TTL与COMS的区别
18232|47
55953797 发表于 2007-8-10 15:17 | 显示全部楼层
学习了
lzclever 发表于 2007-9-4 22:05 | 显示全部楼层
cosimage 发表于 2007-11-6 23:26 | 显示全部楼层
长长见识
长长见识
yuyetufu 发表于 2008-1-31 08:37 | 显示全部楼层
学习学习
daotiansi 发表于 2008-3-31 19:33 | 显示全部楼层
re
TTL和CMOS是两种不同的工艺<br />主要是电平规范不同,带负载能力,转换速率等方面<br />以后都向CMOS发展了&nbsp;但一般情况下还是可以兼容TTL电平的
lessfame 发表于 2008-4-29 19:24 | 显示全部楼层
驱动能力不同
&nbsp;&nbsp;&nbsp;&nbsp;但&nbsp;TTL&nbsp;和&nbsp;CMOS&nbsp;器件由于材料的不同,导致其驱动能力、功耗、上升时间、开关速度等参数迥异,分别适用不同的场合。<br />--------------------------------------------------------------<br />欢迎访问我的网站台:<a href="http://www.smartever.com" target=_blank>www.smartever.com</a>
zhulihuazi 发表于 2008-9-16 22:46 | 显示全部楼层
但有电路代换,很简单的
tjmcu 发表于 2008-10-15 13:24 | 显示全部楼层
英文教材的描述——TTL
&nbsp;TTL,&nbsp;which&nbsp;means&nbsp;transistor&nbsp;transistor&nbsp;logic,&nbsp;is&nbsp;most&nbsp;commonly&nbsp;used&nbsp;for&nbsp;small&nbsp;and&nbsp;medium-scale&nbsp;integration&nbsp;(MSI).&nbsp;There&nbsp;are&nbsp;two&nbsp;basic&nbsp;forms&nbsp;of&nbsp;TIL.&nbsp;The&nbsp;first&nbsp;and&nbsp;original&nbsp;group&nbsp;has&nbsp;a&nbsp;low-power/low-speed&nbsp;version&nbsp;and&nbsp;the&nbsp;standard&nbsp;line.&nbsp;The&nbsp;later&nbsp;designs&nbsp;are&nbsp;Schottky&nbsp;clamped,&nbsp;which&nbsp;come&nbsp;in&nbsp;quite&nbsp;a&nbsp;few&nbsp;versions&nbsp;and&nbsp;are&nbsp;still&nbsp;growing.&nbsp;The&nbsp;Schottky&nbsp;diodes&nbsp;are&nbsp;used&nbsp;to&nbsp;prevent&nbsp;the&nbsp;transistors&nbsp;from&nbsp;going&nbsp;into&nbsp;saturation,&nbsp;with&nbsp;a&nbsp;resulting&nbsp;increase&nbsp;in&nbsp;speed&nbsp;for&nbsp;a&nbsp;given&nbsp;power&nbsp;dissipation.<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;The&nbsp;older&nbsp;families,&nbsp;including&nbsp;the&nbsp;54H/74H&nbsp;are&nbsp;obsolete&nbsp;and&nbsp;used&nbsp;only&nbsp;for&nbsp;replacement.&nbsp;The&nbsp;low-power&nbsp;Schottky,&nbsp;54LS/74L5,&nbsp;and&nbsp;the&nbsp;standard&nbsp;Schottky,&nbsp;54S/74S,&nbsp;have&nbsp;been&nbsp;around&nbsp;for&nbsp;a&nbsp;long&nbsp;time.&nbsp;The&nbsp;newer&nbsp;versions&nbsp;include&nbsp;the&nbsp;family&nbsp;54F/74F&nbsp;called&nbsp;FAST&nbsp;and&nbsp;two&nbsp;Texas&nbsp;Instruments&nbsp;versions,&nbsp;54AS/74AS&nbsp;and&nbsp;54ALS/74ALS.