关于PICC读AT93C46使用,无法读出,附源程
2937|3
sunlimcu|  楼主 | 2008-3-5 09:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include"pic.h"
#include"pic16f7x.h"
#define CS RC2
   PIC16F74    AT93C46
      RC4--------DO
      RC5--------DI
      RC2--------CS
      RC3--------SK
      GND--------GND,ORG
      VDD--------VCC
void MCU_init()
     PORTC=0X2C;
     TRISC=0XD0;
     PORTD=0X00;
     TRISD=0X00;
     PORTE=0X00;
     TRISE=0X00;
     OPTION=0X42;//4MHZ OSC 8分频
     TMR0=131;   //1ms定时
     SSPSTAT=0;
     SSPCON=0X31;
//93c46读写程序,使用SPI
void Delay(void)
     asm("nop");
     asm("nop");
unsigned char OutPut(unsigned char SendData)
     unsigned char temp;
     SSPBUF=SendData;
     //asm("nop");
     //asm("nop");
     while(STAT_BF==0)
         asm("clrwdt");
     temp=SSPBUF;
     return(temp);
void Ewen(void)
     unsigned char temp;
     CS=1;
     Delay();
     temp=0X09;
     OutPut(temp);
     temp=EWEN;   //0x80;
     OutPut(temp);
     Delay();
     CS=0;
void Ewds(void)
     unsigned char temp;
     CS=1;
     Delay();
     temp=0x02;
     OutPut(temp);
     temp=0x00;
     OutPut(temp);
     Delay();
     CS=0;
void WriteByte(unsigned char WData,unsigned char Adress)
      unsigned char wtemp;
      Ewen();
      CS=1;
      Delay();
      wtemp=0x02;
      OutPut(wtemp);
      wtemp=Adress|0x80;
      OutPut(wtemp);
      OutPut(WData);
      CS=0;
      Delay();
      CS=1;
      while(!DI);
      CS=0;
unsigned char  ReadByte(unsigned char Adress)
unsigned char wrtemp,rtemp;
CKP=1;
CS=1;
Delay();
wrtemp=0x03;
OutPut(wrtemp);
wrtemp=Adress&0x7f;
OutPut(wrtemp);
// asm()"nop";
CKP=0;
asm("nop");
rtemp=OutPut(wrtemp);
Delay();
CS=0;
CKP=1;
return(rtemp);
/*void WriteBytes(unsigned char *WriteData,unsigned char Number,unsigned char Adress){
  unsigned char temp;
  Ewen();
  while(Number!=0){
   temp=*WriteData;
         WriteByte(temp,Adress);
         asm("nop");
         asm("nop");
         CS=1;
         asm("nop");
         asm("nop");
         while(DI==0){
              asm("clrwdt");
         Delay();
         CS=0;
         WriteData++;
         Adress++;
         Number--;
void ReadBytes(unsigned char *ReadData,unsigned char Number,unsigned char Adress)
//unsigned char temp;
while(Number!=0)
asm("clrwdt");
*ReadData=ReadByte(Adress);
ReadData++;
Adress++;
Number--;
void main(void)
 MCU_init();
 WriteByte(100,1);
 temp=0;
 temp=ReadByte(1);
 读出来的是0XFF??
 while(1);
hotpower| | 2008-3-10 23:56 | 只看该作者
先用IO模拟看看~~~
wjf07| | 2008-3-11 15:31 | 只看该作者
pls call Microchip office
shishaojun| | 2009-3-26 22:56 | 只看该作者
不用这么麻烦,picc自己带i2c程序库
