收藏0 举报
#ifndef __iot24v_h #define __iot24v_h #ifndef _AVR #warning "You try to include ICCAVR header file." #else /* ATtiny26 register and bit name header file * for ImageCraft ICCAVR compiler */ /* last changed 2003-09-19 */ /* ADC */ #define ADCSRB (*(volatile unsigned char *)0x23)// #define ADC (*(volatile unsigned int *)0x24)// #define ADCL (*(volatile unsigned char *)0x24)// #define ADCH (*(volatile unsigned char *)0x25)// #define ADCSRA (*(volatile unsigned char *)0x26)// #define ADMUX (*(volatile unsigned char *)0x27)// /* Analog Comp */ #define ACSR (*(volatile unsigned char *)0x28)// /* Universal Serial Interface */ #define USICR (*(volatile unsigned char *)0x2D)// #define USISR (*(volatile unsigned char *)0x2E)// #define USIDR (*(volatile unsigned char *)0x2F)// #define USIBR (*(volatile unsigned char *)0x30)// /* Port B */ #define PINB (*(volatile unsigned char *)0x36)// #define DDRB (*(volatile unsigned char *)0x37)// #define PORTB (*(volatile unsigned char *)0x38)// /* Port A */ #define PINA (*(volatile unsigned char *)0x39)// #define DDRA (*(volatile unsigned char *)0x3A)// #define PORTA (*(volatile unsigned char *)0x3B)// /* EEPROM */ #define EECR (*(volatile unsigned char *)0x3C)// #define EEDR (*(volatile unsigned char *)0x3D)// #define EEARL (*(volatile unsigned char *)0x3E)// #define EEAR (*(volatile unsigned char *)0x3E)// #define EEARH (*(volatile unsigned char *)0x3E)// /* Watchdog Timer Control Register */ #define WDTCSR (*(volatile unsigned char *)0x41)// /* Timer/Counter 1 */ #define OCR1BL (*(volatile unsigned char *)0x48)// #define OCR1BH (*(volatile unsigned char *)0x49)// #define OCR1AL (*(volatile unsigned char *)0x4A)// #define OCR1AH (*(volatile unsigned char *)0x4B)// #define TCNT1 (*(volatile unsigned char *)0x4C)// #define TCNT1L (*(volatile unsigned char *)0x4C)// #define TCNT1H (*(volatile unsigned char *)0x4D)// #define TCCR1B (*(volatile unsigned char *)0x4E)// #define TCCR1A (*(volatile unsigned char *)0x4F)// #define TCCR1C (*(volatile unsigned char *)0x42)// /* RC oscillator */ #define OSCCAL (*(volatile unsigned char *)0x51)// /* Timer/Counter 0 */ #define TCNT0 (*(volatile unsigned char *)0x52)// #define TCCR0B (*(volatile unsigned char *)0x53)// #define OCR0B (*(volatile unsigned char *)0x5C)// #define OCR0A (*(volatile unsigned char *)0x36)// /* MCU */ #define MCUSR (*(volatile unsigned char *)0x54)// #define MCUCR (*(volatile unsigned char *)0x55)// /* Timer/Counter Interrupts */ #define TIFR0 (*(volatile unsigned char *)0x58)// #define TIMSK0 (*(volatile unsigned char *)0x59)// /* General Interrupts */ #define GIFR (*(volatile unsigned char *)0x5A)// #define GIMSK (*(volatile unsigned char *)0x5B)// /* Stack Pointer */ #define SP (*(volatile unsigned int *)0x5D)// #define SPL (*(volatile unsigned char *)0x5D)// #define SPH (*(volatile unsigned char *)0x5E)// /* Status REGister */ #define SREG (*(volatile unsigned char *)0x5F)// #define SPMCSR (*(volatile unsigned char *)0x57)// /* General Interrupt registers */ #define INT0 6 #define PCIE1 5 #define PCIE0 4 #define INTF0 6 #define PCIF1 5 #define