&nbsp;There&nbsp;are&nbsp;designated&nbsp;Advanced&nbsp;Schottky&nbsp;and&nbsp;Advanced&nbsp;Low&nbsp;Power&nbsp;Schottky,&nbsp;respectively.&nbsp;All&nbsp;of&nbsp;the&nbsp;TIL&nbsp;families&nbsp;represent&nbsp;different&nbsp;tradeoffs&nbsp;between&nbsp;power&nbsp;consumption&nbsp;and&nbsp;speed.<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;If&nbsp;speed&nbsp;is&nbsp;not&nbsp;required,&nbsp;the&nbsp;Low&nbsp;Power&nbsp;class&nbsp;is&nbsp;a&nbsp;good&nbsp;choice,&nbsp;not&nbsp;only&nbsp;because&nbsp;of&nbsp;low&nbsp;power&nbsp;consumption,&nbsp;but&nbsp;because&nbsp;its&nbsp;low&nbsp;speed&nbsp;makes&nbsp;it&nbsp;insensitive&nbsp;to&nbsp;many&nbsp;high-frequency&nbsp;spikes&nbsp;and&nbsp;glitches.<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Although&nbsp;open&nbsp;inputs&nbsp;to&nbsp;TTL&nbsp;logic&nbsp;act&nbsp;as&nbsp;a&nbsp;high,&nbsp;it&nbsp;is&nbsp;not&nbsp;a&nbsp;good&nbsp;practice&nbsp;to&nbsp;leave&nbsp;them&nbsp;disconnected&nbsp;in&nbsp;final&nbsp;circuitry.&nbsp;This&nbsp;is&nbsp;because&nbsp;the&nbsp;maximum&nbsp;speed&nbsp;is&nbsp;lowered&nbsp;and&nbsp;the&nbsp;noise&nbsp;susceptibility&nbsp;is&nbsp;increased.&nbsp;It&nbsp;is&nbsp;also&nbsp;not&nbsp;a&nbsp;safe&nbsp;practice&nbsp;to&nbsp;tie&nbsp;these&nbsp;inputs&nbsp;to&nbsp;the&nbsp;5&nbsp;V&nbsp;line&nbsp;because&nbsp;the&nbsp;breakdown&nbsp;voltage&nbsp;of&nbsp;the&nbsp;input&nbsp;lines&nbsp;are&nbsp;only&nbsp;5.5V&nbsp;compared&nbsp;to&nbsp;7&nbsp;V&nbsp;for&nbsp;the&nbsp;supply&nbsp;pin.&nbsp;Unused&nbsp;open&nbsp;inputs&nbsp;can&nbsp;be&nbsp;connected&nbsp;to&nbsp;the&nbsp;output&nbsp;of&nbsp;a&nbsp;spare&nbsp;gate&nbsp;that&nbsp;is&nbsp;held&nbsp;at&nbsp;a&nbsp;high&nbsp;or&nbsp;a&nbsp;1&nbsp;kH&nbsp;resistor&nbsp;can&nbsp;be&nbsp;inserted&nbsp;between&nbsp;the&nbsp;gate&nbsp;lead&nbsp;and&nbsp;the&nbsp;+&nbsp;5&nbsp;V&nbsp;supply.&nbsp;One&nbsp;resistor&nbsp;can&nbsp;be&nbsp;used&nbsp;for&nbsp;up&nbsp;to&nbsp;25&nbsp;gates&nbsp;in&nbsp;some&nbsp;logic&nbsp;families.&nbsp;A&nbsp;better&nbsp;way,&nbsp;however,&nbsp;is&nbsp;to&nbsp;use&nbsp;two&nbsp;resistors&nbsp;and&nbsp;a&nbsp;couple&nbsp;of&nbsp;microfarads&nbsp;of&nbsp;capacitance&nbsp;to&nbsp;form&nbsp;a&nbsp;stable&nbsp;Hi&nbsp;of&nbsp;about&nbsp;3.5&nbsp;V.