Dear All,<br /><br />We are pleased to announce that IAR Embedded Workbench for ColdFire V1.10 is now released and available for download from the FTP-server as:<br /><br /> <br />ftp://mercury.iar.se/pub2/CD-EWCF-110-5200.zip<br /><br /> <br /><br />With this release, IAR Embedded Workbench for ColdFire is added to the IAR product portfolio.<br /><br />Highlights<br />· Modular and extensible IDE <br /><br />o A seamlessly integrated environment for building and debugging embedded applications <br /><br />o Powerful project management allowing multiple projects in one workspace <br /><br />o Hierarchical project representation <br /><br />o Dockable and floating windows management <br /><br />o Smart source browser <br /><br />o Feature-rich editor with code templates and multi-byte support <br /><br />o Tool options configurable on global, group of source files, or individual source files level <br /><br />o Flexible project building via batch build, pre/post-build or custom build with access to external tools in the build process. <br /><br />o Integration with source code control systems <br /><br />o Extensive device support with ready-made header files, device description files and linker command files <br /><br />· Highly optimizing C/C++ compiler <br /><br />o Support for C, EC++ and extended EC++ including templates, namespace, standard template library (STL) etc. <br /><br />o MISRA C checker <br /><br />o Support for ColdFire V1 and V2 cores <br /><br />o Language extensions for embedded applications with target-specific support, <br />- Extended keywords for data/functions defining and declaring with memory/type attributers<br />- Pragma directives for controlling the compiler's behavior, such as how it allocates memory<br />- Intrinsic functions for direct access in C source to low-level processor operations <br /><br />o 32- and 64-bit floating-point types in standard IEEE format <br /><br />o Multiple levels of optimizations on code size and execution speed allowing different transformations enabled, such as function inlining, loop unrolling etc. <br /><br />o Advanced global and target-specific optimizer generating compact and stable code <br /><br />· State-of-the-art C-SPY® debugger <br /><br />o Complex code and data breakpoints <br /><br />o Very fine granularity execution control (function call-level stepping) <br /><br />o Stack window to monitor the memory consumption and integrity of the stack <br /><br />o Complete support for stack unwinding even at high optimization levels <br /><br />o Profiling and code coverage performance analysis tools <br /><br />o Trace utility with expressions to examine the execution history <br /><br />o Versatile monitoring of registers, structures, call chain, locals, global variables and peripheral registers <br /><br />o Smart STL container display in the Watch window <br /><br />o Symbolic memory window and static watch window <br /><br />o True editing while debugging <br /><br />o Drag and drop <br /><br />o RTOS-aware debugging with built-in plugin for OSEK Run Time Interface (ORTI), embOS and uCOS-II.<br /><br />· C-SPY target system support <br /><br />o Simulator<br />- Instruction-level simulation<br />- Memory configuration and validation<br />- Interrupt simulation<br />- Peripheral simulation, using the debugger macro system in conjunction with immediate breakpoints <br /><br />o P&E USB Multilink, Cyclone Pro and Cyclone Max BDM debugger. <br /><br />o J-Link for ColdFire <br /><br /> <br /><br />IAR Embedded Workbench for ColdFire provides ready-made support files for the following devices: <br /><br />ColdFire V1: MCF51QE32, MCF51QE64, MCF51QE128, <br /><br />ColdFire V2: MCF5207, MCF5208, MCF5211, MCF5212, MCF5213, MCF5214, MCF5216, MCF5232, MCF5233, MCF5234, MCF5235, MCF5270, MCF5271, MCF5274, MCF5275, MCF52100, MCF52110, MCF52210, MCF52211, MCF52212, MCF52213, MCF52221, MCF52223, MCF52230, MCF52231, MCF52233, MCF52234, MCF52235, MCF52236.<br /><br /> |
