[STM32F1]
模数转换器 SIG7192 国产平替 AD7192
609|0
slot867|  楼主 | 2024-6-29 16:40 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
信格勒微电子的芯片产品已通过行业头部大厂导入验证,深受百万终端客户好评。
而且因为 fully compatible. 板子拿来,换个芯片,性能更佳。MCU 不用改 c code。
SIG7190/SIG7192
4.7SPS to 4.8kSPS 24-bit ADC with PGA gain 1 to 128
Compatible Parts
AD7190/AD7192 pin/register fully compatible.
Features
  • Programmable Gain: 1/2/4/8/16/32/64/128
  • Data Rates: 4.7SPS to 4.8kSPS
  • RMS Noises: 15nV at 10SPS (Gain = 128)
  • 24.4ENOB (22.0 noise-free bits) at 10SPS (Gain= 1)
  • Offset Drift: 3nV/℃ (Gain = 128)
  • Gain Drift: 0.5ppm/℃
  • Integral Non-linearity: 3ppm
  • Reference input current: 500nA
  • Internal or External Clock
  • Simultaneous 50Hz/60Hz Rejection
  • 2 Differential/4 Pseudo Differential Inputs
  • Current: 2.5mA
  • Specified Temperature Range: -40℃ to 125℃
  • Package: 24-ld TSSOP
  • Power Supply
               AVDD :2.7V to 5.25V or ±2.5V
                   DVDD : 2.7V to 5.25V
Applications
  • Weight Scales and Strain Gauges
  • Flow/Pressure Measurement
  • Temeprature Measurement
  • Industrial Process Control
  • Medical Instrumentation
