_sendMsg, CAN_TRANSMIT_SECONDARY))
            s_canCurNode[0].sendCount++;      /* 节点信息更新 */
            ret = 0;
    return ret;
2.2、main.c
#include "debugout_ac7840x.h"
#include "osif.h"
#include "led/led.h"
#include "key/key.h"
#include "adc/adc.h"
#include "spi/spi.h"
#include "ch376s.h"
uint8_t can_txbuf[8];
void SystemClock_Config(void)
    CKGEN_SYS_Init(g_clockManConfigsArr, CLOCK_MANAGER_CONFIG_CNT,
                   g_clockManCallbacksArr, CLOCK_MANAGER_CALLBACK_CNT);
    CKGEN_DRV_UpdateConfiguration(0, CLOCK_MANAGER_POLICY_AGREEMENT);
int main(void)
        uint8_t i=0;
        SystemClock_Config();
        init_led();
        init_key();
        init_adc();
        InitDebug();
        init_can();
        while (1)
                i++;
                can_txbuf[0]=i;
                can_senddat(can_txbuf);
                led3_on();
                OSIF_TimeDelay(100);
                led3_off();
                //ADC_TriggerTest();
三、运行结果
3.1、CAN接收测试
打开CAN调试卡,收到开发板发送的数据
3.2、CAN接收测试
串口打印CAN接收到的数据
