加了15个左右1,6*16的字库,编译成功!
ROM 13% full. 2004 out of 16384 bytes used.
RAM 992 bytes used (does not include stack usage).
Built with ICCAVR PRO V8.04.01
Process terminated with status 0 (0 minutes, 0 seconds)
0 errors, 0 warnings
但是在多加一个字库的代码,就显示:
Build: default in Test ---------------
iccavr.exe -LC:\iccv8avr\lib -o ..\Test\Test .objs\main.o .objs\lcd.o -cross_module_type_checking -g -e:0x4000 -ucrtatmega.o -bfunc_lit:0x54.0x4000 -dram_end:0x45f -bdata:0x60.0x45f -dhwstk_size:20 -beeprom:0.512 -fihx_coff -S2 -nb:13 -lcatmega
!E <library>(44): {linker} area 'noinit' not large enough. Need 0 bytes
lo 1120 hi 1119 size 0
!E <library>(44): {linker} area 'bss' not large enough. Need 0 bytes
iccavr.exe: 'C:\iccv8avr\bin\ilinkavr.exe' returns error code -1
Process terminated with status -1 (0 minutes, 0 seconds)
2 errors, 0 warnings
不知道是什么原因,要怎么解决????
