STM32103zet6 FSMC接ST39VF040不成功,代码如下:
4180|3
 楼主| zb7401 发表于 2009-2-18 09:28 | 显示全部楼层 |阅读模式
用的是万利的EK-STM3210E板子,那位成功读写了板上Nor flash?
/* Includes ------------------------------------------------------------------*/
#include "fsmc_nor.h"
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
#define Bank1_NOR2_ADDR       ((u32)0x64000000)
/* Delay definition */
#define BlockErase_Timeout    ((u32)0x00A00000)
#define ChipErase_Timeout     ((u32)0x30000000)
#define Program_Timeout       ((u32)0x00001400)
/* Private macro -------------------------------------------------------------*/
//#define ADDR_SHIFT(A) (Bank1_NOR2_ADDR + (2 * (A)))
#define ADDR_SHIFT(A) (Bank1_NOR2_ADDR + A)
#define NOR_WRITE(Address, Data)  (*(vu16 *)(Address) = (Data))
/* Private variables ---------------------------------------------------------*/
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
* Function Name  : FSMC_NOR_Init
* Description    : Configures the FSMC and GPIOs to interface with the NOR memory.
*                  This function must be called before any write/read operation
*                  on the NOR.
* Input          : None
* Output         : None
* Return         : None
void FSMC_NOR_Init(void)
  FSMC_NORSRAMInitTypeDef  FSMC_NORSRAMInitStructure;
  FSMC_NORSRAMTimingInitTypeDef  p;
  GPIO_InitTypeDef GPIO_InitStructure;
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOE |
                         RCC_APB2Periph_GPIOF | RCC_APB2Periph_GPIOG, ENABLE);
  /*-- GPIO Configuration ------------------------------------------------------*/
  /* NOR Data lines configuration */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_14 | GPIO_Pin_15;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10;
  GPIO_Init(GPIOE, &GPIO_InitStructure);
  /* NOR Address lines configuration */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3 |
                                GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_12 | GPIO_Pin_13 |
  GPIO_Init(GPIOF, &GPIO_InitStructure);
                                GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5;
  GPIO_Init(GPIOG, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_13;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6;
  /* NOE and NWE configuration */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_5;
  /* NE2 configuration */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
  /*-- FSMC Configuration ----------------------------------------------------*/
  p.FSMC_AddressSetupTime = 0x05;
  p.FSMC_AddressHoldTime = 0x00;
  p.FSMC_DataSetupTime = 0x07;
  p.FSMC_BusTurnAroundDuration = 0x00;
  p.FSMC_CLKDivision = 0x00;
  p.FSMC_DataLatency = 0x00;
  p.FSMC_AccessMode = FSMC_AccessMode_B;
  FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM2;
  FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable;
  FSMC_NORSRAMInitStructure.FSMC_MemoryType = FSMC_MemoryType_NOR;
  FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_8b;
  FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode = FSMC_BurstAccessMode_Disable;
  FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low;
  FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable;
  FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState;
  FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable;
  FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Disable;
  FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Disable;
  FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable;
  FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &p;
  FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &p;
  FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure);
  /* Enable FSMC Bank1_NOR Bank */
  FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM2, ENABLE);
* Function Name  : FSMC_NOR_ReadID
* Description    : Reads NOR memory's Manufacturer and Device Code.
* Input          : - NOR_ID: pointer to a NOR_IDTypeDef structure which will hold
*                    the Manufacturer and Device Code.
* Output         : None
* Return         : None
void FSMC_NOR_ReadID(NOR_IDTypeDef* NOR_ID)
  NOR_WRITE(ADDR_SHIFT(0x5555), 0x00AA);
  NOR_WRITE(ADDR_SHIFT(0x2AAA), 0x0055);
  NOR_WRITE(ADDR_SHIFT(0x5555), 0x0090);
  NOR_ID->Manufacturer_Code = *(vu16 *) ADDR_SHIFT(0x0000);
  NOR_ID->Device_Code1 = *(vu16 *) ADDR_SHIFT(0x0001);
  //NOR_ID->Device_Code2 = *(vu16 *) ADDR_SHIFT(0x000E);
 // NOR_ID->Device_Code3 = *(vu16 *) ADDR_SHIFT(0x000F);
* Function Name  : FSMC_NOR_EraseBlock
* Description    : Erases the specified Nor memory block.
* Input          : - BlockAddr: address of the block to erase.
