#i nclude <reg52.h>
#i nclude <intrins.h> #ifndef uchar #define uchar unsigned char #endif #ifndef uint #define uint unsigned int #endif #define DATA P1 sbit RS=P3^7; sbit RW=P3^6; sbit E =P3^5; sbit BS=P1^7;
uchar *h="hello everyone ! \n welcome! " ; void busy() //??????? { do { DATA=0xFF; RS=0; RW=1; E=0; _nop_(); E=1; }while(BS); } void command(uchar dat) { DATA=dat; RS=0; RW=0; E=0; busy(); E=1; } void write(uchar dat) { DATA=dat; RS=1; RW=0; E=0; busy(); E=1; }
void clear(uchar dat) //??? 1 ?? { command(dat); }
void back(uchar a) //???? { a; command(0x02); }
void mov(uchar id,uchar s) //id ?????????1?? 0 ?? { //s???????????1? 0 ? command(0x04|(id<<1)|s); }
void run(uchar d,uchar c,uchar b) //?????? { //d ?????? 1 ? 2 ? command(0x08|(d<<2)|(c<<1)|b); //c ?????? 1 ? 2 ? } //b ?????? 1 ? 2 ? void shift(uchar sc,uchar rl) //sc 1 ?????? 0 ?????? { //rl 1 ?? 0 ?? command(0x10|(sc<<3)|(rl<<2)); }
void function(uchar dl,uchar n,uchar f) //dl 1 ???? 0 ???? //??dl 1???? 0 ???? ???????? { //n 1 ???? 0 ???? command(0x20|(dl<<4)|(n<<3)|(f<<2)); //f 1 5*10?? 0 5*7 ?? }
void charaddr(uchar agg) //???????? { command(0x40|agg); }
void dataaddr(uchar add) //????????? { command(add|0x80); }
void text(uchar dat) //????? { write(dat); }
void delay(uint t) { uint i; while(!((t--)==0x0)) { for(i=0;i<0x1fff;i++); } }
void print(uchar row ,char *p) //???? row?????? *p?????? { uchar a=0x0,i=1; dataaddr(row); while(i--) { while((*p)!='\0') { text(*p++); delay(2); if(((*p)=='\n')) { back(2); dataaddr(0x50); } } p=&h[0]; dataaddr(0x10); } } /*main.c**************************************/ #define uchar unsigned char #define uint unsigned int void initial() { clear(1); function(1,1,0); mov(1,1); shift(1,1); run(1,0,0); clear(0); } void main() { uchar s; s=10; initial(); do { clear(1); back(2); print(0x10,h); delay(5); _nop_(); delay(0x00); clear(1); back(2); print(0x10,"I can ! belive me ! "); delay(5); _nop_(); delay(0x00); } while(s--); clear(1); while(1); }
