intel196kc温度测量程序代码
2767|0
njliu|  楼主 | 2007-1-26 19:41 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
$include(reg96.asm)
outbit  equ     0e101h
clk164  equ     0e102h
dat164  equ     0e102h
in      equ     0e103h
ad      equ     0a000h
ledbuf  equ     60h
time    equ     40h:byte
shift   equ     42h:byte
val     equ     43h:byte
        cseg at  2080h
        di
        ld      sp,#00c0h
        ld      ax,#0e100h
        ldb    50h,#3
        stb     50h,[ax]
        ld      bx,#ledbuf ;设置显示缓冲区
        ldb    50h,#0h
        stb     50h,[bx]+
        ldb     50h, #8
        stb     50h,[bl]+
        ldb     50h,#0
        stb     50h,[bl]+
        ldb     50h,#9
        stb     50h,[bl]+
        ldb    50h,#10h
        stb     50h,[bx]+
        stb     50h,[bx]+   ;显示"0809  "
mloop:  lcall   displed     ;显示
        lcall   delay
        lcall   delay
        lcall    ad_con     ;调用A/D
        ldb      al,val
        andb     al,#0f0h   ;拆字
        shrb     al,#4
        ldb      64h,al
        ldb      al,val
        andb     al,#0fh
        ldb      65h,al
        ljmp    mloop
ad_con: ld      dx,#0a000h    ;启动ADC0809
        ldb     50h,#0h
        stb     50h,[dx]
        ldb    50h,#0ffh
        djnz   50h,$
        ldb     val,[dx]      ;读AD结果
        ret
delay:  ld      time,#8000h
        djnz    time,$
        ret
tt:     ld      time,#100
        djnz    time,$
        ret
displed:ld      ax,#ledbuf
        ldb     cl,#6h
        ldb     shift,#20h
loop0:  ld      dx,#outbit
        ldb     50h,#0h
        stb     50h,[dx]
        ldb     bl,[ax]+
        ldbze   dx,bl
        ldb     bl,disptab[dx]
        ldb     ch,#8h
dpl:    shlb    bl,#1
        jnc     ad1
        ldb     val,#0fdh
        ljmp    ad2
ad1:    ldb     val,#0fch
ad2:    ld      dx,#dat164
        stb     val,[dx]
        ld      dx,#clk164
        orb    val,#2
        stb     val,[dx]
        nop
        nop
        andb     val,#0fdh
        stb     val,[dx]
        nop
        nop
        djnz    ch,dpl
        ld      dx,#outbit
        stb     shift,[dx]
        shrb    shift,#1
        lcall  tt
        ldb    50h,#0h
        stb    50h,[dx]
        djnz    cl,loop0
        ret
disptab:dcb   3fh,06h,5bh,4fh,66h,6dh,7dh,07h
        dcb   7fh,6fh,77h,7ch,39h,5eh,79h,71h,0
        end
