PSoC4进不了串口中断
3105|35
 楼主| heping517 发表于 2015-6-25 08:42 | 显示全部楼层
        * Function Name: UART_1_EnableTxInt
        * Summary:
        *  Enable TX interrupt generation
        * Parameters:
        *  None.
        * Return:
        *  None.
        * Theory:
        *  Enable the interrupt output -or- the interrupt component itself
        void UART_1_EnableTxInt(void)
            CyIntEnable(UART_1_TX_VECT_NUM);
 楼主| heping517 发表于 2015-6-25 08:43 | 显示全部楼层
        * Function Name: UART_1_DisableTxInt
        * Summary:
        *  Disable TX interrupt generation
        * Parameters:
        *  None.
        * Return:
        *  None.
        * Theory:
        *  Disable the interrupt output -or- the interrupt component itself
        void UART_1_DisableTxInt(void)
            CyIntDisable(UART_1_TX_VECT_NUM);
    * Function Name: UART_1_SetTxInterruptMode
    * Summary:
    *  Configure which status bits trigger an interrupt event
    * Parameters:
    *  intSrc: An or'd combination of the desired status bit masks (defined in
    *          the header file)
    * Return:
    *  None.
    * Theory:
    *  Enables the output of specific status bits to the interrupt controller
    void UART_1_SetTxInterruptMode(uint8 intSrc)
        UART_1_TXSTATUS_MASK_REG = intSrc;
    * Function Name: UART_1_WriteTxData
    * Summary:
    *  Write a byte of data to the Transmit FIFO or TX buffer to be sent when the
    *  bus is available. WriteTxData sends a byte without checking for buffer room
    *  or status. It is up to the user to separately check status.
    * Parameters:
    *  TXDataByte: byte of data to place in the transmit FIFO
    * Return:
    * void
    * Global Variables:
    *  UART_1_txBuffer - RAM buffer pointer for save data for transmission
    *  UART_1_txBufferWrite - cyclic index for write to txBuffer,
    *    incremented after each byte saved to buffer.
    *  UART_1_txBufferRead - cyclic index for read from txBuffer,
    *    checked to identify the condition to write to FIFO directly or to TX buffer
    *  UART_1_initVar - checked to identify that the component has been
    *    initialized.
    * Reentrant:
    *  No.
    void UART_1_WriteTxData(uint8 txDataByte)
        /* If not Initialized then skip this function*/
        if(UART_1_initVar != 0u)
            #if(UART_1_TXBUFFERSIZE > UART_1_FIFO_LENGTH)
                /* Disable Tx interrupt. */
                /* Protect variables that could change on interrupt. */
                #if(UART_1_TX_INTERRUPT_ENABLED)
                    UART_1_DisableTxInt();
                #endif /* End UART_1_TX_INTERRUPT_ENABLED */
                if( (UART_1_txBufferRead == UART_1_txBufferWrite) &&
                    ((UART_1_TXSTATUS_REG & UART_1_TX_STS_FIFO_FULL) == 0u) )
                    /* Add directly to the FIFO. */
                    UART_1_TXDATA_REG = txDataByte;
                else
                    if(UART_1_txBufferWrite >= UART_1_TXBUFFERSIZE)
                        UART_1_txBufferWrite = 0u;
                    UART_1_txBuffer[UART_1_txBufferWrite] = txDataByte;
                    /* Add to the software buffer. */
                    UART_1_txBufferWrite++;
                /* Enable Tx interrupt. */
                    UART_1_EnableTxInt();
            #else /* UART_1_TXBUFFERSIZE > UART_1_FIFO_LENGTH */
            #endif /* End UART_1_TXBUFFERSIZE > UART_1_FIFO_LENGTH */
    * Function Name: UART_1_ReadTxStatus
    * Summary:
    *  Read the status register for the component
    * Parameters:
    *  None.
    * Return:
    *  Contents of the status register
    * Theory:
    *  This function reads the status register which is clear on read. It is up to
    *  the user to handle all bits in this return value accordingly, even if the bit
    *  was not enabled as an interrupt source the event happened and must be handled
    *  accordingly.
    uint8 UART_1_ReadTxStatus(void)
        return(UART_1_TXSTATUS_REG);
 楼主| heping517 发表于 2015-6-25 08:44 | 显示全部楼层
    * Summary:
    * Parameters:
    *  None.
