| 用keil μVision V5.14.2  编写以下程序, #define uchar unsigned char
 #define uint unsigned int
 #include <reg51.h>
 #include <stdio.h>
 void delay(void)
 uchar a, b,C;
 for (a = 20; a>0; a--)
 for (b =20; b>0; b--)
 for (C =248; C>0; C--);
 void main()
 while(1)
 P2|=0x01;
 delay();
 P2&=~0x01;
 delay();
 能正常运行,结果正常。
 可是程序写成下面这样,就是死活不运行,LED不显示或乱显示,板子确认是OK的,用别的芯片试过了!
 #include <reg51.h>
 #include <stdio.h>
 const uchar code tab[16]={0x81,0xf5,0x49,0x61,0x35,0x23,0x03,0xf1,0x01,0x21,0x11,0x07,0x8b,0x45,0x0b,0x1b};
 void delay (uint ms)
 uint i,j;
 for (i=0;i<ms;i++)
 for (j=0;j<1141;j++);
 void ledshow (uchar ten,uchar one)
 P2|= 0x01;
 P0 = tab[one];
 delay(10);
 P2&=~0x01;
 P2|= 0x02;
 P0 = tab[ten];
 delay(10);
 P2&=~0x02;
 int main (void)
 uchar one=0,ten=0;
 uchar enc_bef=0;
 delay(1);
 while(1)
 one=counter%10;
 ten=counter/10%10;
 ledshow(ten,one);