<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;One&nbsp;exception&nbsp;to&nbsp;this&nbsp;is&nbsp;the&nbsp;LS&nbsp;series&nbsp;where&nbsp;most&nbsp;of&nbsp;the&nbsp;devices&nbsp;have&nbsp;diode&nbsp;inputs,&nbsp;which&nbsp;can&nbsp;be&nbsp;directly&nbsp;connected&nbsp;to&nbsp;the&nbsp;+&nbsp;5&nbsp;V&nbsp;supply.&nbsp;Some&nbsp;of&nbsp;them&nbsp;have&nbsp;emitter&nbsp;inputs,&nbsp;however,&nbsp;which&nbsp;must&nbsp;be&nbsp;connected&nbsp;through&nbsp;the&nbsp;1&nbsp;kH&nbsp;resistor.<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;The&nbsp;families&nbsp;are&nbsp;almost&nbsp;completely&nbsp;pin&nbsp;compatible,&nbsp;but&nbsp;for&nbsp;some&nbsp;strange&nbsp;reason&nbsp;there&nbsp;are&nbsp;a&nbsp;few&nbsp;exceptions.&nbsp;The&nbsp;power&nbsp;pin&nbsp;for&nbsp;dual-in-line&nbsp;sockets&nbsp;is&nbsp;usually&nbsp;#&nbsp;16&nbsp;(or&nbsp;#&nbsp;14)&nbsp;and&nbsp;the&nbsp;ground&nbsp;pin&nbsp;#&nbsp;8&nbsp;(or&nbsp;#&nbsp;7)&nbsp;depending&nbsp;on&nbsp;whether&nbsp;it&nbsp;is&nbsp;a&nbsp;16-pin&nbsp;or&nbsp;14-pin&nbsp;package.&nbsp;But,&nbsp;again,&nbsp;not&nbsp;always.<br />
tjmcu 发表于 2008-10-15 13:26 | 显示全部楼层
英文教材的描述——MOS
&nbsp;Mos&nbsp;logic&nbsp;comes&nbsp;in&nbsp;two&nbsp;forms.&nbsp;The&nbsp;first&nbsp;is&nbsp;called&nbsp;CMOS,&nbsp;where&nbsp;C&nbsp;stands&nbsp;for&nbsp;complementary,&nbsp;which&nbsp;means&nbsp;that&nbsp;both&nbsp;N&nbsp;channel&nbsp;and&nbsp;P&nbsp;channel&nbsp;transistors&nbsp;are&nbsp;used&nbsp;in&nbsp;a&nbsp;complementary&nbsp;fashion.&nbsp;These&nbsp;are&nbsp;mediumspeed&nbsp;devices&nbsp;that&nbsp;can&nbsp;be&nbsp;operated&nbsp;at&nbsp;3&nbsp;to&nbsp;15&nbsp;V.&nbsp;For&nbsp;example,&nbsp;a&nbsp;54C73&nbsp;flip-flop&nbsp;has&nbsp;a&nbsp;typical&nbsp;toggle&nbsp;frequency&nbsp;of&nbsp;4&nbsp;MHz&nbsp;at&nbsp;5&nbsp;V&nbsp;and&nbsp;11&nbsp;MHz&nbsp;at&nbsp;10&nbsp;V.&nbsp;If&nbsp;the&nbsp;speed&nbsp;limitations&nbsp;are&nbsp;acceptable,&nbsp;these&nbsp;devices&nbsp;are,&nbsp;on&nbsp;an&nbsp;all-around&nbsp;basis,&nbsp;clearly&nbsp;superior&nbsp;to&nbsp;the&nbsp;other&nbsp;families&nbsp;of&nbsp;logic.&nbsp;They&nbsp;have&nbsp;the&nbsp;lowest&nbsp;power&nbsp;consumption,&nbsp;high&nbsp;noise&nbsp;immunity&nbsp;(at&nbsp;10&nbsp;V),&nbsp;symmetrical&nbsp;drive&nbsp;capability&nbsp;at&nbsp;a&nbsp;good&nbsp;current&nbsp;level,&nbsp;and&nbsp;a&nbsp;very&nbsp;high&nbsp;input&nbsp;impedance.