哈哈哈……原来老外也互相抄袭啊,而且是业界知名半导体
3968|15
 楼主| 风... 发表于 2007-10-13 10:28 | 显示全部楼层 |阅读模式
“The&nbsp;CD4013B&nbsp;dual&nbsp;D&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;flip-flop&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;is&nbsp;a&nbsp;monolithic&nbsp;complementary&nbsp;MOS&nbsp;(CMOS)&nbsp;integrated&nbsp;circuit&nbsp;constructed&nbsp;with&nbsp;N-&nbsp;and&nbsp;P-channel&nbsp;enhancement&nbsp;mode&nbsp;transistors.&nbsp;Each&nbsp;flip-flop&nbsp;has&nbsp;independent&nbsp;data,&nbsp;set,&nbsp;reset,&nbsp;and&nbsp;clock&nbsp;inputs&nbsp;and&nbsp;``Q''&nbsp;and&nbsp;``Q''&nbsp;outputs.&nbsp;These&nbsp;devices&nbsp;can&nbsp;be&nbsp;used&nbsp;for&nbsp;shift&nbsp;register&nbsp;applications,&nbsp;and&nbsp;by&nbsp;connecting&nbsp;``Q''&nbsp;output&nbsp;to&nbsp;the&nbsp;data&nbsp;input,&nbsp;for&nbsp;counter&nbsp;and&nbsp;toggle&nbsp;applications.&nbsp;The&nbsp;logic&nbsp;level&nbsp;present&nbsp;at&nbsp;the&nbsp;``D''&nbsp;input&nbsp;is&nbsp;transferred&nbsp;to&nbsp;the&nbsp;Q&nbsp;output&nbsp;during&nbsp;the&nbsp;positive-going&nbsp;transition&nbsp;of&nbsp;the&nbsp;clock&nbsp;pulse.&nbsp;Setting&nbsp;or&nbsp;resetting&nbsp;is&nbsp;independent&nbsp;of&nbsp;the&nbsp;clock&nbsp;and&nbsp;is&nbsp;accomplished&nbsp;by&nbsp;a&nbsp;high&nbsp;level&nbsp;on&nbsp;the&nbsp;set&nbsp;or&nbsp;reset&nbsp;line&nbsp;respectively.”<br /><br />“The&nbsp;CD4013B&nbsp;dual&nbsp;D-type&nbsp;flip-flop&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;is&nbsp;a&nbsp;monolithic&nbsp;complementary&nbsp;MOS&nbsp;(CMOS)&nbsp;integrated&nbsp;circuit&nbsp;constructed&nbsp;with&nbsp;N-&nbsp;and&nbsp;P-channel&nbsp;enhancement&nbsp;mode&nbsp;transistors.&nbsp;Each&nbsp;flip-flop&nbsp;has&nbsp;independent&nbsp;data,&nbsp;set,&nbsp;reset,&nbsp;and&nbsp;clock&nbsp;inputs&nbsp;and&nbsp;“Q”&nbsp;and&nbsp;“Q”&nbsp;outputs.&nbsp;These&nbsp;devices&nbsp;can&nbsp;be&nbsp;used&nbsp;for&nbsp;shift&nbsp;register&nbsp;applications,&nbsp;and&nbsp;by&nbsp;connecting&nbsp;“Q”&nbsp;output&nbsp;to&nbsp;the&nbsp;data&nbsp;input,&nbsp;for&nbsp;counter&nbsp;and&nbsp;toggle&nbsp;applications.&nbsp;The&nbsp;logic&nbsp;level&nbsp;present&nbsp;at&nbsp;the&nbsp;“D”&nbsp;input&nbsp;is&nbsp;transferred&nbsp;to&nbsp;the&nbsp;Q&nbsp;output&nbsp;during&nbsp;the&nbsp;positive-going&nbsp;transition&nbsp;of&nbsp;the&nbsp;clock&nbsp;pulse.&nbsp;Setting&nbsp;or&nbsp;resetting&nbsp;is&nbsp;independent&nbsp;of&nbsp;the&nbsp;clock&nbsp;and&nbsp;is&nbsp;accomplished&nbsp;by&nbsp;a&nbsp;high&nbsp;level&nbsp;on&nbsp;the&nbsp;set&nbsp;or&nbsp;reset&nbsp;line&nbsp;respectively.”<br /><br />哈哈,是不是完全一样?<br /><a href="http://www.fairchildsemi.com/ds/CD/CD4013BC.pdf" target=_blank>http://www.fairchildsemi.com/ds/CD/CD4013BC.pdf</a><br /><a href="http://www1.national.com/ds.cgi/CD/CD4013BM.pdf" target=_blank>http://www1.national.com/ds.cgi/CD/CD4013BM.pdf</a><br /><br />
