请问eeprom和铁电的驱动有什么区别,除了慢些.
8557|15
alphal|  楼主 | 2008-1-26 18:39 | 显示全部楼层 回帖奖励 |倒序浏览 |阅读模式
alphal|  楼主 | 2008-1-27 18:10 | 显示全部楼层
to:huntington
出现写入的数据读出会不一样,但并没有出现错误.
没有错误是指器件的应答正常.
另外程序读写字节里面需要关中断吗?我发现似乎关不关都一样.
我帖上程序看看...
#define     AT24C256_I2cWRITE         0xA0    // 定义24CXX的器件地址SLA和方向位W
#define     AT24C256_I2cREAD          0xA1    //定义24CXX的器件地址SLA和方向位R
#define      I2CEPR_DELAY                          _nop_();_nop_(); _nop_(); _nop_();     _nop_();     _nop_(); _nop_();
#define      SET_SDAEPR_HIGH                 epr_SDA = 1//    io_T_SDA = 1 /* set SDA to high */
#define      SET_SDAEPR_LOW                    epr_SDA = 0//io_T_SDA = 0 /* set SDA to low */
#define      SET_SCLEPR_HIGH                 epr_SCL = 1//io_T_SCL = 1 /* set SCL to high */
#define      SET_SCLEPR_LOW                    epr_SCL = 0//io_T_SCL = 0 /* set SCL to low */
#define     SET_SDAEPR_TO_INPUT              epr_SDA = 1//io_T_SDA = 1
#define     SET_SDAEPR_TO_OUTPUT
#define     GET_SDAEPR_VALUE                 epr_SDA;//io_T_SDA
static void     _hwi2c_I2cSendStart(void);
static void     _hwi2c_I2cSendStop(void);
static void     _hwi2c_I2cSendNAck(void);
static u1_t     _u1_hwi2c_I2cGetAck(void);
static u1_t     _u1_hwi2c_I2cSendByte(u1_t value);
static void     _hwi2c_I2cSendAck(void);
static u1_t     _u1_hwi2c_I2cGetByte(void);
static u1_t     _u1_hwi2c_I2cGetLastByte(void);
Function name : _hwrtc_I2cSendStart
Purpose :i2c bus write/read start program
Input parameters :none
Output parameters : none
    SET_SDAEPR_HIGH;            //发送起始条件的数据信号
    SET_SCLEPR_HIGH;                                     /* set SDA,SCL to high */
    I2CEPR_DELAY;                    //起始条件建立时间大于4.7us延时
    SET_SDAEPR_LOW;                //发送起始信号                      /* set SDA to low */
    I2CEPR_DELAY;                    //起始条件锁定时间大于4us
    SET_SCLEPR_LOW;                //钳住总线,准备发送或接收数据  /* set SCL to low */
    I2CEPR_DELAY;
Function name : _hwrtc_I2cSendStop
Purpose :i2c bus write/read stop program
    SET_SDAEPR_LOW;                                      /* set SDA to low */
    I2CEPR_DELAY ;
    SET_SCLEPR_HIGH;                                     /* set SCL to high */
    I2CEPR_DELAY ;
    SET_SDAEPR_HIGH;                                     /* set SDA to high */
    I2CEPR_DELAY ;
    SET_SCLEPR_LOW;
Function name : _hwrtc_I2cSendNAck
Purpose :Send NACK Signal
    I2CEPR_DELAY ;
    I2CEPR_DELAY ;
    SET_SCLEPR_LOW;                                      /* set SCL to low */
    I2CEPR_DELAY ;
Function name : _u1_hwrtc_I2cGetAck
Purpose :Get ACK Signal
Output parameters : ACK Signal
    u1_t __temp = TRUE, __i = 0xFF;
//    bool_t __b_ea ;
//    __b_ea = _testbit_(EA) ;
    SET_SDAEPR_HIGH;                                             /* set SDA to high,Release SDA for ACK */
    I2CEPR_DELAY ;
    SET_SCLEPR_HIGH;                                             /* set SCL to high,raise ACK clock */
    while((--__i) && (__temp))
             __temp = GET_SDAEPR_VALUE;
    I2CEPR_DELAY ;
//    EA = __b_ea ;
    if (__temp)                                              /* if success return 0x01,else return 0x00 */
        return FALSE;
    else
        return TRUE;
Function name : _u1_hwrtc_I2cSendByte
Purpose :Send one byte to I2C interface
Input parameters :value-the Byte that will be sent
Output parameters : TRUE or FALSE
    u1_t         __i, __temp;
//    bool_t    __b_ea ;
    for (__i = 0; __i < BITSOFBYTE; __i++)
        __temp = value;
        __temp >>= 7 - __i;
        __temp &= 0x01;
        if (__temp == 0)
            SET_SDAEPR_LOW;
        }                              /* set SDA to low */
        else
