1. tar xvfz qt-2.3.10.tar.gz<br />2. <br />   QTDIR=/home/qt-2.3.10<br />   LD_LIBRARY_PATH=$QTDIR/libLD_LIBRARY_PATH<br />   PATH=$QTDIR/binPATH<br />   export QTDIR  LDLIBRARY_PATH<br />3. ./configure -xplatform linux-arm-g++ -shared<br />   注意配置时 -shared前有个空格的,否则配置出错。 <br />   输入yes,5,16,no<br />4. make<br />5. 后来更换高版本的编译器后 连接例子时提示未定义的 __cxa_pure_virtual函数,解决方法是<br />    改变该例子的Makefile里的arm-linux-gcc为 arm-linux-g++即可。<br /><br /><br />出错误后:<br />vim src/allmoc.cpp  加入下面的函数。<br /><br /><br />extern 'C' void<br />__cxa_pure_virtual(void)<br />{<br />    //CYG_FAIL('attempt to use a virtual function before object has been constructed');<br />    for(;;);<br />}<br /><br />void* operator new[](size_t size)<br />{<br />    return malloc(size);<br />}<br /><br />void* operator new(size_t size)<br />{<br />    return malloc(size);<br />}<br /><br />void operator delete[](void* p)<br />{<br />    free(p);<br />}<br /><br />void operator delete[](void* p, size_t size)<br />{<br />    free(p);<br />}<br /><br />void operator delete(void* p)<br />{<br />    free(p);<br />}<br /><br />void operator delete(void* p, size_t size)<br />{<br />    free(p);<br />}<br />  拷贝lib目录到根文件系统就可以测试了。<br /><br /><br /><br />arm-linux-gcc -v<br />Reading specs from /home/toolchain/arm/3.4.1/bin/../lib/gcc/arm-linux/3.4.1/specs<br />Configured with: /work/crosstool-0.27/build/arm-linux/gcc-3.4.1-glibc-2.3.2/gcc-3.4.1/configure --target=arm-linux --host=i686-host_pc-linux-gnu --prefix=/usr/local/arm/3.4.1 --with-headers=/usr/local/arm/3.4.1/arm-linux/include --with-local-prefix=/usr/local/arm/3.4.1/arm-linux --disable-nls --enable-threads=posix --enable-symvers=gnu --enable-__cxa_atexit --enable-languages=c,c++ --enable-shared --enable-c99 --enable-long-long<br />Thread model: posix<br />gcc version 3.4.1<br /> |
