- ;2.24设计,
- S2 BIT P1.2
- S6 BIT P1.3
- S4 BIT P1.4
- S5 BIT P1.5
- S3 BIT P1.6
- S1 BIT P1.7
- BH BIT P3.7
- WDG BIT P1.1
- CMP BIT P1.0
- FOR BIT P3.1
- BACK BIT P3.0
- PWM BIT 08H
- FLAG BIT 09H ;0-FACT SPEED;1-GIV SPEED
- FLAG0 BIT 0AH ;0-启动定时器,1-获取给定值
- FLAG1 BIT 0BH ;0-启动定时器,1-获取实际转速
- OPEN_FLAG BIT 0CH
- INT1_FLAG BIT 0DH
- H_TIME EQU 31H
- L_TIME EQU 32H
- SWITCH_TEMP EQU 33H
- GIVEN_H EQU 34H ;给定转速
- GIVEN_L EQU 35H
- SPEED_H EQU 36H ;电机实际转速
- SPEED_L EQU 37H
- INTT0 EQU 38H
- INTT1 EQU 39H
- ORG 0000H ;BEGINE OF CODE
- AJMP MAIN ;JUMP TO MAIN PROGRAM
- ORG 0003H ;INT0 INTERRUPT
- AJMP INT0_INT
- ORG 000BH ;T0 INTERRUPT
- AJMP T0_INT
- ORG 0013H ;INT1 INTERRUPT
- AJMP INT1_INT
- ORG 001BH ;T1 INTERRUPT
- AJMP T1_INT
- ;_____________________________________________________________________
- ORG 0100H
- MAIN:
- MOV P3,#11111111B ;INITIALIZATION
- MOV P1,#11111101B ;TO CLOSE DRIVE SIGNAL
- MOV SP,#60H ;SET STACK POINTER
- CLR OPEN_FLAG
- MOV H_TIME,#206 ;PWM=60%,此初值可以设定,保证电机正确启动。
- MOV L_TIME,#56
- MOV TH1,#206
- MOV TL1,#56
- MOV TMOD,#00100001B ;T1 DEFINE TIMER1 8 BIT AUTO RELOAD MODE
- CLR FLAG
- CLR FLAG0 ;AND T0 16 BIT TIMER
- SETB EA ;TO PERMIT CHIEF INTERRUPT
- SETB ET1
- SETB TR1
- SETB IT0 ;INT0 AND INT1 UP-DOWN CREATE
- SETB IT1
- SETB EX0 ;TO PERMIT INT0 AND INT1
- SETB EX1
- POWJUDGE:
- CPL WDG
- JB CMP,POWJUDGE ;0 POW>GIV,1 POW<GIV
- JNB FOR, FORWARDRUN
- JNB BACK,BACKWARDRUN
- SJMP POWJUDGE
- ;______________________________________________________________________________________
- FORWARDRUN:
- MOV P3,#11111111B
- JNB BH,STOP ;TO CHECK BH SIGNAL
- LCALL JUDGE
- MOV A,H_TIME
- CJNE A,#240,FORLOOP1
- SETB OPEN_FLAG
- LCALL FORFULL
- SJMP POWJUDGE
- FORLOOP1:
- CLR OPEN_FLAG
- LCALL FORWARD
- SJMP POWJUDGE
- STOP:
- CLR EA
- SETB P1.0
- LCALL DELAY
- CLR P1.0
- SJMP STOP
- BACKWARDRUN:
- MOV P3,#11111111B
- LCALL JUDGE
- MOV A,H_TIME
- CJNE A,#240,BACKLOOP1
- SETB OPEN_FLAG
- LCALL BACKFULL
- SJMP POWJUDGE
- BACKLOOP1:
- CLR OPEN_FLAG
- LCALL BACKWORD
- SJMP POWJUDGE
- INT0_INT:
- PUSH PSW
- PUSH ACC
- JB FLAG,END_INT0 ;FLAG0=0,获取给定转速,FLAG=1跳出中断。
- JNB FLAG0,GET_GIV ;FLAG1=0,跳转至启动定时器,FLAG1=1,停止计数,获取给定
- CLR TR0
- MOV GIVEN_H,TH0
- MOV GIVEN_L,TL0
- LOOP2:
- CPL FLAG
- SJMP ENDINT0
- GET_GIV:
- MOV TH0,#0
- MOV TL0,#0
- SETB TR0
- ENDINT0:
- CPL FLAG0
- END_INT0:
- POP ACC
- POP PSW
- RETI
- INT1_INT:
- PUSH PSW
- PUSH ACC
- JNB FLAG,END_INT1
- JNB FLAG1,GET_FACT
- CLR TR0
- MOV SPEED_H,TH0
- MOV SPEED_L,TL0
- CPL FLAG
- SETB INT1_FLAG
- SJMP ENDINT1
- GET_FACT:
- MOV TH0,#0
- MOV TL0,#0
- SETB TR0
- NOP
- ENDINT1:
- CPL FLAG1
- END_INT1:
- POP ACC
- POP PSW
- RETI
- T0_INT:
- RETI
- T1_INT:
- CPL PWM ;GENERATE PWM
