[ZLG-ARM] 哦!不错的**
1821|2
 楼主| qtopia 发表于 2009-7-2 13:18 | 显示全部楼层 |阅读模式
#include&ltlinux/init.h&gt<br />#include&ltlinux/module.h&gt<br />#include&ltlinux/sched.h&gt<br />#include&ltlinux/sem.h&gt<br />MODULE_LICENSE('Dual&nbsp;BSD/GPL');<br />struct&nbsp;completion&nbsp;my_completion1;<br />struct&nbsp;completion&nbsp;my_completion2;//定义了两个完成量<br /><br />int&nbsp;thread_dirver(void&nbsp;*);<br />int&nbsp;thread_saleman(void&nbsp;*);<br />int&nbsp;thread_driver(void&nbsp;*p)//司机线程<br />{<br />&nbsp;&nbsp;&nbsp;&nbsp;printk(KERN_ALERT'DRIVER:I&nbsp;AM&nbsp;WAITING&nbsp;FOR&nbsp;SALEMAN&nbsp;CLOSED&nbsp;THE&nbsp;DOOR\n');<br />&nbsp;&nbsp;&nbsp;&nbsp;wait_for_completion(&my_completion1);//等待完成量completion1<br />&nbsp;&nbsp;&nbsp;&nbsp;printk(KERN_ALERT'DRIVER:OK&nbsp;,&nbsp;LET'S&nbsp;GO!NOW~\n');<br />&nbsp;&nbsp;&nbsp;&nbsp;printk(KERN_ALERT'DRIVER:ARRIVE&nbsp;THE&nbsp;STATION.STOPED&nbsp;CAR!\n');<br />&nbsp;&nbsp;&nbsp;&nbsp;complete(&my_completion2);//唤醒完成量completion2<br />&nbsp;&nbsp;&nbsp;&nbsp;return&nbsp;0;<br />}<br />int&nbsp;thread_saleman(void&nbsp;*p)//售票员线程<br />{<br />&nbsp;&nbsp;&nbsp;&nbsp;printk(KERN_ALERT'SALEMAN:THE&nbsp;DOOR&nbsp;IS&nbsp;CLOSED!\n');<br />&nbsp;&nbsp;&nbsp;&nbsp;complete(&my_completion1);//唤醒完成量completion1<br />&nbsp;&nbsp;&nbsp;&nbsp;printk(KERN_ALERT'SALEMAN:YOU&nbsp;CAN&nbsp;GO&nbsp;NOW!\n');<br />&nbsp;&nbsp;&nbsp;&nbsp;wait_for_completion(&my_completion2);//等待完成量completion2<br />&nbsp;&nbsp;&nbsp;&nbsp;printk(KERN_ALERT'SALEMAN:OK,THE&nbsp;DOOR&nbsp;BE&nbsp;OPENED!\n');<br />&nbsp;&nbsp;&nbsp;&nbsp;return&nbsp;0;<br />}<br />static&nbsp;int&nbsp;hello_init(void)<br />{<br />&nbsp;&nbsp;&nbsp;&nbsp;printk(KERN_ALERT'\nHello&nbsp;everybody~\n');<br />&nbsp;&nbsp;&nbsp;&nbsp;init_completion(&my_completion1);<br />&nbsp;&nbsp;&nbsp;&nbsp;init_completion(&my_completion2);//初始化完成量<br />&nbsp;&nbsp;&nbsp;&nbsp;kernel_thread(thread_driver,NULL,CLONE_KERNEL);<br />&nbsp;&nbsp;&nbsp;&nbsp;kernel_thread(thread_saleman,NULL,CLONE_KERNEL);//创建了两个内核线程,<br />&nbsp;&nbsp;&nbsp;&nbsp;return&nbsp;0;<br />}<br />static&nbsp;void&nbsp;hello_exit(void)<br />{<br />&nbsp;&nbsp;&nbsp;&nbsp;printk(KERN_ALERT'Goodbye&nbsp;everybody~\n');<br />}<br />module_init(hello_init);<br />module_exit(hello_exit);<br />MODULE_AUTHOR('CHEN');<br />MODULE_DESCRIPTION('A&nbsp;simple&nbsp;completion&nbsp;Module');<br /><br /><br />这个例子实现了两个线程间的同步,只有当售票员把门关了后,司机才能开动车,只有当司机停车后,售票员才能开门。所以例子中用了两个完成量来实现这个要求。<br />运行结果:<br />Hello&nbsp;&nbsp;everybody~<br />DRIVER:I&nbsp;AM&nbsp;WAITING&nbsp;FOR&nbsp;SALEMAN&nbsp;CLOSED&nbsp;THE&nbsp;DOOR<br />SALEMAN:THE&nbsp;DOOR&nbsp;IS&nbsp;CLOSED!<br />SALEMAN:YOU&nbsp;CAN&nbsp;GO&nbsp;NOW!<br />DRIVER:OK&nbsp;,&nbsp;LET'S&nbsp;GO!NOW~<br />DRIVER:ARRIVE&nbsp;THE&nbsp;STATION.STOPED&nbsp;CAR!<br />SALEMAN:OK,THE&nbsp;DOOR&nbsp;&nbsp;BE&nbsp;OPENED!<br />Goodbye&nbsp;everybody~<br /><br />点评:完成量是对信号量的一种补充,主要用于多处理器系统上发生的一种微妙竞争。因此,大家可以思考,是否可以用信号量达到司机与售票员的同步?要真正体现完成量的功能,如何设计实例?<br />&nbsp;<br /> &nbsp;&nbsp;<br />
tmake 发表于 2009-7-2 18:29 | 显示全部楼层
哦!不错的**
lpc2410 发表于 2009-7-3 12:58 | 显示全部楼层
路过,学习咯
