stm32的i2c
2960|2
 楼主| lonely8122 发表于 2009-5-13 15:02 | 显示全部楼层 |阅读模式
大家有没有觉得STM32的I2C有比较严重的问题?SR1和SR2的值经常莫名的变,还有连续读写也会有问题,这里说的连续读写不是指24cxx的页读写,而是说,我如果先读10个字节,然后发停止位,后面跟着又读10个字节,就会失败了。请有使用经验的人指点,谢谢,下面是我的读写24c256的程序,请大家帮忙分析:
*    函数名:read_24cxx
*    参数:读缓冲区:read_buff,读操作其始地址:read_address 读字节数量:num
*    返回:操作的结果
INT8U read_24cxx(INT8U *read_buff , INT16U read_address, INT8U length)
  INT32U i, wait_timer;
  INT8U address_8bit;
  if((I2C1->SR1&0x0040)!=0) i=I2C1->DR;  //清除SR1里的RXNE位,这一位经常无故置位
  wait_timer=0xffff;
  // Send I2C1 START condition
  I2C_GenerateSTART(I2C1, ENABLE);
  // Test on I2C1 EV5 and clear it
  while((!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_MODE_SELECT))&&(wait_timer))  wait_timer--;
  if(wait_timer==0) return TIME_OUT;
  wait_timer=0xffff;
  // Send I2C2 slave Address for write
  I2C_Send7bitAddress(I2C1, __24C_SLAVE1_ADDRESS7, I2C_Direction_Transmitter);
  // Test on I2C1 EV6 and clear it
  while((!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED))&&(wait_timer))  wait_timer--;
  wait_timer=0xffff;
  address_8bit = (INT8U)(read_address>>8);
  I2C_SendData(I2C1, address_8bit);       //send the writing address.
  while((!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED))&&(wait_timer))  wait_timer--;
  wait_timer=0xffff;
  address_8bit = (INT8U)(read_address);
  wait_timer=0xffff;
  wait_timer=0xffff;
  I2C_Send7bitAddress(I2C1, __24C_SLAVE1_ADDRESS7, I2C_Direction_Receiver);
  while((!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED))&&(wait_timer))  wait_timer--;
    for(i=0;i<length;i++)
    wait_timer=0xffff;
    while((!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_RECEIVED))&&(wait_timer)) wait_timer--;
    if(wait_timer==0) break;
    else
      read_buff=I2C_ReceiveData(I2C1);
    // Send I2C1 STOP Condition
 I2C_GenerateSTOP(I2C1, ENABLE);
  else  return NO_ERROR;
*    函数名:write_24cxx
*    参数:写缓冲区:write_buff,读操作其始地址:write_address 读字节数量:num(<=64)
*    返回:操作的结果
INT8U write_24cxx(INT8U * write_buff, INT16U write_address, INT8U length)
  INT8U address_8bit;
  if(length>64)  return  QUANTITY_OVERRUN;   //写入数量超过一页(64byte)
  EN_24C_WRITE;                   //关闭写保护
  I2C_EE_WaitEepromStandbyState();    //等待E2准备好
  wait_timer=0xffff;
  if(wait_timer==0)
    DIS_24C_WRITE;       //恢复写保护
    return TIME_OUT;
  wait_timer=0xffff;
  if(wait_timer==0)
    DIS_24C_WRITE;
    return TIME_OUT;
  wait_timer=0xffff;
  address_8bit = (INT8U)(write_address>>8);
  if(wait_timer==0)
    DIS_24C_WRITE;
    return TIME_OUT;
  wait_timer=0xffff;
  address_8bit = (INT8U)(write_address);
  if(wait_timer==0)
    DIS_24C_WRITE;
    return TIME_OUT;
    wait_timer=0xffff;
    I2C_SendData(I2C1, write_buff);
  OSTimeDly(5);           //延时等待器件内部写操作结束
lut1lut 发表于 2009-5-13 17:22 | 显示全部楼层
置顶帖子有个I2C读写的可以供参考
那个查询方式的,很多人用过了,你可以先比较一下,找找自己的问题。
dragonbch 发表于 2009-12-29 13:35 | 显示全部楼层
初始化后第一次是主写,可是就是就是在EV5那个循环内出不来,咋整呢?高手指点,我都急死了。