- JB OPEN_FLAG,END_T1
- JB PWM,PWM_H ;PWM=1,OUTPUT SWITCH_TEMP
- MOV P1,#0FFH
- MOV TH1,L_TIME
- SJMP END_T1
- PWM_H:
- MOV P1,SWITCH_TEMP
- MOV TH1,H_TIME
- END_T1:
- RETI
- FORWARD:
- FORWARD_101:
- MOV A,P3
- ANL A,#00111000B
- CJNE A,#00101000B,FORWARD_100
- MOV SWITCH_TEMP,#01110111B
- SJMP FORWARDHALL_END
- FORWARD_100:
- CJNE A,#00001000B,FORWARD_110
- MOV SWITCH_TEMP,#01111011B
- FORWARD_110:
- CJNE A,#00011000B,FORWARD_010
- MOV SWITCH_TEMP,#10111011B
- FORWARD_010:
- CJNE A,#00010000B,FORWARD_011
- MOV SWITCH_TEMP,#10101111B
- FORWARD_011:
- CJNE A,#00110000B,FORWARD_001
- MOV SWITCH_TEMP,#11001111B
- FORWARD_001:
- MOV SWITCH_TEMP,#11010111B
- FORWARDHALL_END:
- RET
- FORFULL:
- FORFULL_101:
- MOV A,P3
- ANL A,#00111000B
- CJNE A,#00101000B,FORFULL_100
- MOV P1,#01110111B
- SJMP FORFULLHALL_END
- FORFULL_100:
- CJNE A,#00001000B,FORFULL_110
- MOV P1,#01111011B
- FORFULL_110:
- CJNE A,#00011000B,FORFULL_010
- MOV P1,#10111011B
- FORFULL_010:
- CJNE A,#00010000B,FORFULL_011
- MOV P1,#10101111B
- FORFULL_011:
- CJNE A,#00110000B,FORFULL_001
- MOV P1,#11001111B
- FORFULL_001:
- MOV P1,#11010111B
- FORFULLHALL_END:
- RET
- BACKWORD:
- BWHETHER_101:
- MOV A,P3
- ANL A,#00111000B
- CJNE A,#00101000B,BWHETHER_100
- SJMP BHALL_END
- BWHETHER_100:
- CJNE A,#00001000B,BWHETHER_110
- SJMP BHALL_END
- BWHETHER_110:
- CJNE A,#00011000B,BWHETHER_010
- SJMP BHALL_END
- BWHETHER_010:
- CJNE A,#00010000B,BWHETHER_011
- SJMP BHALL_END
- BWHETHER_011:
- CJNE A,#00110000B,BWHETHER_001
- SJMP BHALL_END
- BWHETHER_001:
- BHALL_END:
- RET
- BACKFULL:
- BACKFULL_101:
- MOV A,P3
- ANL A,#00111000B
- CJNE A,#00101000B,BACKFULL_100
- MOV P1,#10101111B
- SJMP BACKFULLHALL_END
- BACKFULL_100:
- CJNE A,#00001000B,BACKFULL_110
- MOV P1,#11001111B
- BACKFULL_110:
- CJNE A,#00011000B,BACKFULL_010
- MOV P1,#11010111B
- BACKFULL_010:
- CJNE A,#00010000B,BACKFULL_011
- MOV P1,#01110111B
- BACKFULL_011:
- CJNE A,#00110000B,BACKFULL_001
- MOV P1,#01111011B
- BACKFULL_001:
- MOV P1,#10111011B
- BACKFULLHALL_END:
- RET
- JUDGE:
- JNB INT1_FLAG,END_JUDGE
- CLR INT1_FLAG
- MOV A,SPEED_H
- CJNE A,GIVEN_H,JUDGE0
- SJMP RE_JUDGE
- RE_JUDGE:
- MOV A,SPEED_L ;A>GIVEN_L,C=0,A<GIVEN,C=1
- CJNE A,GIVEN_L,JUDGE0
- SJMP END_JUDGE
- JUDGE0:
- JC DOWNSPEED ;C=1,跳转
- SJMP UPSPEED
- DOWNSPEED:
- MOV A,L_TIME
- CJNE A,#240,DEC_SPEED ;此处设定占空比的最小值,可以通过实验获取
- SJMP END_JUDGE
- UPSPEED:
- MOV A,H_TIME
- CJNE A,#240,INC_SPEED ;此处设定占空比的最大值
- SJMP END_JUDGE
- INC_SPEED:
- INC H_TIME
- DEC L_TIME
- SJMP END_JUDGE
- DEC_SPEED:
- DEC H_TIME
- INC L_TIME
- END_JUDGE:
- RET
- DELAY:
- MOV R7,#40
- DEL1:
- MOV R6,#0FFH
- DEL2:
- MOV R5,#80H
- KONG:
- NOP
- DJNZ R5,$
- DJNZ R6,DEL2
- DJNZ R7,DEL1
- RET
- END