            SET_SDAEPR_HIGH;
        }                             /* set SDA to high */
        I2CEPR_DELAY ;
        I2CEPR_DELAY ;
        I2CEPR_DELAY ;
//    EA = __b_ea ;
    return(_u1_hwi2c_I2cGetAck());                         /* if sucess return 0x01,else return 0x00 */
Function name : _hwrtc_I2cSendAck
Purpose :Send ACK Signal
    SET_SDAEPR_LOW;
    I2CEPR_DELAY ;
    SET_SCLEPR_HIGH;
    I2CEPR_DELAY ;
    SET_SCLEPR_LOW;
    I2CEPR_DELAY ;
Function name : _u1_hwrtc_I2cGetByte
Purpose :Get one byte from  I2C interface
Output parameters : the byte from I2C interface
    u1_t         __i, __temp, __temp1;
//    bool_t    __b_ea ;
    __temp = 0;
    SET_SDAEPR_TO_INPUT;
        __temp <<= 1;
        SET_SCLEPR_HIGH;
        I2CEPR_DELAY ;
        __temp1 = GET_SDAEPR_VALUE;
        __temp |= __temp1;
        SET_SCLEPR_LOW;
        I2CEPR_DELAY ;
    SET_SDAEPR_TO_OUTPUT;
    _hwi2c_I2cSendAck();
//    EA = __b_ea ;
    return(__temp);
Function name : _u1_hwrtc_I2cGetLastByte
Purpose :Get the last byte form I2C interface
Output parameters : the last byte from I2C interface
//    bool_t    __b_ea ;
    __temp = 0;
        __temp <<= 1;
        SET_SCLEPR_HIGH;
        I2CEPR_DELAY ;
        __temp |= __temp1;
        SET_SCLEPR_LOW;
        I2CEPR_DELAY ;
//    SET_SDAEPR_TO_OUTPUT;                 edit by whs  no define
    _hwi2c_I2cSendNAck();
//    EA = __b_ea ;
    return(__temp);
函数: u1_hwi2cepr_I2ceprReadBlock
功能: eeprom连续写操作
参数: address:读数据的地址;pdat:读出数据存储地址;size:写入长度
返回: true:成功;false:失败
备注:
创建: whs-07-11-23
修改:
u1_t u1_hwi2cepr_I2ceprReadBlock(u2_t address, u1_t* pdat, u1_t size)
    u1_t         __i;
  u1_t         __status;
    _hwi2c_I2cSendStart();
    __status = _u1_hwi2c_I2cSendByte(AT24C256_I2cWRITE);
  if (__status == TRUE)
    __status = _u1_hwi2c_I2cSendByte((u1_t)(address>>BITSOFBYTE));   /*send the high byte first*/
    __status = _u1_hwi2c_I2cSendByte((u1_t)address);
    __status = _u1_hwi2c_I2cSendByte(AT24C256_I2cREAD);
    for (__i=0; __i<size-1; __i++)
      pdat[__i] = _u1_hwi2c_I2cGetByte();
    pdat[__i] = _u1_hwi2c_I2cGetLastByte();
    _hwi2c_I2cSendStop();
  return (__status);
函数: u1_hwi2cepr_I2ceprWriteBlock
功能: eeprom连续写操作
参数: address:写入地址;pdat:写入的数据;size:写入长度
备注:
创建: whs-07-11-23
修改:
u1_t u1_hwi2cepr_I2ceprWriteBlock(u2_t address, u1_t* pdat, u1_t size)
    u1_t     __i;
  u1_t     __status;
//    bool_t    b_ea ;
//    b_ea = _testbit_(EA) ;
    for (__i=0; __i<size; __i++)
      __status = _u1_hwi2c_I2cSendByte( *(pdat+__i) );
      if (__status == FALSE)
        break;
//  EA = b_ea;
  return (__status);
函数: hwi2cepr_I2ceprInit
功能: 初始化
参数:
返回:
备注:
创建: whs-07-11-23
修改:
void hwi2cepr_I2ceprInit(void)
        u1_t __i ;
        SET_SDAEPR_HIGH ;
        for(__i = 0; __i < 9; __i++)
         SET_SCLEPR_HIGH ;
         I2CEPR_DELAY;
         SET_SCLEPR_LOW ;
         I2CEPR_DELAY;
alphal|  楼主 | 2008-1-27 21:06 | 显示全部楼层
to 楼上
不断地尝试向该器件发出start condition,当它以“0”来应答时,则表明它的上一个写过程已经完成,你可以接着进行下一步的操作了
不是这儿吗?
    I2CEPR_DELAY ;
alphal|  楼主 | 2008-1-27 21:09 | 显示全部楼层
毫秒级是指什么?
是nop的延时时间需要到毫秒级还是等待iic ask的时间毫秒级?
alphal|  楼主 | 2008-1-28 11:48 | 显示全部楼层
是不是每次操作后的时间
每次操作(一次读或者写,不管是写一个字节还是连写多字节,都只是一次操作)后,最坏情况是10ms内都不能就行下一次操作.
是这样吧?
但是我的程序里操作一次后等待的时间是大于10ms的,等了40ms,可是还是有问题.
但相同的程序读写铁电就没有问题,铁电和eeprom是不是只是读写时间上的区别?
alphal|  楼主 | 2008-1-28 13:47 | 显示全部楼层
我是地址依次从0增至100,连续写入50byte数据.芯片是24C256
好像和eepro内部翻页有关????
一次连续读/写操作中,地址不能跨页吗?????
alphal|  楼主 | 2008-1-28 15:00 | 显示全部楼层
好像是跨页的问题
我现在每次操作都是64byte,所以一次操作内就没有跨页,好像就正常了,跑了几千次还没发现问题.
据说是eeprom的写操作不能跨页?
不过现在,这个程序操作铁电反而会出错了,也是读出和写入的不一样,真是晕了....
alphal|  楼主 | 2008-1-28 16:54 | 显示全部楼层
呵呵
呵呵,不好意思,没读datasheet....
谢谢各位大侠的指点..
