[Atmel] The Eleven is an open source desktop 3D printer
791|0
 楼主| ddllxxrr 发表于 2015-10-9 20:48 | 显示全部楼层 |阅读模式
Developed by Canadian startup ISG3D, the Eleven is a hackable desktop 3D printer with an open-air design. Boasting an impressive build envelope of 22cm x 40cm x 40cm, the machine is capable of creating decently-sized objects in a variety of filaments like PLA, ABS, Nylon and NinjaFlex.Inspired by the Prusa i3 and based on RepRap mechanics, the newly-revealed gadget was built specifically with Makers in mind, not to mention hackers thanks to its open source nature. Its stripped down composition provides users with the ability to make improvements of their own, and customize it to their liking.What’s more, the Eleven features a sleek open-air body, resembling that of the Prusa, and can easily fit on any desktop or workbench without taking up too much space. The printer is equipped with a heated bed, a user-friendly LCD screen for menu navigation, a resolution of up to 100 microns, and can precisely extrude layers as thin as 0.1mm. With a print speed of up to 100mm/second, objects can be spit out relatively quickly with a great degree of accuracy. In terms of hardware, the desktop device is driven by the mighty combination of an Arduino Mega (ATmega2560) and RAMPS 1.4 along with a set of NEMA 17 stepper motors, and runs Repetier Host software.The Eleven’s simple design makes it convenient to swap out filament spools, accessible for quick repairs or tune-ups, and pretty portable with a weight of roughly 30 pounds. Meanwhile, its frame is comprised mostly of aluminum, which offers enhanced stability and reliability during a print job. Plus, to give the gadget a little personality, the team has even added a series of LEDs that lets users choose from up to 15 colors and for different effects.
  • Printer size: 33cm x 60cm x 60cm
  • Build volume: 22cm x 40cm x 40cm
  • Layer resolution: <100microns
  • Nozzle: 0.4mm
  • Filament: PLA, ABS, Nylon (1.75mm)
  • Print speed: 100mm/s
  • Power supply: 240W
  • Connectivity: USB
  • OS: Windows, Mac, Linux
  • Software: Repetier
Sound like a 3D printer you’d like to have in your Makerspace? Head over to its Kickstarter page, where ISG3D is currently seeking $8,402. The first batch of units is expected to ship in February 2016.
个人签名:http://shop34182318.taobao.com/ http://shop562064536.taobao.com
2404