PCIF0 4 /* Timer/Counter Interrupt registers */ #define OCIE1A 1 #define OCIE1B 2 #define TOIE1 0 #define OCIE0A 1 #define OCIE0B 2 #define TOIE0 0 #define OCF1A 1 #define OCF1B 2 #define TOV1 0 #define OCF0A 1 #define OCF0B 2 #define TOV0 0 #define ICF1 5 /* MCU general Control Register */ #define BODS 7 #define PUD 6 #define SE 5 #define SM1 4 #define SM0 3 #define ISC01 1 #define ISC00 0 /* MCU general Status Register */ #define WDRF 3 #define BORF 2 #define EXTRF 1 #define PORF 0 /* Timer/Counter 0 Control Register */ #define WGM02 3 #define CS02 2 #define CS01 1 #define CS00 0 /* Timer/Counter 1 Control Registers */ #define COM1A1 7 #define COM1A0 6 #define COM1B1 5 #define COM1B0 4 #define FOC1A 3 #define FOC1B 2 #define PWM1A 1 #define PWM1B 0 #define CTC1 7 #define PSR1 6 #define CS13 3 #define CS12 2 #define CS11 1 #define CS10 0 /* Watchdog Timer Control Register */ #define WDCE 4 #define WDE 3 #define WDP2 2 #define WDP1 1 #define WDP0 0 /* EEPROM Control Register */ #define EERIE 3 #define EEMWE 2 #define EEWE 1 #define EERE 0 /* Port A bits */ #define PORTA7 7 #define PORTA6 6 #define PORTA5 5 #define PORTA4 4 #define PORTA3 3 #define PORTA2 2 #define PORTA1 1 #define PORTA0 0 #define PA7 7 #define PA6 6 #define PA5 5 #define PA4 4 #define PA3 3 #define PA2 2 #define PA1 1 #define PA0 0 #define DDA7 7 #define DDA6 6 #define DDA5 5 #define DDA4 4 #define DDA3 3 #define DDA2 2 #define DDA1 1 #define DDA0 0 #define PINA7 7 #define PINA6 6 #define PINA5 5 #define PINA4 4 #define PINA3 3 #define PINA2 2 #define PINA1 1 #define PINA0 0 /* Port B bits */ #define PORTB3 3 #define PORTB2 2 #define PORTB1 1 #define PORTB0 0 #define PB3 3 #define PB2 2 #define PB1 1 #define PB0 0 #define DDB3 3 #define DDB2 2 #define DDB1 1 #define DDB0 0 #define PINB3 3 #define PINB2 2 #define PINB1 1 #define PINB0 0 /* Universal Serial Interface */ #define USISIF 7 #define USIOIF 6 #define USIPF 5 #define USIDC 4 #define USICNT3 3 #define USICNT2 2 #define USICNT1 1 #define USICNT0 0 #define USISIE 7 #define USIOIE 6 #define USIWM1 5 #define USIWM0 4 #define USICS1 3 #define USICS0 2 #define USICLK 1 #define USITC 0 /* Analog Digital Converter MUX Register */ #define REFS1 7 #define REFS0 6 #define ADLAR 5 #define MUX4 4 #define MUX3 3 #define MUX2 2 #define MUX1 1 #define MUX0 0 /* Analog Digital Converter Control/Status Register */ #define ADEN 7 #define ADSC 6 #define ADFR 5 #define ADIF 4 #define ADIE 3 #define ADPS2 2 #define ADPS1 1 #define ADPS0 0 /* Interrupt Vector Numbers */ #define iv_RESET 1 #define iv_EXT_INT0 2 #define iv_PCINT0 3 #define iv_PCINT1 4 #define iv_WDT 5 #define iv_TIM1_CAPT 6 #define iv_TIM1_COMPA 7 #define iv_TIM1_COMPB 8 #define iv_TIM1_OVF 9 #define iv_TIM0_COMPA 10 #define iv_TIM0_COMPB 11 #define iv_TIM0_OVF 12 #define iv_ANA_COMP 13 #define iv_ADC 14 #define iv_EE_RDY 15 #define iv_USI_STR 16 #define iv_USI_OVF 17 /* */ #endif #endif
本版积分规则 发表回复 回帖并转播 回帖后跳转到最后一页
等级类勋章
发帖类勋章
时间类勋章
人才类勋章
扫码关注 21ic 官方微信
扫码关注嵌入式微处理器
扫码关注电源系统设计
扫码关注21ic项目外包
扫码浏览21ic手机版
本站介绍 | 申请友情链接 | 欢迎投稿 | 隐私声明 | 广告业务 | 网站地图 | 联系我们 | 诚聘英才
京公网安备 11010802024343号
