香版,有个问题实在是搞不定想问下,现在用的是103VC的芯片,用FSMC来驱动类似ST的DEMO里面LCD屏的方式来驱动一颗芯片,但是关于时序和波形有点问题想请教下,使用的STM32的FSMC_NE1做芯片的CS,FSMC_NWE,FSMC_NOE作为芯片的读写脚,D0-D7接芯片的HAD0-HAD7芯片的数据口来实现读写,VC的芯片的A16来作为芯片的ALE脚,但是根据例子配置的程序,这个A16一直没有信号输出,其他脚都有信号,还有就是FSMC能否实现这个芯片的读写时序?谢谢了,下面是配置代码和芯片的时序
/* Enable FSMC, GPIOD, GPIOE and AFIO clocks */
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_FSMC, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOE |
RCC_APB2Periph_AFIO, ENABLE);
/* Set PD.00(D2), PD.01(D3), PD.04(NOE), PD.05(NWE),PD.14(D0), PD.15(D1) as alternate
function push pull */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_4 | GPIO_Pin_5 |
GPIO_Pin_14 | GPIO_Pin_15;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_Init(GPIOD, &GPIO_InitStructure);
/* Set PE.07(D4), PE.08(D5), PE.09(D6), PE.10(D7)as alternate function push pull */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 ;
GPIO_Init(GPIOE, &GPIO_InitStructure);
/* Set PD7(NE1 (LCD/CS)) as alternate function push pull - CE3(LCD /CS) */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
/* Set PD.11(A16 (RS)) as alternate function push pull */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
FSMC_NORSRAMInitTypeDef FSMC_NORSRAMInitStructure;
FSMC_NORSRAMTimingInitTypeDef p;
/*-- FSMC Configuration ------------------------------------------------------*/
/* FSMC_Bank1_NORSRAM1 timing configuration */
p.FSMC_AddressSetupTime = 0;
p.FSMC_AddressHoldTime =0;
p.FSMC_DataSetupTime =3;
p.FSMC_BusTurnAroundDuration = 0;
p.FSMC_CLKDivision = 0;
p.FSMC_DataLatency = 0;
p.FSMC_AccessMode = FSMC_AccessMode_A;
/* FSMC_Bank1_NORSRAM1 configured as follows:
- Data/Address MUX = Disable
- Memory Type = SRAM
- Data Width = 8bit
- Write Operation = Enable
- Extended Mode = Disable
- Asynchronous Wait = Disable */
FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM1;
FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable;
FSMC_NORSRAMInitStructure.FSMC_MemoryType = FSMC_MemoryType_SRAM;
FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_8b;
FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode = FSMC_BurstAccessMode_Disable;
FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low;
FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable;
FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState;
FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable;
FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Disable;
FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Disable;
FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable;
FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &p;
FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &p;
FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure);
/* Enable FSMC_Bank1_NORSRAM1 */
FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM1, ENABLE);
typedef struct
vu16 LCD_Addr;
vu16 LCD_Data;
} LCD_TypeDef;
/* LCD is connected to the FSMC_Bank1_NOR/SRAM1 and NE1 is used as ship select signal */
#define LCD_BASE ((u32)(0x60000000 | 0x00020000))
#define LCD ((LCD_TypeDef *) LCD_BASE) |
