PWM为什么没输出
1327|2
jxmzzr|  楼主 | 2014-4-24 15:24 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
用STM32F101VC做PWM:
程序如下:
void Timer3Init(void)
  //RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
  /* Time base configuration */
  //--------------------For   pwm--------------
  //----------第一步:配置时钟 ---------------
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC,ENABLE);
  RCC_APB2PeriphClockCmd(RCC_APB1Periph_TIM3,ENABLE);
  //TIM_InternalClockConfig(TIM3);
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE);
  TIM_TimeBaseStructure.TIM_Period = 65535;
  TIM_TimeBaseStructure.TIM_Prescaler = 35;//8+1=9
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
  /* Prescaler configuration */
//  TIM_PrescalerConfig(TIM3, 1, TIM_PSCReloadMode_Immediate);
  /* Output Compare Timing Mode configuration: Channel1 */
//  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Timing;
//  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Disable;
//  TIM_OCInitStructure.TIM_Pulse = CCR1_Val;
//  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
//  TIM_OC1Init(TIM3, &TIM_OCInitStructure);
//  TIM_OC1PreloadConfig(TIM3, TIM_OCPreload_Disable);
  /* TIM IT enable */
//  TIM_ITConfig(TIM3, TIM_IT_Update  , ENABLE);
  /* TIM2 enable counter */
  TIM_Cmd(TIM3, DISABLE);
//  TIM_SelectOnePulseMode(TIM3, TIM_OPMode_Single);
// NVIC_InitStructure.NVIC_IRQChannel = TIM3_UP_IRQChannel;
  NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQChannel;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
  //------------For  PWM----------------------
  //-----------第二步,配置goio口-------------
   GPIO_InitStructure2.GPIO_Pin=GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9;
   GPIO_InitStructure2.GPIO_Speed=GPIO_Speed_50MHz;
   GPIO_InitStructure2.GPIO_Mode=GPIO_Mode_AF_PP;                 //设置为复用浮空输出
   GPIO_Init(GPIOC,&GPIO_InitStructure2);
        /*********TIM1_CH1N 引脚配置********/
   GPIO_PinRemapConfig(GPIO_FullRemap_TIM3, ENABLE);
    //第三步,定时器基本配置
   TIM_TimeBaseStructure.TIM_Period=1000-1;             // 自动重装载寄存器的值
   TIM_TimeBaseStructure.TIM_Prescaler=72-1;            // 时钟预分频数
   TIM_TimeBaseStructure.TIM_ClockDivision=0;    // 采样分频
   TIM_TimeBaseStructure.TIM_CounterMode=TIM_CounterMode_Up;//向上计数
   TIM_TimeBaseStructure.TIM_RepetitionCounter=0;//重复寄存器,用于自动更新pwm占空比
   //第四步pwm输出配置
   TIM_OCInitStructure.TIM_OCMode=TIM_OCMode_PWM1;                    //设置为pwm1输出模式
   TIM_OCInitStructure.TIM_Pulse=500;                                            //设置占空比时间
   TIM_OCInitStructure.TIM_OCPolarity=TIM_OCPolarity_Low;                 //设置输出极性
   TIM_OCInitStructure.TIM_OCNPolarity=TIM_OCNPolarity_High;        //设置互补端输出极性
   //下面几个参数是高级定时器才会用到,通用定时器不用配置
   TIM_OCInitStructure.TIM_OutputState=TIM_OutputState_Enable;        //使能该通道输出
   TIM_OCInitStructure.TIM_OutputNState=TIM_OutputNState_Enable;//使能互补端输出
   TIM_OC1Init(TIM3,&TIM_OCInitStructure);   //按照指定参数初始化
   TIM_OC1PreloadConfig(TIM3,TIM_OCPreload_Enable);
    //第四步pwm输出配置
   TIM_OC2Init(TIM3,&TIM_OCInitStructure);   //按照指定参数初始化
   TIM_OC2PreloadConfig(TIM3,TIM_OCPreload_Enable);
    //第四步pwm输出配置
   TIM_OC3Init(TIM3,&TIM_OCInitStructure);   //按照指定参数初始化
   TIM_OC3PreloadConfig(TIM3,TIM_OCPreload_Enable);
     //第四步pwm输出配置
   TIM_OC4Init(TIM3,&TIM_OCInitStructure);   //按照指定参数初始化
   TIM_OC4PreloadConfig(TIM3,TIM_OCPreload_Enable);
  //第五步,死区和刹车功能配置,高级定时器才有的,通用定时器不用配置
//第六步,使能端的打开
              //使能TIMx在ARR上的预装载寄存器
   TIM_ClearITPendingBit(TIM3,TIM_IT_Update);
   TIM_Cmd(TIM3,ENABLE);
    //打开TIM2
    TIM_ARRPreloadConfig(TIM3, ENABLE);//使能ARR预装载缓冲器
    //下面这句是高级定时器才有的,输出pwm必须打开
    TIM_CtrlPWMOutputs(TIM3, ENABLE);                                   //pwm输出使能,一定要记得打开
我的PWM为什么没输出?用的是TIM3四个通道。
mmuuss586| | 2014-4-24 21:25 | 只看该作者
值改成100,拿示波器看下有没有PWM输出
BioAA| | 2014-8-28 18:22 | 只看该作者
RCC_APB2PeriphClockCmd(RCC_APB1Periph_TIM3,ENABLE);      這行寫錯了