&nbsp;They&nbsp;are&nbsp;competitive&nbsp;with&nbsp;TTL&nbsp;in&nbsp;cost&nbsp;and&nbsp;are&nbsp;approaching&nbsp;TTL&nbsp;in&nbsp;the&nbsp;availability&nbsp;of&nbsp;logic&nbsp;functions,&nbsp;which&nbsp;are&nbsp;increasing&nbsp;rapidly.&nbsp;As&nbsp;contrasted&nbsp;to&nbsp;the&nbsp;other&nbsp;forms&nbsp;of&nbsp;logic,&nbsp;all&nbsp;inputs&nbsp;must&nbsp;be&nbsp;tied&nbsp;to&nbsp;a&nbsp;high&nbsp;or&nbsp;a&nbsp;low&nbsp;because&nbsp;they&nbsp;are&nbsp;open-gate&nbsp;leads&nbsp;of&nbsp;the&nbsp;MOSFETs&nbsp;and&nbsp;the&nbsp;devices&nbsp;simply&nbsp;do&nbsp;not&nbsp;know&nbsp;where&nbsp;they&nbsp;are&nbsp;if&nbsp;the&nbsp;gate&nbsp;lead&nbsp;is&nbsp;left&nbsp;open.&nbsp;One&nbsp;good&nbsp;feature&nbsp;is&nbsp;that&nbsp;the&nbsp;inputs&nbsp;can&nbsp;be&nbsp;safety&nbsp;connected&nbsp;to&nbsp;Z?&nbsp;+&nbsp;for&nbsp;a&nbsp;high.&nbsp;Particular&nbsp;attention&nbsp;should&nbsp;be&nbsp;given&nbsp;to&nbsp;power&nbsp;consumption,&nbsp;which&nbsp;depends&nbsp;strongly&nbsp;on&nbsp;the&nbsp;operating&nbsp;frequency&nbsp;and&nbsp;load.<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;The&nbsp;second&nbsp;form&nbsp;of&nbsp;MOS&nbsp;logic&nbsp;is&nbsp;not&nbsp;really&nbsp;a&nbsp;family&nbsp;of&nbsp;logic&nbsp;elements&nbsp;but&nbsp;a&nbsp;collection&nbsp;of&nbsp;MSI&nbsp;and&nbsp;LSI&nbsp;(large-scale&nbsp;integration)&nbsp;that&nbsp;takes&nbsp;advantage&nbsp;of&nbsp;the&nbsp;small&nbsp;size&nbsp;and&nbsp;the&nbsp;low-power&nbsp;consumption&nbsp;of&nbsp;the&nbsp;MOS&nbsp;transistor&nbsp;to&nbsp;fabricate&nbsp;very&nbsp;large&nbsp;arrays.&nbsp;Typical&nbsp;of&nbsp;these&nbsp;devices&nbsp;are&nbsp;random-access&nbsp;memories&nbsp;(RAMs&nbsp;),&nbsp;read-only&nbsp;memories&nbsp;(&nbsp;ROMs&nbsp;),&nbsp;and&nbsp;microprocessors.&nbsp;These&nbsp;devices&nbsp;can&nbsp;be&nbsp;made&nbsp;by&nbsp;either&nbsp;N&nbsp;channel&nbsp;or&nbsp;P&nbsp;channel&nbsp;processes.&nbsp;They&nbsp;are&nbsp;generally&nbsp;constructed&nbsp;so&nbsp;that&nbsp;their&nbsp;drive&nbsp;levels&nbsp;are&nbsp;TTL&nbsp;compatible&nbsp;and&nbsp;can&nbsp;be&nbsp;mixed&nbsp;with&nbsp;TTL&nbsp;circuits.&nbsp;Many&nbsp;MSI&nbsp;and&nbsp;LSI&nbsp;devices&nbsp;are&nbsp;available&nbsp;in&nbsp;both&nbsp;MOS&nbsp;and&nbsp;TTL.&nbsp;m&nbsp;these&nbsp;cases&nbsp;the&nbsp;TTL&nbsp;is&nbsp;used&nbsp;only&nbsp;if&nbsp;its&nbsp;superior&nbsp;speed&nbsp;is&nbsp;required.<br />
