[STM32F1]
利用stm32输出可调的PFM波,但ADC不起作用!!
1417|5
mmuuss586| | 2015-3-23 12:15 | 显示全部楼层 回帖奖励 |倒序浏览
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
ADC_InitTypeDef ADC_InitStructure;
DMA_InitTypeDef DMA_InitStructure;
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
#define ADC1_DR_ADDRESS     ((uint32_t)0x4001204C)
__IO uint16_t ADCConvertedValue=0;
void Adc12_Init(void)
  NVIC_InitTypeDef NVIC_InitStructure;
  /* Enable DMA1 clock */
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1|RCC_APB2Periph_ADC2, ENABLE);
          /* Configure and enable ADC interrupt */
  NVIC_InitStructure.NVIC_IRQChannel = ADC1_2_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
  /* Configure PA.01 (ADC Channe1) as analog input -------------------------*/
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
          /* DMA1 channel1 configuration ----------------------------------------------*/
  DMA_DeInit(DMA1_Channel1);
  DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_ADDRESS;
  DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)&ADCConvertedValue;
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
  DMA_InitStructure.DMA_BufferSize = 1;
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Disable;
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
  DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
  DMA_Init(DMA1_Channel1, &DMA_InitStructure);
  /* Enable DMA1 channel1 */
  DMA_Cmd(DMA1_Channel1, ENABLE);
  /* ADC1 configuration ------------------------------------------------------*/
  ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
  ADC_InitStructure.ADC_ScanConvMode = ENABLE;
  ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
  ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
  ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
  ADC_InitStructure.ADC_NbrOfChannel = 1;
  ADC_Init(ADC1, &ADC_InitStructure);
  /* ADC1 regular channel14 configuration */
  ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 1, ADC_SampleTime_239Cycles5);
  /* Enable ADC1 DMA */
  ADC_DMACmd(ADC1, ENABLE);
  /* Enable ADC1 */
  ADC_Cmd(ADC1, ENABLE);
  /* Enable ADC1 reset calibration register */
  ADC_ResetCalibration(ADC1);
  /* Check the end of ADC1 reset calibration register */
  while(ADC_GetResetCalibrationStatus(ADC1));
  /* Start ADC1 calibration */
  ADC_StartCalibration(ADC1);
  /* Check the end of ADC1 calibration */
  while(ADC_GetCalibrationStatus(ADC1));
  /* Start ADC1 Software Conversion */
  ADC_SoftwareStartConvCmd(ADC1, ENABLE);
          /* ADC2 configuration ------------------------------------------------------*/
  ADC_InitStructure.ADC_ScanConvMode = DISABLE;
  ADC_Init(ADC2, &ADC_InitStructure);
  /* ADC2 regular channels configuration */
  ADC_RegularChannelConfig(ADC2, ADC_Channel_0, 1, ADC_SampleTime_239Cycles5 );
  /* Enable ADC2 EOC interrupt */
  ADC_ITConfig(ADC2, ADC_IT_EOC, ENABLE);
          /* Enable ADC2 */
  ADC_Cmd(ADC2, ENABLE);
  /* Enable ADC2 reset calibration register */
  ADC_ResetCalibration(ADC2);
  /* Check the end of ADC2 reset calibration register */
  while(ADC_GetResetCalibrationStatus(ADC2));
  /* Start ADC2 calibration */
  ADC_StartCalibration(ADC2);
  /* Check the end of ADC2 calibration */
  while(ADC_GetCalibrationStatus(ADC2));
        /* Start ADC2 Software Conversion */
  ADC_SoftwareStartConvCmd(ADC2, ENABLE);
mmuuss586| | 2015-3-23 12:16 | 显示全部楼层
我的ADC初始化,仅供参考;
mmuuss586| | 2015-4-1 12:28 | 显示全部楼层
476754698 发表于 2015-4-1 09:40
非常感谢,我先试一下。
不客气
