发新帖我要提问
返回列表
[其他ST产品]
STM32-GPIO输入输出(hal库)
楼主: 原来是wjc
原来是wjc|  楼主 | 2023-12-27 16:24 | 只看该作者 回帖奖励 |倒序浏览
4、代码
(1)GPIO初始化
void MX_GPIO_Init(void)
  GPIO_InitTypeDef GPIO_InitStruct = {0};
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOE_CLK_ENABLE();
  __HAL_RCC_GPIOF_CLK_ENABLE();
  __HAL_RCC_GPIOH_CLK_ENABLE();
  __HAL_RCC_GPIOA_CLK_ENABLE();
  /*Configure GPIO pin Output Level */
  HAL_GPIO_WritePin(Buzzer_GPIO_Port, Buzzer_Pin, GPIO_PIN_SET);
  HAL_GPIO_WritePin(GPIOF, LED1_Pin|LED2_Pin, GPIO_PIN_RESET);
  /*Configure GPIO pins : PEPin PEPin PEPin */
  GPIO_InitStruct.Pin = KeyRight_Pin|KeyDown_Pin|KeyLeft_Pin;
  GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
  GPIO_InitStruct.Pull = GPIO_PULLUP;
  HAL_GPIO_Init(GPIOE, &GPIO_InitStruct);
  /*Configure GPIO pins : PFPin PFPin PFPin */
  GPIO_InitStruct.Pin = Buzzer_Pin|LED1_Pin|LED2_Pin;
  GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  GPIO_InitStruct.Pull = GPIO_NOPULL;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
  HAL_GPIO_Init(GPIOF, &GPIO_InitStruct);
  /*Configure GPIO pin : PtPin */
  GPIO_InitStruct.Pin = KeyUp_Pin;
  GPIO_InitStruct.Pull = GPIO_PULLDOWN;
  HAL_GPIO_Init(KeyUp_GPIO_Port, &GPIO_InitStruct);
2)时钟初始化void SystemClock_Config(void)
  RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  /** Configure the main internal regulator output voltage
  __HAL_RCC_PWR_CLK_ENABLE();
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
  /** Initializes the RCC Oscillators according to the specified parameters
  * in the RCC_OscInitTypeDef structure.
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
  RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
  RCC_OscInitStruct.PLL.PLLM = 8;
  RCC_OscInitStruct.PLL.PLLN = 168;
  RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
  RCC_OscInitStruct.PLL.PLLQ = 4;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  /** Initializes the CPU, AHB and APB buses clocks
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5) != HAL_OK)
    Error_Handler();
(3)按键处理函数
typedef enum{
    Key_NONE = 0,   //没有那件按键被按下
    Key_LEFT,       //KeyLeft
    Key_RIGHT,      //KeyRight
    Key_UP,         //KeyUp
    Key_DOWN        //KeyDown
}KEYS;
KEYS ScanPressedKey(uint32_t timeout)
    KEYS key = Key_NONE;
    uint32_t tickstart = HAL_GetTick();     //当前技术值
    const uint32_t btnDelay = 20;           //按下按键的抖动,延时在采样时间
    GPIO_PinState keyState;                 //引脚输入状态
    while(1)
        keyState = HAL_GPIO_ReadPin(KeyLeft_GPIO_Port,KeyLeft_Pin);
        if(keyState == GPIO_PIN_RESET)
            HAL_Delay(btnDelay);            //延时跳过前抖动期
            keyState = HAL_GPIO_ReadPin(KeyLeft_GPIO_Port,KeyLeft_Pin);     //再采样
                return Key_LEFT;
        keyState = HAL_GPIO_ReadPin(KeyRight_GPIO_Port,KeyRight_Pin);
            keyState = HAL_GPIO_ReadPin(KeyRight_GPIO_Port,KeyRight_Pin);       //再采样
                return Key_RIGHT;
        keyState = HAL_GPIO_ReadPin(KeyDown_GPIO_Port,KeyDown_Pin);
            keyState = HAL_GPIO_ReadPin(KeyDown_GPIO_Port,KeyDown_Pin);     //再采样
                return Key_DOWN;
        keyState = HAL_GPIO_ReadPin(KeyUp_GPIO_Port,KeyUp_Pin);
        if(keyState == GPIO_PIN_SET)
            keyState = HAL_GPIO_ReadPin(KeyUp_GPIO_Port,KeyUp_Pin);     //再采样
                return Key_UP;
        if(timeout != KEY_WAIT_ALWAYS)
            if((HAL_GetTick() == tickstart) > timeout)
                break;
    return key;
中国龙芯CDX| | 2023-12-28 08:53 | 只看该作者
有点分散以及讲述的太多