    * Return:
    * Theory:
    *  accordingly.
    * Function Name: UART_1_PutString
    * Summary:
    *  Write a Sequence of bytes on the Transmit line. Data comes from RAM or ROM.
    * Parameters:
    *  string: char pointer to character string of Data to Send.
    * Return:
    *  None.
    * Global Variables:
    *     initialized.
    * Reentrant:
    *  No.
    * Theory:
    *  This function will block if there is not enough memory to place the whole
    *  string, it will block until the entire string has been written to the
    *  transmit buffer.
    void UART_1_PutString(const char8 string[])
        uint16 buf_index = 0u;
            /* This is a blocking function, it will not exit until all data is sent*/
            while(string[buf_index] != (char8)0)
                UART_1_PutChar((uint8)string[buf_index]);
                buf_index++;
 楼主| heping517 发表于 2015-6-25 09:41 | 显示全部楼层
    * Summary:
    * Parameters:
    * Return:
    *  None.
    * Global Variables:
    *     initialized.
    * Reentrant:
    *  No.
    * Theory:
    *  transmit buffer.
                buf_index++;
    * Function Name: UART_1_PutArray
    * Summary:
    * Parameters:
    *  string: Address of the memory array residing in RAM or ROM.
    *  byteCount: Number of Bytes to be transmitted.
    * Return:
    *  None.
    * Global Variables:
    *     initialized.
    * Reentrant:
    *  No.
    void UART_1_PutArray(const uint8 string[], uint8 byteCount)
        uint8 buf_index = 0u;
            do
                UART_1_PutChar(string[buf_index]);
                buf_index++;
            }while(buf_index < byteCount);
    * Function Name: UART_1_PutCRLF
    * Summary:
    *  Write a character and then carriage return and line feed.
    * Parameters:
    *  txDataByte: uint8 Character to send.
    * Return:
    *  None.
    * Global Variables:
    *     initialized.
    * Reentrant:
    *  No.
    void UART_1_PutCRLF(uint8 txDataByte)
            UART_1_PutChar(txDataByte);
            UART_1_PutChar(0x0Du);
            UART_1_PutChar(0x0Au);
 楼主| heping517 发表于 2015-6-25 09:42 | 显示全部楼层
    * Function Name: UART_1_GetTxBufferSize
    * Summary:
    *  Determine the amount of space left in the TX buffer and return the count in
    *  bytes
    * Parameters:
    *  None.
    * Return:
    *  Integer count of the number of bytes left in the TX buffer
    * Global Variables:
    *  UART_1_txBufferWrite - used to calculate left space.
    *  UART_1_txBufferRead - used to calculate left space.
    * Reentrant:
    *  No.
    * Theory:
    *  Allows the user to find out how full the TX Buffer is.
    uint8 UART_1_GetTxBufferSize(void)
        uint8 size;
            if(UART_1_txBufferRead == UART_1_txBufferWrite)
                size = 0u;
            else if(UART_1_txBufferRead < UART_1_txBufferWrite)
                size = (UART_1_txBufferWrite - UART_1_txBufferRead);
            else
                size = (UART_1_TXBUFFERSIZE - UART_1_txBufferRead) + UART_1_txBufferWrite;
            size = UART_1_TXSTATUS_REG;
            /* Is the fifo is full. */
            if((size & UART_1_TX_STS_FIFO_FULL) != 0u)
                size = UART_1_FIFO_LENGTH;
            else if((size & UART_1_TX_STS_FIFO_EMPTY) != 0u)
                size = 0u;
            else
                /* We only know there is data in the fifo. */
                size = 1u;
        return(size);
    * Function Name: UART_1_ClearTxBuffer
    * Summary:
    *  Clears the TX RAM buffer by setting the read and write pointers both to zero.
    *  Clears the hardware TX FIFO.  Any data present in the FIFO will not be sent.
    * Parameters:
    *  None.
    * Return:
    *  None.
    * Global Variables:
    *  UART_1_txBufferWrite - cleared to zero.
    *  UART_1_txBufferRead - cleared to zero.
    * Reentrant:
    *  No.