maychang 发表于 2007-10-13 10:34 | 显示全部楼层
很正常的事,不是抄袭
51系列单片机是Intel公司设计的,其它各厂家生产的都是向Intel买了许可证,当然同时也带着所有的技术资料。
chunyang 发表于 2007-10-13 11:33 | 显示全部楼层
楼主说的这两家公司更不是什么抄袭了,而是有一段“传奇
&nbsp;&nbsp;&nbsp;&nbsp;楼主提到的第一家公司叫“仙童”,第二家叫“国半”(国家半导体),仙童公司是硅谷的奠基者,IC的商品化生产方法就是由仙童发明,当年很多半导体界的传奇人物和传奇事件也与仙童有关,比如“摩尔定律”等等。仙童也是包括国半、Intel、AMD等著名硅谷半导体公司的“生母”,其中血统最纯的就算是国半了。仙童在世界半导体产业曾经起过非常重要的作用,当时(1960S)的影响远超现在的Intel,像4000系列CMOS电路、74系列TTL电路等的标准制订仙童起的是主导作用,在80年代初出版的著名畅销书《硅谷热》(Silicon&nbsp;Valley&nbsp;Fever)中写到:“硅谷大约70家半导体公司的半数,是仙童公司的直接或间接后裔。在仙童公司供职是进入遍布于硅谷各地的半导体业的途径。1969年在森尼维尔举行的一次半导体工程师大会上,&nbsp;400位与会者中,未曾在仙童公司工作过的还不到24人。”从这个意义上讲,说仙童半导体公司是“硅谷人才摇篮”毫不为过。<br />&nbsp;&nbsp;&nbsp;&nbsp;但大量“出血”繁荣了硅谷的同时仙童自己却逃不了衰弱的**,到1970S末,仙童已到了破产倒闭的地步,最终于1979年被出售。仙童公司倒了,但仙童品牌还是极具分量的,所谓“瘦死骆驼比马大”,几经转手包括换了法国、日本等几个东家,仙童最终被国半收购,国半的核心正是当年从仙童“叛逃”的核心,CEO都是同一个人,仙童这算是“回家”了。<br />&nbsp;&nbsp;&nbsp;&nbsp;目前,仙童作为国家半导体的全资子公司独立运作。
McuPlayer 发表于 2007-10-13 12:08 | 显示全部楼层
佩服
chunyang兄见多识广
edanzg 发表于 2007-10-13 12:31 | 显示全部楼层
呵呵,都是肖克利的门徒,
HWM 发表于 2007-10-13 12:42 | 显示全部楼层
其实硅谷的演变史,
充分演绎了当代半导体乃至整个当代技术的发展历程。其具有相当的借鉴价值。
mVA 发表于 2007-10-13 13:14 | 显示全部楼层
原来国半与仙童还有这样一段关系!
maychang 发表于 2007-10-13 13:30 | 显示全部楼层
回楼上
各大公司之间的这样的故事多得很,仙童(Fairchild,费尔柴尔德)与国半之间仅仅是几百个这样的故事中的一个。<br />世界上第一片模拟集成电路是仙童公司做出来的。
vr2whf 发表于 2007-10-14 01:46 | 显示全部楼层
Fairchild已在1997年从国半独立出来了
在共同利益或互补情况下,&nbsp;外国公司之间有很多技术转移,&nbsp;大家有同样的设计是不奇怪的.<br /><br />再者,&nbsp;有部分专利权过了一定时限之後就会废了,&nbsp;人家也就可以合法模仿.<br /><br />外国公司十分注重版权的,&nbsp;因为仲值钱的不是血汗,&nbsp;而是知识.<br />
computer00 发表于 2007-10-14 02:11 | 显示全部楼层
中文名应该叫飞兆半导体了吧
 楼主| 风... 发表于 2007-10-14 02:12 | 显示全部楼层
嘿,还有这么多历史啊,涨见识了!顶!
HWM 发表于 2007-10-14 10:33 | 显示全部楼层
00:那是直译拉,我还是喜欢"仙童",还是早期的译法好.
computer00 发表于 2007-10-14 10:35 | 显示全部楼层
没办法,这是官方给的名字,我们也只好这样用.
maychang 发表于 2007-10-14 10:40 | 显示全部楼层
音乐乐乐 在电测仪表版面问买示波器是买安捷伦的还是买泰
安捷伦就是从惠普公司分出来的。
chunyang 发表于 2007-10-14 13:58 | 显示全部楼层
仙童并非真正的独立,而是国半的子公司
&nbsp;&nbsp;&nbsp;&nbsp;国半重新整合了仙童的产品线,令其独立运作,但仍在国半的全球战略框架内。当前国际市场环境下,大公司的战略两级分化严重,东方企业仍在追求大而全,西方企业则流行拆分,HP吃掉了Compaq及其未消化的DEC,负担很重,所以将其立家之本测量仪器拆分成立安捷伦以轻装觊觎PC老大的位置;Motorola则将其半导体业务拆分出ON和Freescale以Moto跟Nokia争霸;西门子则拆分出英飞凌;Philips在同一招牌下拆分,其半导体部分现在成了NXP;AMD为了和Intel在CPU产业上竞争,也准备将其Flash业务拆分……所有这些策略都是为了在特定的方向上优化资源以图全球霸业。
开发过程 发表于 2007-10-14 16:01 | 显示全部楼层
一个公司而已
国半是老板,仙童是打工的。
