可以参考这篇**
楼主: 发霉的味道
mon51| | 2007-2-6 13:26 | 显示全部楼层 回帖奖励 |倒序浏览
请看下面,你主机发出0X11,就行了。
               CLR     A
                MOV     RCAP2H,A
                MOV     RCAP2L,A
                MOV     TL2,A
                MOV     TH2,A
                MOV     T2MOD,A
                MOV     T2CON,A
L4:             JB      RXD,L4
L6:             JNB     RXD,L6
L7:             SETB    TR2
L8:             JNB     RXD,L10
                JNB     TF2,L8
L10:            JNB     RXD,L10
L12:            JNB     RXD,L14
                JNB     TF2,L12
L14:            JNB     RXD,L14
L15:            CLR     TR2
                JB      TF2,InitSerial
                MOV     R7,TL2
                MOV     R6,TH2
                MOV     A,R6
                CLR     C
                RRC     A
                MOV     R4,A
                MOV     A,R7
                RRC     A
                ADD     A,R7
                MOV     R7,A
                MOV     A,R4
                ADDC    A,R6
                MOV     R6,A
                MOV     A,R7
                ADD     A,#010H
                MOV     R7,A
                CLR     A
                ADDC    A,R6
                MOV     R6,A
                MOV     A,R7
                MOV     R0,#05H
L22:            XCH     A,R6
                CLR     C
                RRC     A
                XCH     A,R6
                RRC     A
                DJNZ    R0,L22
                MOV     R7,A
                CLR     C
                CLR     A
                SUBB    A,R7
                MOV     BRL,A
                CLR     A
                MOV     TL2,A
                MOV     TH2,A
                MOV     T2MOD,A
                MOV     T2CON,A
                ORL     PCON,#080H      ; set SMOD1 to double baudrate
                MOV     BDRCON,#01EH    ; set TBCK/RBCK/BRR/SPD
                MOV     SCON,#01011010B ; Init Serial Interface
