[STM32F1] 外部计数STM32 ETR计算频率问题
2141|13
 楼主| zhshw0614 发表于 2015-7-22 16:32 | 显示全部楼层 |阅读模式
我用外部计数STM32 ETR计算频率,测量100K频率,用定时器2定时1S,定时器三PD2(TIM3_ETR)计数,计算公式f=n/t;测量出来的结果是9999 HZ,整整少了一位数字,这是什么原因呢,大家分析一下,谢谢,附我的程序
void Time3_Configuration()
   TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
   TIM_TimeBaseStructure.TIM_Prescaler = 0x00;
   TIM_TimeBaseStructure.TIM_Period = 0xFFFF;
   TIM_TimeBaseStructure.TIM_ClockDivision = 0x0;
   TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
   TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);  // Time base configuration
   TIM_ETRClockMode2Config(TIM3, TIM_ExtTRGPSC_OFF, TIM_ExtTRGPolarity_NonInverted, 0);
   //TIM_ITConfig(TIM3, TIM_IT_Update, ENABLE);
   TIM_SetCounter(TIM3, 0);
   TIM_Cmd(TIM3, ENABLE);
         /*1S定时*/
void Tim2_Config(void)
    TIM_TimeBaseInitTypeDef   TIM2_TimeBaseStructure;
    NVIC_InitTypeDef NVIC_InitStructure;
    TIM_DeInit(TIM2);
    TIM2_TimeBaseStructure.TIM_Period =999;
    TIM2_TimeBaseStructure.TIM_Prescaler = (7200-1);
    TIM2_TimeBaseStructure.TIM_ClockDivision = 0x0;//ÉèÖÃʱÖÓϵÊý ²»·ÖƵ
  TIM2_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;//ÏòÉϼÆÊýģʽ
    TIM_TimeBaseInit(TIM2, &TIM2_TimeBaseStructure); // Time base configuration
    TIM_ClearFlag(TIM2,TIM_FLAG_Update);//Çå³þ¸üбê־λ
  TIM_ITConfig(TIM2,TIM_IT_Update,ENABLE );
    TIM_Cmd(TIM2, ENABLE);
    NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
    NVIC_Init(&NVIC_InitStructure);
最后的计算部分:
void TIM2_IRQHandler(void)
        if (TIM_GetITStatus(TIM2, TIM_IT_Update) != RESET)
             TIM_ClearITPendingBit(TIM2, TIM_IT_Update);
             CAPTURE1=(u32)TIM_GetCounter(TIM3);
        sum+=CAPTURE1;
        count++;
        if(count==4)
         Frequency1=sum/4;//求频率公式F=n/t;这里求了4次的计数平均值,结果是1S的频率
       sum=0;
         count=0;
        TIM_SetCounter(TIM3,0);
airwill 发表于 2015-7-22 20:55 | 显示全部楼层
看看这里, 你自己少了 10倍嘛. 要仔细检查自己的代码哦
643757107 发表于 2015-7-22 21:05 来自手机 | 显示全部楼层
楼上大侠说的挺对,楼主要多练练
598330983 发表于 2015-7-22 22:23 来自手机 | 显示全部楼层
你自己少了 10倍嘛
 楼主| zhshw0614 发表于 2015-7-23 09:29 | 显示全部楼层
这是定时0.1秒,我搞错了,但是我改了扩大10倍,数值就不对了
 楼主| zhshw0614 发表于 2015-7-23 09:31 | 显示全部楼层
你自己少了 10倍嘛
刚才是0.1S,我搞错了,现在是定时1S,
TIM2_TimeBaseStructure.TIM_Period =9999;
测量100K怎么是34456 HZ.大家分析一下,什么问题
 楼主| zhshw0614 发表于 2015-7-23 14:35 | 显示全部楼层
嗯,考虑到16位定时器65536会溢出,我定时250MS,现在测试100K-130K频率误差在8HZ-12HZ,不过每次测量频率变化,测量出来的数值有些不稳定 有些波动4HZ,怎么解决这个问题呢
airwill 发表于 2015-7-23 19:02 | 显示全部楼层
嗯,考虑到16位定时器65536会溢出,我定时250MS,现在测试100K-130K频率误差在8HZ-12HZ,不过每次测量频 ...
测试100K-130K频率误差在8HZ-12HZ  这个精度已经很高了.
1. 你的信号源有那么高的精度吗?
2. 在中断服务的时候, 有没有可能丢失脉冲
 楼主| zhshw0614 发表于 2015-7-24 09:21 | 显示全部楼层
使用函数信号发生器产生的方波,精度没有问题,
在中断中调用计数函数,怎么检查丢失脉冲了呢,这个应该避免不了吧,有延时
734774645 发表于 2015-7-24 12:03 | 显示全部楼层
你自己少了 10倍嘛:lol
598330983 发表于 2015-7-24 12:07 | 显示全部楼层
   TIM2_TimeBaseStruc ...
你可以慢慢调整到那个你需要的位置。。
lefeng 发表于 2015-7-24 12:39 | 显示全部楼层
中断服务中, 可能有丢失脉冲
 楼主| zhshw0614 发表于 2015-7-26 08:37 | 显示全部楼层
中断服务中, 可能有丢失脉冲
那怎么尽量提高精度呢,避免丢失呢
小浣熊 发表于 2015-7-26 18:55 | 显示全部楼层
怎么尽量提高精度呢,避免丢失呢??同问!!
