使用5.0配置了CSD后,排除了看门狗原因;一调用CSD_1_InitializeBaselines();或者CSD_1_ScanAllSensors();就再也返回不了主函数了。 在配置完成后出现了两个警告如下,请高手看看是否与这两个警告有关: 一: *** Warning: File `D:\mlwwif\mlwwif\mlwwif\memory.inc' has modification time in the future (2009-04-29 12:46:26 > 2009-04-29 二: *** Warning: File `D:\mlwwif\mlwwif\mlwwif\memory.inc' has modification time in the future (2009-04-29 12:50:08 > 2009-04-29 具体内容如下:
GENERATE/BUILD 'MLWWIF' PROJECT (F6) Generating mlwwif project... Starting MAKE... creating project.mk C:\PROGRA~1\Cypress\Common\CY3E64~1\tools\make: *** Warning: File `D:\mlwwif\mlwwif\mlwwif\memory.inc' has modification time in the future (2009-04-29 12:46:26 > 2009-04-29 12:46:24) lib/csd_1.asm lib/csd_1hl.asm lib/csd_1int.asm lib/csd_1table.asm lib/psocconfig.asm lib/psocconfigtbl.asm ./boot.asm ./main.c sed: can't read HTlinkOpts.lkp: No such file or directory expanded_libs = Linking.. HI-TECH C COMPILER (Cypress PSOC) Pro V9.61PL5 Copyright (C) 1984-2009 HI-TECH SOFTWARE licensed for evaluation purposes only this licence will expire on Mon, 25 May 2009 Memory Summary: Program space used 68Eh ( 1678) of 2000h bytes ( 20.5%) Data space used 82h ( 130) of 200h bytes ( 25.4%) Comparative memory usage (excludes absolute areas and stack variables) ROM used: 1329 bytes RAM used: 122 bytes mlwwif - 0 error(s) 1 warning(s) 12:46:26
BUILD ‘MLWWIF’PROJECT (F7) Starting MAKE... creating project.mk C:\PROGRA~1\Cypress\Common\CY3E64~1\tools\make: *** Warning: File `D:\mlwwif\mlwwif\mlwwif\memory.inc' has modification time in the future (2009-04-29 12:50:08 > 2009-04-29 12:50:06) lib/csd_1.asm lib/csd_1hl.asm lib/csd_1int.asm lib/csd_1table.asm lib/psocconfig.asm lib/psocconfigtbl.asm ./boot.asm ./main.c sed: can't read HTlinkOpts.lkp: No such file or directory expanded_libs = Linking.. HI-TECH C COMPILER (Cypress PSOC) Pro V9.61PL5 Copyright (C) 1984-2009 HI-TECH SOFTWARE licensed for evaluation purposes only this licence will expire on Mon, 25 May 2009 Memory Summary: Program space used 68Eh ( 1678) of 2000h bytes ( 20.5%) Data space used 82h ( 130) of 200h bytes ( 25.4%) Comparative memory usage (excludes absolute areas and stack variables) ROM used: 1329 bytes RAM used: 122 bytes mlwwif - 0 error(s) 1 warning(s) 12:50:08
