msp430f149温度pid控制
1558|4
 楼主| dirtwillfly 发表于 2015-7-29 09:51 | 显示全部楼层 |阅读模式
程序框图:
本设计使用高速晶体振荡器,程序如下:
BCSCTL1 &= ~XT2OFF;//打开XT2高频晶体振荡
do
   IFG1 &= ~OFIFG;//清除晶振失败标志
   for (i = 0xFF; i > 0; i--);//等待8MHz晶体起振
   while ((IFG1 & OFIFG));//晶振失效标志仍然存在?
   BCSCTL2 |= SELM_2 + SELS;//MCLK和SMCLK选择高频晶振
PID算法程序:
void PIDCalc(void)
float Rate;//误差变化率
Current_Error =   Set_Temp  - Pre_Temp ;// 当前误差计算
Sum_Error    +=   Current_Error;// 误差积分
Prev_Error    =   Last_Error;// 存储误差更新
Last_Error    =   Current_Error;// 存储误差更新
Rate          =   ( Current_Error - Last_Error )*1000/ Ctrl_Period;
// 当前误差微分
if(Rate>5)//对误差变化率进行限制,锅炉温度不可能变化太大
Rate=5;
if(Rate<-5)
Rate=-5;
    P_OUT = P * Gain * Current_Error  ; /*比例项*/
I_OUT = I * Gain * Sum_Error  ;/*积分项*/
//积分限幅处理
if( I_OUT>PID_I_MAX )  I_OUT = PID_I_MAX;
if( I_OUT<PID_I_MIN )  I_OUT = PID_I_MIN;
if( ( Current_Error <= 2.5 ) && ( Prev_Error <=2.8))
I_OUT=I_OUT * 0.5;
if( (Current_Error <= 0.45 ) && ( Last_Error <=55))
I_OUT=I_OUT * 0.08;
//因为锅炉只能加温不能降温所以一旦超过设定值令积分值为零
if( ( Current_Error <= 0 ) && ( Last_Error <=0 ))
  I_OUT=0;
  //微分延迟输出处理
  D_OUT= ( D_OUT * Sdde_Para + D * Rate * (1-Sdde_Para) )*Gain  ;
  PID_OUT =  P_OUT  +  I_OUT  +  D_OUT ;
  if ( PID_OUT >= PWM_DATA_MAX )  PID_OUT = PWM_DATA_MAX;
  if ( PID_OUT <= PWM_DATA_MIN )  PID_OUT = PWM_DATA_MIN;
  if( Set_Temp - Pre_Temp >=10)
  PID_OUT=16383;
void main()
Device_Init( );
while(1)
LED8_Rollback;//系统运行指示灯
Parameter_Show( );
ADC模数转换程序
char ADC12Init(char n,char channels[],char rep)
if(n>15)
return 0;
ADC12CTL0 = ADC12ON + MSC + SHT0_0 + REFON + REF2_5V;
// 开启ad,参考电压2.5v
ADC12CTL1 = SHP + ADC12SSEL_3;  //Use sampling timer, SMCLK
for(int i = 0;i < n;i++)
if(channels >= 0x80)
return 0;
*(char*)(ADC12MCTL0_ + i) = channels;//每个MCTL设置
*(char*)(ADC12MCTL0_ + n - 1) |= EOS;//序列结束
if(rep != 0)//多次转换
ADC12CTL1 |= CONSEQ_3;
else
ADC12CTL1 |= CONSEQ_1;
ADC12IE = 1<<(n-1);// Enable ADC12IFG.n-1
return 1;
定时器设置程序
void TA_Init(void)
  TACTL=TASSEL0+TACLR;//设定定时器A控制寄存器
  CCTL0=CCIE;//使能中断
  CCR0=3276;//设置CCR0初值,及100毫秒中断一次
  TACTL|=MC0;//计数器加模式
void TimerB_Init(void)
    TBCTL=TBSSEL_1+TBCLR+MC0+ID_3;
    TBCCTL1=OUTMOD_3;
    TBCCR0=16384;//PWM中断周期
    TBCCR1=4000;//PWM低电平时间
    P4DIR|=BIT1;//设置PWMIO口
    P4SEL|=BIT1;
void TimerB_Duty(u16 duty)
    TBCCR1=duty;//PWM低电平时间
异步通讯程序
void UART0_Init(void)
    WDTCTL = WDTPW + WDTHOLD;// Stop WDT
    P3SEL |= 0x30;// P3.4,5 = USART0 TXD/RXD
    ME1 |= UTXE0+URXE0;// Enable USART0 TXD/RXD
    UCTL0 |= CHAR;// 8-bit character
    UTCTL0 |= SSEL0;// UCLK = ACLK
    UBR00 = 0x03;// 32k/9600 - 3.41
    UBR10 = 0x00;
    UMCTL0 = 0x4A;// Modulation
    UCTL0 &= ~SWRST;// Initialize USART state machine
    IE1 |= URXIE0;// 使能USART0的接收中断
void PutChar(uchar data)
    while (!(IFG1 & UTXIFG0));// TX缓存空闲?
     TXBUF0 = data;// 发送数据
void Blank(void)
  PutChar(0x20);
void Newline()
   PutChar(0x0d);//发送一个回车
   PutChar(0x0a);//发送一个换行
void PutString(uchar *ptr)
   while(*ptr != '\0')
     PutChar(*ptr++);
温度拟合程序
float Scale_Conv( u16 Value)
float  Temp1=0,Temp2=0;
//温度拟合(二次函数)
Temp1=Value*A_para;
Temp1=Value*Temp1;
Temp2=Value*B_para;
//当前温度=A*X*X+B*X+C-零漂
return (Temp1+Temp2+C_para+Null_shift);
尤彼卡 发表于 2015-7-29 09:57 | 显示全部楼层
这是用于哪方面的,有没原理图呀,感觉很不错
 楼主| dirtwillfly 发表于 2015-7-29 09:58 | 显示全部楼层
移植一下都可以用
ruogurencheng 发表于 2015-7-29 13:54 | 显示全部楼层
米尔豪斯 发表于 2015-7-30 09:14 | 显示全部楼层
PID算法程序值得借鉴,收藏先
个人签名:欢迎进入TI MCU论坛      21ic TI技术交流1群:61549143(已满),  21ic TI技术交流2群:311421422 我的博客:http://blog.timcu.com/
1199
