| | 更新时间  |
How to Design with PSoC® 3, PSoC 4, and PSoC 5LP - KBA86521 Updated
Question:Can you give me a comprehensive list of resources that I can use to design applications using PSoC 3, PSoC 4, and PSoC 5 LP?
尚未评级 | 13 年 06 月 06 日 |
PSoC® 1 Application Note Finder - KBA83025 Updated
Question:How do I find application notes for PSoC 1?
(4/5) 1 个用户 | 13 年 06 月 06 日 |
PSoC® 4 SAR ADC Configurable Sample Time - KBA87493 New
Question:What is the PSoC 4 SAR ADC configurable sample time (acquisition time)?
尚未评级 | 13 年 06 月 05 日 |
Device Security of PSoC® 4 - KBA87495 New
Question:Please describe the device security of PSoC 4?
SCB Block in Deep-Sleep Mode in PSoC® 4 - KBA87494 New
Question:Does an SCB block work in deep-sleep mode in PSoC 4?
Active Analog Filter Application Using PSoC® 4 - KBA87492 New
Question:How do you build an active analog filter using PSoC 4's analog resources?
Printf Function Usage for PSoC® 4 in PSoC Creator™ 2.2 SP1 - KBA87093New
Question:How do I use the printf function for PSoC 4 in PSoC Creator 2.2 SP1?
PSoC® 4 Pioneer Kit (CY8CKIT-042) Factory Restore Instructions for Programmer and Debugger Functionality - KBA87474 New
Question:How can I restore the programmer and debugger functionality of the PSoC 5LP device on my PSoC 4 Pioneer Kit?
Time Period Measurement in PSoC® 4 - KBA87496 New
Question:How do you measure time period in PSoC 4?
尚未评级 | 13 年 06 月 04 日 |
Complementary PWM Outputs with Dead Time on PSoC® 4 - KBA87491 New
Question:How do you get complementary PWM outputs with dead time on PSoC 4?
PSoC® Creator™ Debugging Error:"No source available, would you like to open disassembly?"- KBA86862 New
Question:When I run the debugger in PSoC Creator 2.2, I see the error message "No source available, would you like to open disassembly?"How do I avoid this error?
EZ-USB® FX3™ Power Consumption - KBA85505 New
Question:How do I calculate the power consumption of an FX3 device?
Connecting an External Input Pin to ADCINC - KBA83561 Updated
Question:How do I connect an external input pin to the ADCINC User Module in CY7C64xxx part?
Cypress Date Code Rule - KBA87489 New
Question:What is the maximum number of date codes in a lot?
尚未评级 | 13 年 06 月 03 日 |
ADV pin to a static level?Should I toggle it during normal operation?">Connecting the ADV Pin to a Static Level - KBA83097 Updated
Question:Can I connect the ADV pin to a static level?Should I toggle it during normal operation?
尚未评级 | 13 年 05 月 31 日 |
USB 2.0 Certification for FX2LP™ - KBA82981 Updated
Question:Is FX2LP™ USB 2.0 compliant?If yes, where can I find its certification documents?
Multiplexing PSoC® 4 SAR ADC Channels - KBA87497 New
Question:How do you multiplex PSoC 4 SAR ADC channels?
Power Pin Connection of PSoC® 4 - KBA87089 New
Question:How do I connect the power pins VDDD, VCCD, and VDDA of PSoC 4?
In-Bulk-NAK (IBN) Interrupt in FX2LP Updated
What is the usage of In-Bulk-NAK (IBN) Interrupt in FX2LP?
尚未评级 | 13 年 05 月 30 日 |
Apple and Linux OS Support for PSoC® Software and Kits - KBA87545 New
Question:Do the Cypress Software tools and kits support Linux or the Apple Mac operating system?
尚未评级 | 13 年 05 月 29 日 |
Objects That Can Activate CapSense Sensors - KBA82822
Question:What materials other than a human finger can activate a CapSense sensor?
尚未评级 | 13 年 05 月 08 日 |
Extending a CapSense Sensor Above the PCB - KBA82851
Question:Can you extend a CapSense sensor above the PCB using something like a spring or conductive rubber?
尚未评级 | 13 年 05 月 07 日 |
Configuring Unused Buttons - KBA82818
Question:I have a PCB layout that is used for multiple projects, however, a few CapSense buttons are not used in every project.In these projects, the unused buttons are on the PCB but they are not defined on the overlay artwork.What is the right pin configuration for these buttons in PSoC Designer?
Housing CapSense Circuits - KBA82823
Question:Are there any specific design guidelines for housing CapSense circuitry?
How to Avoid the Need for an External EEPROM - KBA83524
Question:Can I use the default VID/PID and default descriptors for the hub to avoid the need for an external EEPROM?
尚未评级 | 13 年 05 月 02 日 |
