求助!新手!stm32f407z的摄像头OV9655实验
4118|6
toniz26|  楼主 | 2013-5-13 11:47 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
用的是微雪的STM32F407z的开发板,摄像头是OV9655,用随板的示例程序测试只显示已初始化成功,LCD上并无成像,是怎么回事啊?摄像头,板子和lcd屏都没问题!
我是新手,解答请详细点,在此拜谢各位大神!
ps:附主程序
#include "stm32f4xx.h"
#include "usart.h"
#include "LCD/LCD.h"
#include "camera/dcmi_OV9655.h"
void LCD_CS_ResetBits(void);
void Delay(__IO uint32_t nTime);
void TimingDelay_Decrement(void);
static __IO uint32_t TimingDelay;
uint32_t        fps=0;
uint32_t        disfps=0;
uint32_t        fpsbuff[5];
int main(void)
        OV9655_IDTypeDef OV9655ID;
        USART_Configuration();
        //USART_NVIC_Config();
        LCD_Initializtion();
        LCD_Clear(Red);
        GUI_Text(50,70,"Camera Init..",White,Red);
        printf("\r\n\r\nWelcome to WaveShare STM32F4 series MCU Board Open407I\r\n");
        printf("OV9655 Init..\r\n");
        if(DCMI_OV9655Config()==0){
                printf("Camera Have Init..\r\n");
                GUI_Text(50,90,"Camera Have Init..",White,Red);
        else {
                printf("OV9655 Init fails!!\r\n");
                GUI_Text(50,90,"OV9655 Init fails!!",White,Red);
        DCMI_OV9655_ReadID(&OV9655ID);
        printf("OV9655 ID:0x%x 0x%x 0x%x 0x%x\r\n",OV9655ID.Manufacturer_ID1, OV9655ID.Manufacturer_ID2, OV9655ID.PID, OV9655ID.Version);
        LCD_WriteReg(0x0011,0x6068);
        LCD_SetCursor(0,0);
        Prepare_Write_RAM();
        /* Start Image capture and Display on the LCD *****************************/
    /* Enable DMA transfer */
    DMA_Cmd(DMA2_Stream1, ENABLE);
    /* Enable DCMI interface */
    DCMI_Cmd(ENABLE);
    /* Start Image capture */
    DCMI_CaptureCmd(ENABLE);
        //DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x8d, 0x10); //color test        on
        //DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x0c, 0x80); //color test        on
        //uint32_t i=0x1fffff;
//        while(i--);
        //DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x8d, 0x00); //color test off
        //DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x0c, 0x00); //color test off
        while (1)
  TimingDelay = nTime;
  while(TimingDelay != 0)
  if (TimingDelay != 0x00)
    TimingDelay--;
        GPIO_InitTypeDef  GPIO_InitStructure;
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD, ENABLE);
        //LCD_CS PD7
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
        GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
        GPIO_Init(GPIOD, &GPIO_InitStructure);
        GPIO_ResetBits(GPIOD , GPIO_Pin_7);                 //CS=0;
#ifdef  USE_FULL_ASSERT
void assert_failed(uint8_t* file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
toniz26|  楼主 | 2013-5-13 13:28 | 只看该作者
急啊急 啊~
IJK| | 2013-5-13 13:57 | 只看该作者
那么LZ可以问问微雪的人。
另外,LZ怎么知道摄像头是好的?
cjhk| | 2013-5-13 20:04 | 只看该作者
图像处理这一块的程序  不是很了解  楼主  帮你顶一个  看看有没有高手能够解决这个问题
wakojosin| | 2013-12-6 20:41 | 只看该作者
请问楼主解决没呢,我也遇到这个问题了  用他们给的程序调不出来
18893784560| | 2017-10-12 09:18 | 只看该作者
请问楼主解决没呢,我也遇到这个问题了  用他们给的程序调不出来,谢谢
18893784560| | 2017-10-12 10:44 | 只看该作者
你跳出来没
