[Atmel] 8岁小孩的作品自叹不如
1191|4
 楼主| ddllxxrr 发表于 2015-12-10 17:57 | 显示全部楼层 |阅读模式
AN, TI, TE, ST, ui
8岁的小创客Omkar Govil-Nair创造了Atmel | SMART SAM D20为核心,采用OLED 显示屏, LiPo 电池蓄能的适合孩子的手表。 这款手表不但能看时间,安装各种小游戏。未来的设计还能测量温度,大气压,还有指南针功能。小创客说了,这是一个可以自己设计自己喜欢的程序的手表。
Do you recall what you were doing back in the summer of fourth grade? Chances are you weren’t creating a programmable, Arduino-based smartwatch like eight-year-old Maker Omkar Govil-Nair, let alone starting your own business.
The O Watch is built around an Arduino Zero (Atmel | SMART SAM D21) module and packs quite the punch when it comes to portable computing. Not only can it tell time, the wearable device can run a wide range of games and applications. For instance, the smartwatch can calculate the value of Pi, play a recognizable version of “Flappy Bird,” “Pac-Man” and “Rock, Paper, Scissors,” and collect measurements in science experiments, among many other things.
Now live on Kickstarter, the O Watch will come in two different models: a base kit and a smartwatch kit. The first is comprised of a SAMD21G18A based programmer board along with a mini color OLED screen, a LiPo battery, a 3D-printed case, and a paracord available in four colors (orange, yellow, pink and blue). Meanwhile, the latter features all of that plus a sensor board equipped with a Honeywell three-axis compass, a Silicon Labs temperature and humidity sensor, and a Bosch barometric pressure sensor.
To bring his idea to life, Govil-Nair has partnered with TinyCircuits for the design and manufacture of the watch’s electronic parts. Helping to reduce the gadget’s inner workings and thickness, TinyCircuits developed a new Arduino module with a color OLED screen, microUSB programmer and charger, all rolled into one board. The O Watch is driven by the highly-popular TinyDuino platform, while its integrated microUSB port is used for both charging and uploading programs.
“Since it’s a fully Arduino-compatible product in a tiny package, you can do a lot more – pretty much anything that is possible using a regular Arduino board and a color screen,” he explains.
What’s truly exciting about this project is that its programmability opens the door for young Makers to explore their imagination, enabling Arduino lovers of all ages to devise games and apps of their own that can be worn around the wrist.
Interestingly enough, Govil-Nair was inspired “to make his own product” after meeting our good friend and fellow whiz-kid Quin Etnyre at Maker Faire two years ago. And it looks like he’s well on his way to following in the footsteps of Etnyre with a successful crowdfunding campaign of his own. The O Watch is currently seeking $15,000 on Kickstarter and expected to begin shipping in February 2016.
We can’t wait to see the wearable on display at the World Maker Faire in New York next month. Until then, ‘watch’ it in action below!
wsnsyy 发表于 2015-12-11 10:39 | 显示全部楼层
歪果仁怎么都这么厉害
ningling_21 发表于 2015-12-11 11:41 | 显示全部楼层
歪果仁怎么都这么厉害
中果仁就不厉害了?
 楼主| ddllxxrr 发表于 2015-12-11 12:17 | 显示全部楼层
歪果仁,中果仁,谁搞出东东,谁历害
lizhuang_1 发表于 2015-12-11 15:36 | 显示全部楼层
小朋友很有天赋啊!
个人签名:http://shop34182318.taobao.com/ http://shop562064536.taobao.com
2404
