[STM32F1]
STM32F1两点CAN通信有波形,接收不到数据
3866|3
kaynlee|  楼主 | 2014-3-10 15:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我用STM32103RE与红牛开发板(STM32103ZE)进行CAN总线2点通信,一块应用例程程序,另一块应用修改程序,各自LoopBack模式,没问题。CAN总线正常模式下,可以检测到H与L引脚有周期的波形,但是收不到正确的数据请问是怎么回事。
GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_11;
       GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;        //CAN_RX,上拉输入
    GPIO_Init(GPIOA, &GPIO_InitStructure);
       GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_12;
       GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;          //CAN_TX,复用推挽输出
144脚STM32103ZE
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_AFIO,ENABLE);                /*  使能相关CAN引脚时钟         */
    GPIO_PinRemapConfig(GPIO_Remap1_CAN1,ENABLE);                       /*  重映射CAN引脚               */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
    GPIO_Init(GPIOB, &GPIO_InitStructure);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
    GPIO_InitStructure.GPIO_Speed =    GPIO_Speed_10MHz;
CAN配置部分
void CAN_Configuration(void)
CAN_InitTypeDef CAN_InitStructure;
CAN_FilterInitTypeDef  CAN_FilterInitStructure;
CAN_DeInit();
CAN_FilterInitStructure.CAN_FilterNumber=0;//选择过滤器0
CAN_FilterInitStructure.CAN_FilterMode=CAN_FilterMode_IdMask;//指定过滤器被设置为标识符屏蔽模式
CAN_FilterInitStructure.CAN_FilterScale=CAN_FilterScale_32bit;//给出过滤器位宽为32位
CAN_FilterInitStructure.CAN_FilterIdHigh=0x0000;   //     0x0020
CAN_FilterInitStructure.CAN_FilterIdLow=0x0000;        // 0x0002
CAN_FilterInitStructure.CAN_FilterMaskIdHigh=0x0000;
CAN_FilterInitStructure.CAN_FilterMaskIdLow=0x0000;
CAN_FilterInitStructure.CAN_FilterFIFOAssignment=0;//为过滤器分配缓存 此处到//fifo 因为 CAN_FilterInitStructure.CAN_FilterNumber=0;
CAN_FilterInitStructure.CAN_FilterActivation=ENABLE;
CAN_FilterInit(&CAN_FilterInitStructure);
CAN_InitStructure.CAN_TTCM = DISABLE;
CAN_InitStructure.CAN_ABOM = DISABLE;
CAN_InitStructure.CAN_AWUM = DISABLE;
CAN_InitStructure.CAN_NART = DISABLE;
CAN_InitStructure.CAN_RFLM = DISABLE;
CAN_InitStructure.CAN_TXFP = DISABLE;
CAN_InitStructure.CAN_Mode=CAN_Mode_LoopBack ;              //     CAN_Mode_LoopBack,CAN_Mode_Normal
CAN_InitStructure.CAN_SJW=CAN_SJW_1tq;                    //重新同步跳跃宽度1个时间单位,在每位中可以延长或缩短多少个时间单位的上限
CAN_InitStructure.CAN_BS1=CAN_BS1_5tq;                    //时间段1为4个时间单位
CAN_InitStructure.CAN_BS2=CAN_BS2_2tq;                    // 时间段2为3个时间单位
CAN_InitStructure.CAN_Prescaler=4.5;                           //CAN_Prescaler设定了一个时间
CAN_Init(&CAN_InitStructure);                            //CAN_APS=PCLK1/((1+5+2)*3)=1MBPS
  CAN_ITConfig(CAN_IT_FMP0, ENABLE);
CAN接受中断
void UserCAN_NVIC_Config(void)
  NVIC_InitTypeDef  NVIC_InitStructure;
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
  NVIC_InitStructure.NVIC_IRQChannel = USB_LP_CAN_RX0_IRQChannel;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x0;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
void USB_LP_CAN_RX0_IRQHandler(void)
INT32U i;
    i=CAN_GetITStatus(CAN_IT_FMP0);
      if(CAN_GetITStatus(CAN_IT_FMP0)!= RESET)
       INT16U ch;
       CanRxMsg RxMessage;
       CAN_ClearITPendingBit(CAN_IT_FMP0);
     CAN_Receive(CAN_FIFO0,&RxMessage);
                ch=(RxMessage.Data[1]<<8)|RxMessage.Data[0];
CAN发送部分:
while(DEF_TRUE)
    CanTxMsg TxMessage;
       CanRxMsg RxMessage;
       CAN_TypeDef CAN_Type;
       u8 TransmitMailbox;
       TxMessage.StdId=0x11;                 //标识符
       TxMessage.IDE=CAN_ID_STD;                //标准标识符
       TxMessage.RTR=CAN_RTR_DATA;                 //数据帧
    TxMessage.DLC=8;                              //传输消息的帧长度
       TxMessage.Data[0]=0X09;
       TxMessage.Data[1]=0X11;
       TxMessage.Data[2]=0X42;
    TxMessage.Data[3]=0X86;
       TxMessage.Data[4]=0X33;
       TxMessage.Data[5]=0X91;
       TxMessage.Data[6]=0XF6;
       TxMessage.Data[7]=0X77;
TransmitMailbox=CAN_Transmit(&TxMessage);
while((CAN_TransmitStatus(TransmitMailbox) != CANTXOK));
                     OSTimeDlyHMSM(0,0,0,200);
kaynlee|  楼主 | 2014-3-11 10:37 | 只看该作者
15113484470| | 2014-11-12 15:24 | 只看该作者
楼主问题解决了吗
21ID| | 2014-11-12 15:31 | 只看该作者
波形正确吗?
