[DemoCode下载] 在M451中,使用U盘更新APROM
3210|12
 楼主| a_ziliu 发表于 2015-9-24 11:32 | 显示全部楼层 |阅读模式
感谢CYTseng提供。
CONFIG请设成BOOT IN "LDROM with IAP".
使用在KEIL编译後下载代码至M451即可。在U盘中,要更新的BIN档请改成AP.BIN即可。
M451SeriesBSP_CMSIS_v3.00.005 - HOST MASS ISP.zip (1.28 MB, 下载次数: 120)
yiyigirl2014 发表于 2015-9-24 21:18 | 显示全部楼层
U盘的接口程序如何写的啊,我要学学了,这个好神奇的。
598330983 发表于 2015-9-26 11:09 | 显示全部楼层
IAP程序先读取U盘数据,然后确认固件后,读取写入到Flash
mintspring 发表于 2015-9-28 17:02 来自手机 | 显示全部楼层
有了这个可以拷贝进去就行了
734774645 发表于 2015-9-29 15:32 来自手机 | 显示全部楼层
不知道原理是什么,要不停扫描优盘内容吗?
小猫爱吃鱼 发表于 2015-9-29 16:19 | 显示全部楼层
用U盘更新APROM,是一个很不错的想法啊
minier 发表于 2015-10-3 13:28 | 显示全部楼层
NXP的ARM就是这样
weizhiwuxian 发表于 2015-12-23 14:59 | 显示全部楼层
是启动设置成LDROM 含IAP功能吧??然后把程序烧写到APROM吧?烧写到LDROM说程序太大,
U盘更目录下有个IP.bin程序.插U盘上电后,观看串口输出的信息,无任何输出.
再把启动塞罕至成APROM,重启后,可以看到串口输出
UDetecting USB disk...
Device connected.
Port reset OK.
USB device enabled (Full-speed).
[Device Descriptor]
  Length              = 18
  DescriptorType      = 01
  USB version         = 2.00
  Vendor:Product      = 1043:8012
  MaxPacketSize0      = 64
  NumConfigurations   = 1
  Device version      = 1.00
  Device Class:SubClass:Protocol = 00:00:00
[Configuration Descriptor]
  Length              =  9
  DescriptorType      = 02
  wTotalLength        = 32
  bNumInterfaces      = 1
  bConfigurationValue = 1
  iConfiguration      = 0
  bmAttributes        = 0x80
  MaxPower            = 50
[Interface Descriptor]
  Length              =  9
  DescriptorType      = 04
  bInterfaceNumber    = 0
  bAlternateSetting   = 0
  bNumEndpoints       = 2
  bInterfaceClass     = 0x08
  bInterfaceSubClass  = 0x06
  bInterfaceProtocol  = 0x50
  iInterface          = 0
[Endoint Descriptor]
  Length              =  7
  DescriptorType      = 05
  bEndpointAddress    = 0x81
  bmAttributes        = 0x02
  wMaxPacketSize      = 64
  bInterval           = 0
  bRefresh            = 7
  bSynchAddress       = 5
  Length              =  7
  DescriptorType      = 05
  bEndpointAddress    = 0x02
  bmAttributes        = 0x02
  wMaxPacketSize      = 64
  bInterval           = 0
  bRefresh            = 0
  bSynchAddress       = 0
USB Mass Storage device found.
Max lun is 0
******* Read lun 0 ******
INQUIRY...
INQUIRY command success.
TEST_UNIT_READY...
CSW status error.
REQUEST_SENSE...
REQUEST_SENSE command success.
READ CAPACITY ==>
USB disk found: size=2046 MB, uTotalSectorN=4190208
g_disk_lun = 0
rc=0
Firmware AP.BIN file not found.
Data file data.bin not found.
Will branch to user application...
In Hard Fault Handler
r0  = 0x18
r1  = 0x20026
r2  = 0x2e
r3  = 0xa
r12 = 0x0
lr  = 0x201
pc  = 0x790
psr = 0x21000000
最终都没有更新,是什么原因?????
weizhiwuxian 发表于 2015-12-23 15:26 | 显示全部楼层
换了个U盘后
INQUIRY...
TEST_UNIT_READY...
CSW status error.
REQUEST_SENSE...
READ CAPACITY ==>
USB disk found: size=1911 MB, uTotalSectorN=3915775
g_disk_lun = 0
rc=0
----A 2015/12/22 16:23      5760  AP.BIN
   1 File(s),      5760 bytes total
   0 Dir(s)Firmare file found, start update firmware...
Program page 0x0, count=2048
Verify failed at 0x0, read:0x0, epect:0x200004f8
r0  = 0x18
r1  = 0x20026
r2  = 0x2e
r3  = 0xa
r12 = 0x1
lr  = 0x201
pc  = 0x790
psr = 0x21000000
734774645 发表于 2016-1-27 15:53 | 显示全部楼层
neeringstu 发表于 2016-1-28 09:01 | 显示全部楼层
这个是不是就是dfu啊?
玛尼玛尼哄 发表于 2019-8-14 22:54 | 显示全部楼层
config是在哪儿
wanduzi 发表于 2019-8-14 22:58 | 显示全部楼层
U盘也可以,这个方法比较好,不需要单独搞烧录软件了。