    * Theory:
    *  Setting the pointers to zero makes the system believe there is no data to
    *  read and writing will resume at address 0 overwriting any data that may have
    *  remained in the RAM.
    * Side Effects:
    *  Any received data not read from the RAM buffer will be lost when overwritten.
    void UART_1_ClearTxBuffer(void)
        uint8 enableInterrupts;
        /* Enter critical section */
        enableInterrupts = CyEnterCriticalSection();
        /* clear the HW FIFO */
        UART_1_TXDATA_AUX_CTL_REG |=  UART_1_TX_FIFO_CLR;
        UART_1_TXDATA_AUX_CTL_REG &= (uint8)~UART_1_TX_FIFO_CLR;
        /* Exit critical section */
        CyExitCriticalSection(enableInterrupts);
            UART_1_txBufferRead = 0u;
    * Function Name: UART_1_SendBreak
    * Summary:
    *  Write a Break command to the UART
    * Parameters:
    *  uint8 retMode:  Wait mode,
    *   0 - Initialize registers for Break, sends the Break signal and return
    *       imediately.
    *   1 - Wait until Break sending is complete, reinitialize registers to normal
    *       transmission mode then return.
    *   2 - Reinitialize registers to normal transmission mode then return.
    *   3 - both steps: 0 and 1
    *       init registers for Break, send Break signal
    *       wait until Break sending is complete, reinit registers to normal
    * Return:
    *  None.
    * Global Variables:
    *     initialized.
    *  tx_period - static variable, used for keeping TX period configuration.
    * Reentrant:
    *  No.
    * Theory:
    *  SendBreak function initializes registers to send 13-bit break signal. It is
    *  important to return the registers configuration to normal for continue 8-bit
    *  operation.
    *  Trere are 3 variants for this API usage:
    *  1) SendBreak(3) - function will send the Break signal and take care on the
    *     configuration returning. Funcition will block CPU untill transmition
    *     complete.
    *  2) User may want to use bloking time if UART configured to the low speed
    *     operation
    *     Emample for this case:
    *     SendBreak(0);     - init Break signal transmition
    *         Add your code here to use CPU time
    *     SendBreak(1);     - complete Break operation
    *  3) Same to 2) but user may want to init and use the interrupt for complete
    *     break operation.
    *     Example for this case:
    *     Init TX interrupt whith "TX - On TX Complete" parameter
    *     When interrupt appear with UART_TX_STS_COMPLETE status:
    *     SendBreak(2);     - complete Break operation
    * Side Effects:
    *   Uses static variable to keep registers configuration.
    void UART_1_SendBreak(uint8 retMode)
            /*Set the Counter to 13-bits and transmit a 00 byte*/
            /*When that is done then reset the counter value back*/
            uint8 tmpStat;
            #if(UART_1_HD_ENABLED) /* Half Duplex mode*/
                if( (retMode == UART_1_SEND_BREAK) ||
                    (retMode == UART_1_SEND_WAIT_REINIT ) )
                    /* CTRL_HD_SEND_BREAK - sends break bits in HD mode*/
                    UART_1_WriteControlRegister(UART_1_ReadControlRegister() |
                                                          UART_1_CTRL_HD_SEND_BREAK);
                    /* Send zeros*/
                    UART_1_TXDATA_REG = 0u;
                    do /*wait until transmit starts*/
                        tmpStat = UART_1_TXSTATUS_REG;
                    }while((tmpStat & UART_1_TX_STS_FIFO_EMPTY) != 0u);
                if( (retMode == UART_1_WAIT_FOR_COMPLETE_REINIT) ||
                    (retMode == UART_1_SEND_WAIT_REINIT) )
                    do /*wait until transmit complete*/
                    }while(((uint8)~tmpStat & UART_1_TX_STS_COMPLETE) != 0u);
                    (retMode == UART_1_REINIT) ||
                    UART_1_WriteControlRegister(UART_1_ReadControlRegister() &
