Error[e104]: Failed to fit all segments into specified ranges. Problem discovered in segment CODE. Unable to place 49 block(s) (0x23ce byte(s) total) in 0x1e3e
byte(s) of memory. The problem occurred while processing the segment placement command "-P(CODE)CODE=E000-FF7F", where at the moment of placement the
available memory ranges were "CODE:e142-ff7f"
这是为毛,然后也不知道哪里写错了。。。
