[STM32F1] 求教STM32修改官方库分频以及自设分频两种情况电流不同原因
1035|1
 楼主| 夜雨声烦、 发表于 2016-1-12 21:52 | 显示全部楼层 |阅读模式
运行STM32F105,由于外部晶振是12MHZ,所以对官方库进行修改:
首先stm32f10x.h修改晶振为#define HSE_VALUE    ((uint32_t)12000000)。
想把主频设置为48MHz,system_stm32f10x.c文件修改函数
static void SetSysClockTo48(void)
  __IO uint32_t StartUpCounter = 0, HSEStatus = 0;
  /* SYSCLK, HCLK, PCLK2 and PCLK1 configuration ---------------------------*/
  /* Enable HSE */
  RCC->CR |= ((uint32_t)RCC_CR_HSEON);
  /* Wait till HSE is ready and if Time out is reached exit */
  do
    HSEStatus = RCC->CR & RCC_CR_HSERDY;
    StartUpCounter++;
  } while((HSEStatus == 0) && (StartUpCounter != HSE_STARTUP_TIMEOUT));
  if ((RCC->CR & RCC_CR_HSERDY) != RESET)
    HSEStatus = (uint32_t)0x01;
  else
    HSEStatus = (uint32_t)0x00;
  if (HSEStatus == (uint32_t)0x01)
    /* Enable Prefetch Buffer */
    FLASH->ACR |= FLASH_ACR_PRFTBE;
    /* Flash 1 wait state */
    FLASH->ACR &= (uint32_t)((uint32_t)~FLASH_ACR_LATENCY);
    FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_1;
    /* HCLK = SYSCLK */
    RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1;
    /* PCLK2 = HCLK */
    RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE2_DIV1;
    /* PCLK1 = HCLK */
    RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE1_DIV2;
#ifdef STM32F10X_CL
    /* Configure PLLs ------------------------------------------------------*/
    /* PLL2 configuration: PLL2CLK = (HSE / 5) * 8 = 40 MHz */
    /* PREDIV1 configuration: PREDIV1CLK = PLL2 / 5 = 8 MHz */
    RCC->CFGR2 &= (uint32_t)~(RCC_CFGR2_PREDIV2 | RCC_CFGR2_PLL2MUL |
                              RCC_CFGR2_PREDIV1 | RCC_CFGR2_PREDIV1SRC);
                if (HSE_VALUE == 25000000)
                        RCC->CFGR2 |= (uint32_t)(RCC_CFGR2_PREDIV2_DIV5 | RCC_CFGR2_PLL2MUL8 |
        RCC_CFGR2_PREDIV1SRC_PLL2 | RCC_CFGR2_PREDIV1_DIV5);
                else if (HSE_VALUE == 8000000)
                        /* PLL2 configuration: PLL2CLK = (HSE / 2) * 10 = 40 MHz */
                        RCC->CFGR2 |= (uint32_t)(RCC_CFGR2_PREDIV2_DIV2 | RCC_CFGR2_PLL2MUL10 |
                else if (HSE_VALUE == 12000000)
                        /* PLL2 configuration: PLL2CLK = (HSE / 3) * 10 = 40 MHz */
                        RCC->CFGR2 |= (uint32_t)(RCC_CFGR2_PREDIV2_DIV3 | RCC_CFGR2_PLL2MUL10 |
                else
    /* Enable PLL2 */
    RCC->CR |= RCC_CR_PLL2ON;
    /* Wait till PLL2 is ready */
    while((RCC->CR & RCC_CR_PLL2RDY) == 0)
    /* PLL configuration: PLLCLK = PREDIV1 * 6 = 48 MHz */
    RCC->CFGR &= (uint32_t)~(RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLSRC | RCC_CFGR_PLLMULL);
    RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLSRC_PREDIV1 |
                            RCC_CFGR_PLLMULL6);
#else
    /*  PLL configuration: PLLCLK = HSE * 6 = 48 MHz */
    RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLMULL));
    RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLMULL6);
#endif /* STM32F10X_CL */
    /* Enable PLL */
    RCC->CR |= RCC_CR_PLLON;
    /* Wait till PLL is ready */
    while((RCC->CR & RCC_CR_PLLRDY) == 0)
    /* Select PLL as system clock source */
    RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));
    RCC->CFGR |= (uint32_t)RCC_CFGR_SW_PLL;
    /* Wait till PLL is used as system clock source */
    while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)0x08)
  else
  { /* If HSE fails to start-up, the application will have wrong clock
         configuration. User can add here some code to deal with this error */
通过函数
   RCC_ClocksTypeDef rcc_clk;
  RCC_GetClocksFreq(&rcc_clk);
获取到时钟分频正确且MCU运行正常(如串口输出,定时器中断)
然后自己写了个函数设置分频
void Set_System(void)
    ErrorStatus HSEStartUpStatus;
    /* SYSCLK, HCLK, PCLK2 and PCLK1 configuration -----------------------------*/
    /* RCC system reset(for debug purpose) */
    RCC_DeInit();
    /* Enable HSE */
    RCC_HSEConfig(RCC_HSE_ON);
    /* Wait till HSE is ready */
    HSEStartUpStatus = RCC_WaitForHSEStartUp();
    if (HSEStartUpStatus == SUCCESS)
        FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
        /* Flash 2 wait state */
        FLASH_SetLatency(FLASH_Latency_2);
        /* HCLK = SYSCLK */
        RCC_HCLKConfig(RCC_SYSCLK_Div1);
        /* PCLK2 = HCLK */
        RCC_PCLK2Config(RCC_HCLK_Div1);
        /* PCLK1 = HCLK/2 */
        RCC_PCLK1Config(RCC_HCLK_Div2);
#ifdef STM32F10X_CL
        /* Configure PLLs *********************************************************/
                                /* HSE_VALUE = 120000000 HZ, stm32f10x.h */
        RCC_PREDIV2Config(RCC_PREDIV2_Div3);
        RCC_PLL2Config(RCC_PLL2Mul_10);
        /* Enable PLL2 */
        RCC_PLL2Cmd(ENABLE);
        while (RCC_GetFlagStatus(RCC_FLAG_PLL2RDY) == RESET)
        /* PLL configuration: PLLCLK = (PLL2 / 5) * 6 = 48 MHz */
        RCC_PREDIV1Config(RCC_PREDIV1_Source_PLL2, RCC_PREDIV1_Div5);
        RCC_PLLConfig(RCC_PLLSource_PREDIV1, RCC_PLLMul_6);
#else
        /* PLLCLK = 8MHz * 9 = 72 MHz */
                                RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
#endif
        /* Enable PLL */
        RCC_PLLCmd(ENABLE);
        while (RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
        RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
        while(RCC_GetSYSCLKSource() != 0x08)
      RCC_OTGFSCLKConfig(RCC_OTGFSCLKSource_PLLVCO_Div3);
    else
        /* If HSE fails to start-up, the application will have wrong clock configuration.
        /* Go to infinite loop */
        while (1)
这个效果和修改官方库一样,分频正确且MCU运行正常,但是比较电流发现,修改官方库的方法比自己写的分频函数电流小了2个ma。
求教有经验的大神指点原因?
shashaa 发表于 2016-1-12 22:14 | 显示全部楼层
这个while循环感觉没什么用啊
