寻卡和认证都过了,就卡在读写扇区上,一直返回CRC错误,对照了网上多份示例代码,驱动都没有问题,请各位调试过的指导一下,主要是
MIF_Read函数中,这时总是返回if((temp & 0x08) == 0x08) return FM1702_CRCERR;错误,单片机为 STC89LE54RD+
- /*名称: MIF_Read */
- /*功能: 该函数实现读MIFARE卡块的数值*/
- /*输入: buff: 缓冲区首地址*/
- /* Block_Adr: 块地址*/
- /*输出: FM1715_NOTAGERR: 无卡*/
- /* FM1715_PARITYERR: 奇偶校验错*/
- /* FM1715_CRCERR: CRC校验错*/
- /* FM1715_BYTECOUNTERR: 接收字节错误*/
- /* FM1715_OK: 应答正确*/
- uchar MIF_READ(uchar idata *buff, uchar Block_Adr)
- uchar idata temp;
- write_reg(0x23,0x63);
- write_reg(0x12,0x3f);
- write_reg(0x13,0x3f);
- write_reg(0x22,0x0f);
- buff[0] = RF_CMD_READ;
- buff[1] = Block_Adr;
- temp = Command_Send(2, buff, Transceive);
- if(temp == 0)
- return FM1715_NOTAGERR;
- temp = read_reg(0x0A);
- if((temp & 0x02) == 0x02) return FM1715_PARITYERR;
- if((temp & 0x04) == 0x04) return FM1715_FRAMINGERR;
- if((temp & 0x08) == 0x08) return FM1715_CRCERR;
- temp = read_reg(0x04);
- if(temp == 0x10) /* 8K卡读数据长度为16 */
- Read_FIFO(buff);
- return FM1715_OK;
- else if(temp == 0x04) /* Token卡读数据长度为16 */
- Read_FIFO(buff);
- return FM1715_OK;
- else
- return FM1715_BYTECOUNTERR;
- /*名称: MIF_Write */
- /*功能: 该函数实现写MIFARE卡块的数值*/
- /* FM1715_NOTAUTHERR: 未经权威认证*/
- /* FM1715_EMPTY: 数据溢出错误*/
- /* FM1715_WRITEERR: 写卡块数据出错*/
- uchar MIF_Write(uchar idata *buff, uchar Block_Adr)
- uchar idata temp;
- uchar idata *F_buff;
- F_buff = buff + 0x10;
- write_reg(0x22,0x07);
- *F_buff = RF_CMD_WRITE;
- *(F_buff + 1) = Block_Adr;
- temp = Command_Send(2, F_buff, Transceive);
- if(temp == FALSE)
- return(FM1715_NOTAGERR);
- if(temp == 0)
- return(FM1715_BYTECOUNTERR);
- Read_FIFO(F_buff);
- temp = *F_buff;
- switch(temp)
- case 0x00: return(FM1715_NOTAUTHERR); /* 暂时屏蔽掉写错误 */
- case 0x04: return(FM1715_EMPTY);
- case 0x0a: break;
- case 0x01: return(FM1715_CRCERR);
- case 0x05: return(FM1715_PARITYERR);
- default: return(FM1715_WRITEERR);
- temp = Command_Send(16, buff, Transceive);
- if(temp == TRUE)
- return(FM1715_OK);
- else
- return(FM1715_PARITYERR);
- else if((temp & 0x04) == 0x04)
- return(FM1715_FRAMINGERR);
- else if((temp & 0x08) == 0x08)
- return(FM1715_CRCERR);
- else
- return(FM1715_WRITEERR);