* Output         : None
* Return         : NOR_Status:The returned value can be: NOR_SUCCESS, NOR_ERROR
*                  or NOR_TIMEOUT
NOR_Status FSMC_NOR_EraseBlock(u32 BlockAddr)
  NOR_WRITE(ADDR_SHIFT(0x5555), 0x0080);
  NOR_WRITE((Bank1_NOR2_ADDR + BlockAddr), 0x30);
  return (FSMC_NOR_GetStatus(BlockErase_Timeout));
* Function Name  : FSMC_NOR_EraseChip
* Description    : Erases the entire chip.
* Input          : None
* Output         : None
*                  or NOR_TIMEOUT
NOR_Status FSMC_NOR_EraseChip(void)
  NOR_WRITE(ADDR_SHIFT(0x0555), 0x00AA);
  NOR_WRITE(ADDR_SHIFT(0x02AA), 0x0055);
  NOR_WRITE(ADDR_SHIFT(0x0555), 0x0080);
  NOR_WRITE(ADDR_SHIFT(0x0555), 0x0010);
  return (FSMC_NOR_GetStatus(ChipErase_Timeout));
* Function Name  : FSMC_NOR_WriteHalfWord
* Description    : Writes a half-word to the NOR memory.
* Input          : - WriteAddr : NOR memory internal address to write to.
*                  - Data : Data to write.
* Output         : None
*                  or NOR_TIMEOUT
NOR_Status FSMC_NOR_WriteHalfWord(u32 WriteAddr, u16 Data)
  NOR_WRITE(ADDR_SHIFT(0x5555), 0x00A0);
  NOR_WRITE((Bank1_NOR2_ADDR + WriteAddr), Data);
  return (FSMC_NOR_GetStatus(Program_Timeout));
* Function Name  : FSMC_NOR_WriteBuffer
* Description    : Writes a half-word buffer to the FSMC NOR memory.
* Input          : - pBuffer : pointer to buffer.
*                  - WriteAddr : NOR memory internal address from which the data
*                    will be written.
*                  - NumHalfwordToWrite : number of Half words to write.
* Output         : None
*                  or NOR_TIMEOUT
NOR_Status FSMC_NOR_WriteBuffer(u16* pBuffer, u32 WriteAddr, u32 NumHalfwordToWrite)
  NOR_Status status = NOR_ONGOING;
  do
    /* Transfer data to the memory */
    status = FSMC_NOR_WriteHalfWord(WriteAddr, *pBuffer++);
    WriteAddr = WriteAddr + 2;
    NumHalfwordToWrite--;
  while((status == NOR_SUCCESS) && (NumHalfwordToWrite != 0));
  return (status);
* Function Name  : FSMC_NOR_ProgramBuffer
* Description    : Writes a half-word buffer to the FSMC NOR memory. This function
*                  must be used only with S29GL128P NOR memory.
*                  - WriteAddr: NOR memory internal address from which the data
*                    will be written.
*                  - NumHalfwordToWrite: number of Half words to write.
*                    The maximum allowed value is 32 Half words (64 bytes).
* Output         : None
*                  or NOR_TIMEOUT
NOR_Status FSMC_NOR_ProgramBuffer(u16* pBuffer, u32 WriteAddr, u32 NumHalfwordToWrite)
  u32 lastloadedaddress = 0x00;
  u32 currentaddress = 0x00;
  u32 endaddress = 0x00;
  /* Initialize variables */
  currentaddress = WriteAddr;
  endaddress = WriteAddr + NumHalfwordToWrite - 1;
  lastloadedaddress = WriteAddr;
  /* Issue unlock command sequence */
  NOR_WRITE(ADDR_SHIFT(0x05555), 0x00AA);
  /* Write Write Buffer Load Command */
  NOR_WRITE(ADDR_SHIFT(WriteAddr), 0x0025);
  NOR_WRITE(ADDR_SHIFT(WriteAddr), (NumHalfwordToWrite - 1));
  /* Load Data into NOR Buffer */
  while(currentaddress <= endaddress)
    /* Store last loaded address & data value (for polling) */
    lastloadedaddress = currentaddress;
    NOR_WRITE(ADDR_SHIFT(currentaddress), *pBuffer++);
    currentaddress += 1;
  NOR_WRITE(ADDR_SHIFT(lastloadedaddress), 0x29);
  return(FSMC_NOR_GetStatus(Program_Timeout));
* Function Name  : FSMC_NOR_ReadHalfWord
* Description    : Reads a half-word from the NOR memory.
