新手学习用STM32, ADC问题请教
2844|3
 楼主| fish2bear 发表于 2008-11-1 10:01 | 显示全部楼层 |阅读模式
STM32F101运行正常 (PB0~PB8 I/O能输入输出,vREF+=3.3v, VREF-=0V), 想编程对PC1端口的模拟输入进行读取 (万用表量得端口的输入电压为1.2V),程序如下所示,但读到的DataValue值总是0x0000;
大侠们帮忙看看问题出在那。
u16 DataValue;
/* Configure PC.01 (ADC Channel11) as analog input -------------------------*/
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
/* ADC1 configuration ------------------------------------------------------*/
  ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
  ADC_InitStructure.ADC_ScanConvMode = DISABLE;
  ADC_InitStructure.ADC_ContinuousConvMode = DISABLE;
  ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
  ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
  ADC_InitStructure.ADC_NbrOfChannel = 1;
  ADC_Init(ADC1, &ADC_InitStructure);
/* ADC1 regular channel1 configuration */
  ADC_RegularChannelConfig(ADC1, ADC_Channel_11, 1, ADC_SampleTime_55Cycles5);
/* Enable ADC1 */
  ADC_Cmd(ADC1, ENABLE);
/* Enable ADC1 reset calibaration register */
  ADC_ResetCalibration(ADC1);
/* Check the end of ADC1 reset calibration register */
  while(ADC_GetResetCalibrationStatus(ADC1));
/* Start ADC1 calibaration */
  ADC_StartCalibration(ADC1);
/* Check the end of ADC1 calibration */
  while(ADC_GetCalibrationStatus(ADC1));
/* Start ADC1 Software Conversion */
  ADC_SoftwareStartConvCmd(ADC1, ENABLE);
DataValue = ADC_GetConversionValue(ADC1);
 楼主| fish2bear 发表于 2008-11-1 13:26 | 显示全部楼层
可能是时钟问题吗?
上面的程序是从stm提供的例程修改而来的
我用的是内部时钟,例程中好像是基于外部时钟
我是不是应该修改RCC_Configuration()对应的时钟设定?
香水城 发表于 2008-11-1 17:37 | 显示全部楼层
为什么不等待转换结束?
 楼主| fish2bear 发表于 2008-11-2 01:44 | 显示全部楼层
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC
我找到了两个问题
1. RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_ADC1, ENABLE);
2. 等待转换结束
谢谢香主