tjmcu 发表于 2008-10-15 13:34 | 显示全部楼层
英文教材的描述——ECL
The&nbsp;last&nbsp;of&nbsp;the&nbsp;logic&nbsp;families&nbsp;to&nbsp;be&nbsp;discussed&nbsp;is&nbsp;called&nbsp;emitter-coupled&nbsp;logic,&nbsp;or&nbsp;ECL&nbsp;for&nbsp;short.&nbsp;This&nbsp;differs&nbsp;from&nbsp;the&nbsp;other&nbsp;forms&nbsp;of&nbsp;logic&nbsp;in&nbsp;that&nbsp;the&nbsp;transistors&nbsp;are&nbsp;operated&nbsp;in&nbsp;a&nbsp;linear&nbsp;mode&nbsp;and&nbsp;not&nbsp;allowed&nbsp;to&nbsp;go&nbsp;into&nbsp;saturation.&nbsp;ECL&nbsp;is&nbsp;therefore&nbsp;the&nbsp;fastest&nbsp;of&nbsp;all&nbsp;logic&nbsp;forms.&nbsp;It&nbsp;also&nbsp;consumes&nbsp;the&nbsp;most&nbsp;power.&nbsp;ECL&nbsp;devices&nbsp;operate&nbsp;from&nbsp;a&nbsp;-5.2V&nbsp;power&nbsp;supply,&nbsp;a&nbsp;logic&nbsp;low&nbsp;is&nbsp;-1.8V,&nbsp;and&nbsp;a&nbsp;logic&nbsp;high&nbsp;is&nbsp;-&nbsp;0.9&nbsp;V.&nbsp;The&nbsp;output&nbsp;stages&nbsp;are&nbsp;open-ended&nbsp;emitter&nbsp;followers,&nbsp;which&nbsp;are&nbsp;externally&nbsp;terminated&nbsp;with&nbsp;a&nbsp;51&nbsp;resistor&nbsp;to&nbsp;a&nbsp;-2V&nbsp;supply.&nbsp;This&nbsp;clutters&nbsp;up&nbsp;the&nbsp;circuit&nbsp;a&nbsp;bit,&nbsp;and&nbsp;the&nbsp;-&nbsp;2&nbsp;V&nbsp;supply&nbsp;because&nbsp;of&nbsp;its&nbsp;low&nbsp;voltage&nbsp;must&nbsp;have&nbsp;a&nbsp;low&nbsp;efficiency.&nbsp;The&nbsp;basic&nbsp;ECL&nbsp;gate&nbsp;is&nbsp;the&nbsp;OR/NOR&nbsp;as&nbsp;contrasted&nbsp;to&nbsp;the&nbsp;NAND&nbsp;gate&nbsp;for&nbsp;TTL.
xlking 发表于 2008-10-24 11:51 | 显示全部楼层
谢谢
谢谢,
jack_shine 发表于 2010-11-3 17:59 | 显示全部楼层
路过学习
gguoke@126.com 发表于 2010-11-8 00:19 | 显示全部楼层
一直不明白,现在懂了
wjh橙子 发表于 2011-4-23 12:14 | 显示全部楼层
学习了
bingge 发表于 2011-4-26 20:36 | 显示全部楼层
谈谈TTL和CMOS电平(转贴)
TTL——Transistor-Transistor Logic
HTTL——High-speed TTL
LTTL——Low-power TTL
STTL——Schottky TTL
LSTTL——Low-power Schottky TTL
ASTTL——Advanced Schottky TTL
ALSTTL——Advanced Low-power Schottky TTL
FAST(F)——Fairchild Advanced schottky TTL
CMOS——Complementary metal-oxide-semiconductor
