[数据转换器-信号链] 模拟设计工程师 Analog Design Engineer【TI官方招聘】
1260|6
 楼主| Dezhouyiqi_TI 发表于 2015-8-5 14:45 | 显示全部楼层 |阅读模式
Job Description
Responsible for the definition, design,  layout, and characterization of high performance linear  voltage regulators, switching voltage regulators,  data converters, power drive  and control, transceivers, active filters, switched  acitor  design, and  battery charging  blocks utilizing  BiCMOS technology  which will be integrated  into a larger  ASIC driving true SoC  applications.    Must have an  understanding of IC  fabrication processes  and  be  able to  design  circuits  that  operate effectively  within  the process parameters. Basic Qualifications
Products cover  a wide  range of  circuit types  allowing a  large breadth  of technical  knowledge to  be gained Designs must  operate in a harsh environment, be  cost effective and tailored specifically  to our customer's application  making creativity skills  essential. Designs can  range from very  small (several hundred components) to  the very large system  on a chip (>  250K components). This  wide size range can require the design to be an individual effort or a part of a design team.
The design  engineer  will need  to team  well  both within  the design  team  as well  as within  a  cross functional team  responsible for the  full development and  ramp to  volume of the  IC. Communication skills are extremely important both within TI and with TI's customers.
Preferred Qualifications & Skills
Analog IC design skills in areas such as Bandgaps, Amps, Comparators, A2D's, D2A's, Linear Voltage Regulators, Switching Voltage Regulators, Switched Capacitor, Active Filters, etc. Process and Device Physics knowledge are  a strong plus.  Software tools such  as Cadence Analog  Artist/Virtuoso/Silicon Ensemble, Synopsys, SPICE, etc. Strong layout knowledge and parasitic component understanding.
The  following  areas  of  experience   are  helpful:  BiCMOS/CMOS  knowledge,  High  Voltage/High Current  design, ESD,  Sensor,  Wafer  fab and  Process,  Yield enhancement,  Modelling,  ESD,  motor control, and RF design tools.
 楼主| Dezhouyiqi_TI 发表于 2015-8-5 14:49 | 显示全部楼层
TI官方招聘网站 HTTP(小写)://career.ti.com
xyz549040622 发表于 2015-8-6 07:59 | 显示全部楼层
谷歌翻译的结果如下:
地点:上海研发,中国
职位描述
负责定义,设计,布局,以及高性能线性稳压器特性,开关稳压器,数据转换器,电源驱动和控制,收发器,有源滤波器,开关acitor设计,并利用BiCMOS技术的电池充电模块将被整合到一个更大的ASIC驱动真正的SoC应用。必须有IC制造过程的理解,并能够设计出的工艺参数内有效地工作的电路。基本条件
产品涵盖以中获得了广泛的电路类型的允许的技术知识大幅面设计必须工作在恶劣的环境下,具有成本效益,并专门为我们的客户的应用使得创造性的技能是必不可少的。设计范围可以从非常小(几百组件)到非常大的系统芯片(> 250K组件)上。这种宽尺寸范围可以要求设计是一个个人的努力或一个设计团队的一部分。
设计工程师需要在设计团队以及负责内部为全面发展的一个跨部门的团队以及团队都并减速IC的量。沟通能力是非常重要的两个内TI和TI的客户。
较好的资格和技能
在诸如带隙,放大器,比较器,A2D的,D2A的,线性稳压器,开关稳压器,开关电容,有源滤波器等领域模拟集成电路设计技能工艺和器件物理知识有较强的加分。软件工具,如Cadence模拟艺术家/炫技/硅乐团,新思科技,SPICE等强大的布局知识和寄生元件的理解。
经历了以下几个方面是有帮助的:的BiCMOS / CMOS知识,高电压/高电流的设计,ESD,传感器,晶圆代工厂和工艺,良率提升,建模,ESD,电机控制和RF设计工具。
 楼主| Dezhouyiqi_TI 发表于 2015-8-6 13:10 | 显示全部楼层
谷歌翻译的结果如下:
地点:上海研发,中国
感谢您对TI的关注!
 楼主| Dezhouyiqi_TI 发表于 2015-8-10 11:43 | 显示全部楼层
[em:2]
如欲了解TI的更多信息,敬请登陆全球网站/ti.com/,或中文网站ti.com.cn/
tongbu2015 发表于 2015-8-10 22:32 | 显示全部楼层
谷歌翻译的结果如下:
地点:上海研发,中国
这个看着挺要求高的,首先得沟通能力强才行的。
迪卡 发表于 2015-9-29 17:46 | 显示全部楼层
要求比较高啊
