[STM32F4]
F4中断为什么进不去呢
1462|3
tianli1980|  楼主 | 2014-7-31 19:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
TI, vi, ic, ni, ST
中断配置代码如下:
void bsp_InitKeyEXTI(void)
        EXTI_InitTypeDef   EXTI_InitStructure;
        NVIC_InitTypeDef   NVIC_InitStructure;
        /* 使能SYSCFG时钟 */
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE);
        /* 连接 EXTI Line8 到 PI8 引脚 */
        SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOI, EXTI_PinSource8);
        /* 连接 EXTI Line13 到 PC13 引脚 */
        SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOC, EXTI_PinSource13);
        /* 连接 EXTI Line11 到 PI11 引脚 */
  SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOI, EXTI_PinSource11);
        /* 连接 EXTI Line3 到 PH3 引脚 */
  SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOH, EXTI_PinSource3);
        /* 连接 EXTI Line15 到 PH15 引脚 */
        SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOH, EXTI_PinSource15);
        /* 连接 EXTI Line7 到 PG7 引脚 */
        SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOG, EXTI_PinSource7);
        /* 连接 EXTI Line2 到 PH2 引脚 */
        SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOH, EXTI_PinSource2);
        /* 连接 EXTI Line11 到 PF11 引脚 */
//        SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOF, EXTI_PinSource11);
        /* 配置 EXTI LineXXX */
        EXTI_InitStructure.EXTI_Line = EXTI_Line2 | EXTI_Line3 | EXTI_Line7 | EXTI_Line8 \
                                     | EXTI_Line11 | EXTI_Line13| EXTI_Line15;
        //EXTI_InitStructure.EXTI_Line = EXTI_Line13 | EXTI_Line11 |  EXTI_Line8 | EXTI_Line7 ;
        EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
        EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
        EXTI_InitStructure.EXTI_LineCmd = ENABLE;
        EXTI_Init(&EXTI_InitStructure);
        /* 设置NVIC优先级分组为Group2:0-3抢占式优先级,0-3的响应式优先级 */
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
        /* 中断优先级配置 最低优先级 这里一定要分开的设置中断,不能够合并到一个里面设置 */
        NVIC_InitStructure.NVIC_IRQChannel = EXTI2_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x00;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x00;
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
        NVIC_Init(&NVIC_InitStructure);
        NVIC_InitStructure.NVIC_IRQChannel = EXTI3_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x01;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x01;
        NVIC_InitStructure.NVIC_IRQChannel = EXTI9_5_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x02;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x02;
        NVIC_InitStructure.NVIC_IRQChannel = EXTI15_10_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x03;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x03;
当 EXTI15_10_IRQn和EXTI9_5_IRQn的抢占优先级设置为一样,即0x02或者0x03时都能进入。但是一个设置为0x02一个设置为0x03时,设置为0x03那个的中断函数就是进不去,到底是什么情况呢?
拿起书本| | 2014-8-11 14:12 | 只看该作者
建议楼主看看是不是干扰。检查下电路图。
_icmcu_study| | 2014-8-16 16:59 | 只看该作者
你进中断清楚中断标志位没有? 是不是02那个一直在进行中断,导致03那个无法进入呢
mryw| | 2014-8-16 21:35 | 只看该作者
我也遇到这个问题了。