                                                  (uint8)~UART_1_CTRL_HD_SEND_BREAK);
            #else /* UART_1_HD_ENABLED Full Duplex mode */
                static uint8 tx_period;
                    /* CTRL_HD_SEND_BREAK - skip to send parity bit at Break signal in Full Duplex mode*/
                    #if( (UART_1_PARITY_TYPE != UART_1__B_UART__NONE_REVB) || \
                                        (UART_1_PARITY_TYPE_SW != 0u) )
                    #endif /* End UART_1_PARITY_TYPE != UART_1__B_UART__NONE_REVB  */
                    #if(UART_1_TXCLKGEN_DP)
                        tx_period = UART_1_TXBITCLKTX_COMPLETE_REG;
                        UART_1_TXBITCLKTX_COMPLETE_REG = UART_1_TXBITCTR_BREAKBITS;
                    #else
                        tx_period = UART_1_TXBITCTR_PERIOD_REG;
                        UART_1_TXBITCTR_PERIOD_REG = UART_1_TXBITCTR_BREAKBITS8X;
                    #endif /* End UART_1_TXCLKGEN_DP */
                    /* Send zeros*/
                    do /* wait until transmit starts */
                        UART_1_TXBITCLKTX_COMPLETE_REG = tx_period;
                    #else
                        UART_1_TXBITCTR_PERIOD_REG = tx_period;
                    #endif /* End UART_1_PARITY_TYPE != NONE */
            #endif    /* End UART_1_HD_ENABLED */
    * Function Name: UART_1_SetTxAddressMode
    * Summary:
    *  Set the transmit addressing mode
    * Parameters:
    *  addressMode: 0 -> Space
    *               1 -> Mark
    * Return:
    *  None.
    void UART_1_SetTxAddressMode(uint8 addressMode)
        /* Mark/Space sending enable*/
        if(addressMode != 0u)
            #if( UART_1_CONTROL_REG_REMOVED == 0u )
                                                      UART_1_CTRL_MARK);
            #endif /* End UART_1_CONTROL_REG_REMOVED == 0u */
        else
                                                    (uint8)~UART_1_CTRL_MARK);
 楼主| heping517 发表于 2015-6-25 09:43 | 显示全部楼层
    * Function Name: UART_1_LoadTxConfig
    * Summary:
    *  Unloads the Rx configuration if required and loads the
    *  Tx configuration. It is the users responsibility to ensure that any
    *  transaction is complete and it is safe to unload the Tx
    *  configuration.
    * Parameters:
    *  None.
    * Return:
    *  None.
    * Theory:
    *  Valid only for half duplex UART.
    * Side Effects:
    *  Disable RX interrupt mask, when software buffer has been used.
    void UART_1_LoadTxConfig(void)
        #if((UART_1_RX_INTERRUPT_ENABLED) && (UART_1_RXBUFFERSIZE > UART_1_FIFO_LENGTH))
            /* Disable RX interrupts before set TX configuration */
            UART_1_SetRxInterruptMode(0u);
        #endif /* UART_1_RX_INTERRUPT_ENABLED */
        UART_1_WriteControlRegister(UART_1_ReadControlRegister() | UART_1_CTRL_HD_SEND);
        UART_1_RXBITCTR_PERIOD_REG = UART_1_HD_TXBITCTR_INIT;
        #if(CY_UDB_V0) /* Manually clear status register when mode has been changed */
            /* Clear status register */
            CY_GET_REG8(UART_1_RXSTATUS_PTR);
        #endif /* CY_UDB_V0 */
    * Function Name: UART_1_LoadRxConfig
    * Summary:
    *  Unloads the Tx configuration if required and loads the
    *  Rx configuration. It is the users responsibility to ensure that any
    *  transaction is complete and it is safe to unload the Rx
    *  configuration.
    * Parameters:
    *  None.
    * Return:
    *  None.
    * Theory:
    * Side Effects:
    *  Set RX interrupt mask based on customizer settings, when software buffer
    *  has been used.
    void UART_1_LoadRxConfig(void)
                                                (uint8)~UART_1_CTRL_HD_SEND);
        UART_1_RXBITCTR_PERIOD_REG = UART_1_HD_RXBITCTR_INIT;
            /* Enable RX interrupt after set RX configuration */
            UART_1_SetRxInterruptMode(UART_1_INIT_RX_INTERRUPTS_MASK);
历史暴君 发表于 2015-6-25 18:45 | 显示全部楼层
顶一下,表示也不会
