请教各位专家,allegro导入cadence的网表文件,出现如下错误:
#2 ERROR(SPMHNI-176): Device library error detected.
ERROR(SPMHNI-190): Device problem 'Y-SMD_XTAL_SMD_3D2X2D5_'. Package property error: 'VALUE'='贴片晶振-25MHZ-10PPM-20PF-3225-工业级-40℃-+85℃'. Illegal character(s) present in the name or value..
ERROR(SPMHNI-170): Device 'Y-SMD_XTAL_SMD_3D2X2D5_' has library errors. Unable to transfer to Allegro.
#3 ERROR(SPMHNI-176): Device library error detected.
ERROR(SPMHNI-190): Device problem 'DP_0_FIL2012_SM_-RFDI'. Package property error: 'VALUE'='贴片双工器-RFDIP2012050L5T'. Illegal character(s) present in the name or value..
现在通过修改原理图的器件value属性为非中文可以解决,但是器件太多了,无法一一修改,请问还有其他办法可以解决不?比如allegro导入网表时是否可以设置不检查value属性之类的,如何设置呢?我用的cadence为16.6的
谢谢!
