[MCU新闻]
抢先体验MDK-ARM 512版本 keil512抢先体验
5941|25
Harvard|  楼主 | 2014-9-25 22:02 | 显示全部楼层 回帖奖励 |倒序浏览 |阅读模式
传说中的512版本出来了.哈哈 赶紧下载,和谐照旧.
http://www.keil.com/download/files/mdkcm512.exe
同学们赶紧下载体验.
说说更新吧:
1, This MDK version introduces support for ARM Cortex-M7 processor based devices.
此版本引入了对最新的m7的支持.
2This MDK release contains two ARM Compiler versions that can be selected in the dialog Project - Options for Target - Target (under Code Generation):
ARM Compiler 5.05 (build 41) (in directory ..\ARM\ARMCC\) with support for Cortex-M7 and other enhancements (see release notes).
ARM Compiler 5.04u2 (build 82) (in directory ..\ARM\ARMCC_504u2\) for safety critical applications in combination with the ARM Compiler Qualification Kit (only available with a license for MDK-Professional).
此版本引入了2个arm编译器, 在项目配置中,可以通过下拉选择;
3 Enhanced performance in the Project View and new file, group, and component attributes.
工程显示 菜单,组件的更新.
还有其他一些中间件软件的更新.
个人签名:单片机工作者
74
