[CPLD] ATF1504AS,Found wrong device(s) in hardware
892|0
 楼主| 13123124 发表于 2015-12-23 08:36 | 显示全部楼层 |阅读模式
用atmisp通过byteblaster2向ATF1504AS编写程序,结果ATMISP报错,错误信息如下:Found wrong device(s) in hardware。在下查了查帮助文档上的内容,出现这个错误为:The devices specified in the ATMISP chain file do not match the actual devices found in the JTAG hardware chain. At the beginning of a JTAG programming process, ATMISP will read the device IDs from all of the devices in the JTAG chain and then compare them with the expected device IDs。
这个该如何去解决,有知道的大神吗,赐教一下好吗
