STM32 I2C
2451|1
 楼主| pkat 发表于 2009-8-21 15:24 | 显示全部楼层 |阅读模式
我用STM32F103CB跟Mega8做I2C通信,看了资料,STM32的I2C管脚可以支持5V,所以将STM32的SCL和SDA上拉到5V,跟MEGA8通信。MEGA8的程序测试过,应该是没有问题的。
以下是STM32的程序:
#define I2C1_HOST_ADDRESS7    0x01
#define I2C1_SLAVE_ADDRESS7   0x02
#define ClockSpeed            200000
I2C_InitTypeDef  I2C_InitStructure;
void I2C_Configuration(void)
  /* Enable I2C1 ----------------------------------------------------*/
  I2C_Cmd(I2C1, ENABLE);
  /* I2C1 configuration ------------------------------------------------------*/
  I2C_InitStructure.I2C_Mode = I2C_Mode_I2C;
  I2C_InitStructure.I2C_DutyCycle = I2C_DutyCycle_2;
  I2C_InitStructure.I2C_OwnAddress1 = I2C1_HOST_ADDRESS7;
  I2C_InitStructure.I2C_Ack = I2C_Ack_Enable;
  I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
  I2C_InitStructure.I2C_ClockSpeed = ClockSpeed;
  I2C_Init(I2C1, &I2C_InitStructure);
  /* Send I2C1 START condition */
  I2C_GenerateSTART(I2C1, ENABLE);
  /* Test on I2C1 EV5 and clear it */
  while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_MODE_SELECT));
  /* Send I2C2 slave Address for write */
  I2C_Send7bitAddress(I2C1, I2C1_SLAVE_ADDRESS7, I2C_Direction_Transmitter);
  /* Test on I2C1 EV6 and clear it */
  while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));
  /* Send I2C1 data */
  I2C_SendData(I2C1, 0xaa);
  /* Test on I2C1 EV8 and clear it */
  while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED));
  /* Send I2C1 STOP Condition */
  I2C_GenerateSTOP(I2C1, ENABLE);
RCC_APB1PeriphClockCmd( RCC_APB1Periph_I2C1, ENABLE );
/* Configure I2C1 pins: SCL and SDA ----------------------------------------*/
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_6 | GPIO_Pin_7;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_OD;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
主机发送完START信号后,读取SR1和SR2寄存器的值,始终是0,而MEGA8接收不到ACK信号。郁闷了好几天了,高手帮忙解答一下吧~
香水城 发表于 2009-8-21 17:11 | 显示全部楼层
请楼主注明转帖的出处,尊重原创发帖人,谢谢。
