[Actel FPGA] 下载时出现问题,急!急!急!
7022|8
 楼主| talent2008 发表于 2008-4-2 10:13 | 显示全部楼层 |阅读模式
请高手指教:<br />下载时出现问题,开始都正常,在点击PROGRAM时无法下载,原来还没事。显示如下:<br />programmer&nbsp;'FPBBALTLPT1'&nbsp;:&nbsp;Scan&nbsp;Chain...<br />Error:&nbsp;programmer&nbsp;'FPBBALTLPT1'&nbsp;:&nbsp;Signal&nbsp;Integrity&nbsp;Failure<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Integrity&nbsp;Check&nbsp;Pattern&nbsp;Not&nbsp;Found.<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Integrity&nbsp;Check&nbsp;Pattern&nbsp;:<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;550FAAF000FF0000FFFF<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;IrScan&nbsp;Error.<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Possible&nbsp;chain&nbsp;exceeds&nbsp;expected&nbsp;maximum&nbsp;device&nbsp;count:&nbsp;256.<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Chain&nbsp;Analysis&nbsp;Failed.<br />Error:&nbsp;programmer&nbsp;'FPBBALTLPT1'&nbsp;:&nbsp;Data&nbsp;Bit&nbsp;length&nbsp;:&nbsp;8272<br />Error:&nbsp;programmer&nbsp;'FPBBALTLPT1'&nbsp;:&nbsp;Compare&nbsp;Data&nbsp;&nbsp;:&nbsp;0100000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000<br />Error:&nbsp;programmer&nbsp;'FPBBALTLPT1'&nbsp;:&nbsp;Scan&nbsp;Chain&nbsp;FAILED.<br />Error:&nbsp;Failed&nbsp;to&nbsp;run&nbsp;Action.<br />不知是哪里的问题,怎么解决,请高手指教。
zlgactel 发表于 2008-4-2 22:21 | 显示全部楼层
您好
请检查并口和JTAG插座是否连接好。
 楼主| talent2008 发表于 2008-4-3 10:28 | 显示全部楼层
还是不行
已经检查过连接好了,可还是不能下载<br />我试过了,连接不好的话显示的信息是:<br />Error:&nbsp;programmer&nbsp;'FPBBALTLPT1'&nbsp;:&nbsp;Signal&nbsp;Integrity&nbsp;Failure<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Integrity&nbsp;Check&nbsp;Pattern&nbsp;Not&nbsp;Found.<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Integrity&nbsp;Check&nbsp;Pattern&nbsp;:<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;550FAAF000FF0000FFFF<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;IrScan&nbsp;Error.<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;TDO&nbsp;stuck&nbsp;at&nbsp;1<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Chain&nbsp;Analysis&nbsp;Failed.<br />Error:&nbsp;programmer&nbsp;'FPBBALTLPT1'&nbsp;:&nbsp;Data&nbsp;Bit&nbsp;length&nbsp;:&nbsp;8272<br />Error:&nbsp;programmer&nbsp;'FPBBALTLPT1'&nbsp;:&nbsp;Compare&nbsp;Data&nbsp;&nbsp;:&nbsp;FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF<br />Error:&nbsp;programmer&nbsp;'FPBBALTLPT1'&nbsp;:&nbsp;Scan&nbsp;Chain&nbsp;FAILED.<br />Error:&nbsp;Failed&nbsp;to&nbsp;run&nbsp;Action.<br />
 楼主| talent2008 发表于 2008-4-4 11:05 | 显示全部楼层
问题已解决
我用示波器检查过了,是跳线的电压设的不对,多谢!
jnu1214 发表于 2015-7-3 16:40 | 显示全部楼层
楼上的兄弟,你是怎么解决的啊?我也遇到这样的问题呃,求救!
joelxue_123 发表于 2015-7-9 14:07 | 显示全部楼层
我也遇到了耶,用并口jtag也能烧写么? 用flashpro3 效果一样么。
marsha 发表于 2020-4-1 17:09 | 显示全部楼层
您好 请问怎么解决的
marsha 发表于 2020-4-1 17:13 | 显示全部楼层
大侠们,都怎么解决的 求不吝赐教
鉴云 发表于 2023-5-3 12:41 | 显示全部楼层
检查JTAG接口有没有插反插好,换块板子对比,检查复位电路状态,复位条件下烧不进去