HC/HCT——High-speed CMOS Logic(HCT与TTL电平兼容)
AC/ACT——Advanced CMOS Logic(ACT与TTL电平兼容)(亦称ACL)
AHC/AHCT——Advanced High-speed CMOS Logic(AHCT与TTL电平兼容)
FCT——FACT扩展系列,与TTL电平兼容
FACT——Fairchild Advanced CMOS Technology
1,TTL电平:
   输出高电平>2.4V,输出低电平<0.4V。在室温下,一般输出高电平是3.5V,输出低电平
是0.2V。最小输入高电平和低电平:输入高电平>=2.0V,输入低电平<=0.8V,噪声容限是
0.4V。
2,CMOS电平:
   1逻辑电平电压接近于电源电压,0逻辑电平接近于0V。而且具有很宽的噪声容限。
3,电平转换电路:
   因为TTL和COMS的高低电平的值不一样(ttl 5v<==>cmos 3.3v),所以互相连接时需
要电平的转换:就是用两个电阻对电平分压,没有什么高深的东西。哈哈
4,OC门,即集电极开路门电路,OD门,即漏极开路门电路,必须外界上拉电阻和电源才能
将开关电平作为高低电平用。否则它一般只作为开关大电压和大电流负载,所以又叫做驱
动门电路。
5,TTL和COMS电路比较:
1)TTL电路是电流控制器件,而coms电路是电压控制器件。
2)TTL电路的速度快,传输延迟时间短(5-10ns),但是功耗大。
    COMS电路的速度慢,传输延迟时间长(25-50ns),但功耗低。
    COMS电路本身的功耗与输入信号的脉冲频率有关,频率越高,芯片集越热,这是正常
现象。
3)COMS电路的锁定效应:
   COMS电路由于输入太大的电流,内部的电流急剧增大,除非切断电源,电流一直在增大
。这种效应就是锁定效应。当产生锁定效应时,COMS的内部电流能达到40mA以上,很容易
烧毁芯片。
  防御措施:
   1)在输入端和输出端加钳位电路,使输入和输出不超过不超过规定电压。
   2)芯片的电源输入端加去耦电路,防止VDD端出现瞬间的高压。
   3)在VDD和外电源之间加线流电阻,即使有大的电流也不让它进去。
   4)当系统由几个电源分别供电时,开关要按下列顺序:开启时,先开启COMS电路得电
源,再开启输入信号和负载的电源;关闭时,先关闭输入信号和负载的电源,再关闭COMS
电路的电源。
6,COMS电路的使用注意事项
   1)COMS电路时电压控制器件,它的输入总抗很大,对干扰信号的捕捉能力很强。所以
,不用的管脚不要悬空,要接上拉电阻或者下拉电阻,给它一个恒定的电平。
   2)输入端接低内组的信号源时,要在输入端和信号源之间要串联限流电阻,使输入的
电流限制在1mA之内。
   3)当接长信号传输线时,在COMS电路端接匹配电阻。
   4)当输入端接大电容时,应该在输入端和电容间接保护电阻。电阻值为R=V0/1mA.V0是
外界电容上的电压。
   5)COMS的输入电流超过1mA,就有可能烧坏COMS。
7,TTL门电路中输入端负载特性(输入端带电阻特殊情况的处理):
   1)悬空时相当于输入端接高电平。因为这时可以看作是输入端接一个无穷大的电阻。
   2)在门电路输入端串联10K电阻后再输入低电平,输入端出呈现的是高电平而不是低电
平。因为由TTL门电路的输入端负载特性可知,只有在输入端接的串联电阻小于910欧时,
它输入来的低电平信号才能被门电路识别出来,串联电阻再大的话输入端就一直呈现高电
平。这个一定要注意。COMS门电路就不用考虑这些了。
8,TTL电路有集电极开路OC门,MOS管也有和集电极对应的漏极开路的OD门,它的输出就叫
做开漏输出。
   OC门在截止时有漏电流输出,那就是漏电流,为什么有漏电流呢?那是因为当三机管截
止的时候,它的基极电流约等于0,但是并不是真正的为0,经过三极管的集电极的电流也
就不是真正的0,而是约0。而这个就是漏电流。开漏输出:OC门的输出就是开漏输出;OD
门的输出也是开漏输出。它可以吸收很大的电流,但是不能向外输出的电流。所以,为了
能输入和输出电流,它使用的时候要跟电源和上拉电阻一齐用。OD门一般作为输出缓冲/驱
动器、电平转换器以及满足吸收大负载电流的需要。
9,什么叫做图腾柱,它与开漏电路有什么区别?
   TTL集成电路中,输出有接上拉三极管的输出叫做图腾柱输出,没有的叫做OC门。因为
TTL就是一个三级关,图腾柱也就是两个三级管推挽相连。所以推挽就是图腾。一般图腾式
输出,高电平400UA,低电平8MA.
zhao9183 发表于 2011-5-2 13:31 | 显示全部楼层
学习学习
kjbb2004 发表于 2011-5-15 13:11 | 显示全部楼层
学习了
kyy173 发表于 2011-5-15 13:13 | 显示全部楼层
学习了
shenquan 发表于 2011-6-24 10:32 | 显示全部楼层
20楼的大侠,强啊!
wgq19881001 发表于 2011-7-10 23:22 | 显示全部楼层
TTL芯片的驱动能力比较强
CMOS:功耗低,输入电阻大,体积小的