* Input          : - ReadAddr : NOR memory internal address to read from.
* Output         : None
* Return         : Half-word read from the NOR memory
u16 FSMC_NOR_ReadHalfWord(u32 ReadAddr)
  NOR_WRITE((Bank1_NOR2_ADDR + ReadAddr), 0x00F0 );
  return (*(vu16 *)((Bank1_NOR2_ADDR + ReadAddr)));
* Function Name  : FSMC_NOR_ReadBuffer
* Description    : Reads a block of data from the FSMC NOR memory.
* Input          : - pBuffer : pointer to the buffer that receives the data read
*                    from the NOR memory.
*                  - ReadAddr : NOR memory internal address to read from.
*                  - NumHalfwordToRead : number of Half word to read.
* Output         : None
* Return         : None
void FSMC_NOR_ReadBuffer(u16* pBuffer, u32 ReadAddr, u32 NumHalfwordToRead)
  for(; NumHalfwordToRead != 0x00; NumHalfwordToRead--) /* while there is data to read */
    /* Read a Halfword from the NOR */
    *pBuffer++ = *(vu16 *)((Bank1_NOR2_ADDR + ReadAddr));
    ReadAddr = ReadAddr + 2;
* Function Name  : FSMC_NOR_ReturnToReadMode
* Description    : Returns the NOR memory to Read mode.
* Input          : None
* Output         : None
* Return         : NOR_SUCCESS
NOR_Status FSMC_NOR_ReturnToReadMode(void)
  NOR_WRITE(ADDR_SHIFT(0x5555), 0x00F0);
* Function Name  : FSMC_NOR_Reset
* Description    : Returns the NOR memory to Read mode and resets the errors in
*                  the NOR memory Status Register.
* Input          : None
* Output         : None
NOR_Status FSMC_NOR_Reset(void)
  NOR_WRITE(Bank1_NOR2_ADDR, 0x00F0);
  return (NOR_SUCCESS);
* Function Name  : FSMC_NOR_GetStatus
* Description    : Returns the NOR operation status.
* Input          : - Timeout: NOR progamming Timeout
* Output         : None
*                  or NOR_TIMEOUT
NOR_Status FSMC_NOR_GetStatus(u32 Timeout)
  u16 val1 = 0x00, val2 = 0x00;
  u32 timeout = Timeout;
  /* Poll on NOR memory Ready/Busy signal ------------------------------------*/
  while((GPIO_ReadInputDataBit(GPIOD, GPIO_Pin_6) != RESET) && (timeout > 0))
    timeout--;
  timeout = Timeout;
  while((GPIO_ReadInputDataBit(GPIOD, GPIO_Pin_6) == RESET) && (timeout > 0))
    timeout--;
  /* Get the NOR memory operation status -------------------------------------*/
  while((Timeout != 0x00) && (status != NOR_SUCCESS))
    Timeout--;
      /* Read DQ6 and DQ5 */
    val1 = *(vu16 *)(Bank1_NOR2_ADDR);
    val2 = *(vu16 *)(Bank1_NOR2_ADDR);
    /* If DQ6 did not toggle between the two reads then return NOR_Success */
    if((val1 & 0x0040) == (val2 & 0x0040))
      return NOR_SUCCESS;
    if((val1 & 0x0020) != 0x0020)
      return NOR_SUCCESS;
    else if((val1 & 0x0020) == 0x0020)
      return NOR_ERROR;
  if(Timeout == 0x00)
    status = NOR_TIMEOUT;
  /* Return the operation status */
  return (status);
 楼主| zb7401 发表于 2009-2-19 09:15 | 显示全部楼层
大家都不用8位的flash吗?
你们没测试板上flash吗?万利没有测试Nor的代码!哪位有?
ST_ARM 发表于 2009-2-19 10:07 | 显示全部楼层
没有用过你贴的这个代码
这个代码是我们的一个同事从ST的demo板中程序中抠出来的,做了一些简单的修改,做了一些简单的测试,基本能通过。(ST的demo板上的Nor FLash不是这个型号)
我没有用过。
你的在使用时出现什么样的现象,请列出来。
香水城 发表于 2009-2-19 10:15 | 显示全部楼层
请仔细检查时序参数的配置
ST网站上有一个应用笔记(AN2784),里面有如何计算时序参数的方法。
