[Atmel] Atmel公司推出了一种新的高性能的调试工具
521|0
 楼主| ddllxxrr 发表于 2016-1-1 11:04 | 显示全部楼层 |阅读模式
介绍新的电源调试程序
Atmel公司推出了一种新的高性能的调试工具,具有超低功耗设计先进的可视化。
如果你正在寻找一个高精度的调试工具,让你想象你的产品在开发过程中的功率使用,你是幸运的。这是因为公司已经推出了一个新的电源调试程序,最新的编程和调试都|智能Cortex-M–基于Atmel AVR使用JTAG,社署,PDIdebugwireawire开发工具,TPISPI目标接口。
f you’re seeking a high-accuracy debugging tool that lets you visualize the power usage of your product during development, you’re in luck. That’s because Atmel has unveiled a newPower Debugger, the latest dev tool for debugging and programming both Atmel | SMART Cortex-M–based and AVR MCUs that use JTAG, SWD, PDI, debugWIRE, aWire, TPI or SPI target interfaces.
With ultra-low power being such a critical factor in next-generation IoT, wearable and battery-operated devices, having the ability to locate code where power spikes occur is crucial. The Power Debugger features two independent current-sensing channels for collecting power measurements during application execution (one high resolution channel that can measure 100nA to 100mA and one lower resolution channel that can measure 1mA to 1A), and streams such collected measurements to the Atmel Data Visualizer — available in the Atmel Studio 7 IDE— for real-time analysis and display. The program graphs power usage and utilizes this data to estimate application battery life. What’s more, the Data Visualizer allows developers to correlate power samples with the code that was executing when the sample was taken, greatly reducing the time required to identify “hot spots” in the developers’ application.
“Lowering overall power consumption is key to many customer designs and essential for battery-operated and wearable designs,” explains Steve Pancoast, Atmel Vice President of Software Development, Applications and Tools. “Atmel provides cost-effective, easy-to-use tools that make it possible for **elopers to profile the power usage of applications running on their own hardware as part of the standard development cycle. The Power Debugger is part of Atmel’s pledge to bring the latest tools to market, enabling developers to quickly get their prototype to production with the lowest power consumption.”
The Power Debugger is now available on Atmel’s online store and and through a variety of distributors. Each kit consists of a main unit with plastic back-plate, two USB cables, a 10-lead squid cable, a flat cable (10-pin 50mil connector and 6-pin 100mil connector), an adapter board (20-pin 100mil connector, 6-pin 50mil connector and 10-pin 100mil connector) and a 20-pin 100mil jumper cable.
个人签名:http://shop34182318.taobao.com/ http://shop562064536.taobao.com
2404
