STM32的FSMC地址输出问题
15790|21
liuzhanfeng 发表于 2013-7-30 10:58 | 显示全部楼层
SPC3协议芯片的外围芯片和处理器好多都没有选型:STM 32都是用51单片机。如过你们在PROFIBUS这方面有什么问题也可以找我。我是西门子协议芯片的代理和推广商。QQ:254594509 刘占峰
xu_zhh 发表于 2016-12-26 11:50 | 显示全部楼层
香水城 发表于 2009-8-31 21:14
既然这样,为什么不使用STM32的数据/地址的低8位?使用8位外部数据宽度不是更好?这样还能够保证地址低端的 ...
*   函数名称:
*   函数功能: SJA1000硬件配置初始化
*   参    数:
*   返 回 值:
void SJA1000_HardwareConfiguration(void)        //
    GPIO_InitTypeDef  GPIO_InitStructure;
    FSMC_NORSRAMInitTypeDef  FSMC_NORSRAMInitStructure;
    FSMC_NORSRAMTimingInitTypeDef  readWriteTiming;
    FSMC_NORSRAMTimingInitTypeDef  writeTiming;
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB | RCC_AHB1Periph_GPIOD | RCC_AHB1Periph_GPIOE |  RCC_AHB1Periph_GPIOG, ENABLE);
    RCC_AHB3PeriphClockCmd(RCC_AHB3Periph_FSMC, ENABLE);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;//PE0 RESET
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;//普通输出模式
    GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;//推挽输出
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;//100MHz
    GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;//上拉
    GPIO_Init(GPIOE, &GPIO_InitStructure);//初始化
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;//                              NL  ALE
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;//复用输出
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;//100MHz
    GPIO_Init(GPIOB, &GPIO_InitStructure);//初始化
    // GPIO_InitStructure.GPIO_Pin = (3 << 0) | (3 << 4) | (7 << 8) | (3 << 14); //PD0,1,4,5,8,9,10,14,15 AF OUT
    GPIO_InitStructure.GPIO_Pin = (GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_14 | GPIO_Pin_15);
    GPIO_Init(GPIOD, &GPIO_InitStructure);//初始化
    GPIO_InitStructure.GPIO_Pin = (GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;//
    GPIO_Init(GPIOG, &GPIO_InitStructure);//初始化
    GPIO_PinAFConfig(GPIOD, GPIO_PinSource0, GPIO_AF_FSMC); //PD0,AF12
    GPIO_PinAFConfig(GPIOD, GPIO_PinSource1, GPIO_AF_FSMC); //PD1,AF12
    GPIO_PinAFConfig(GPIOD, GPIO_PinSource4, GPIO_AF_FSMC);
    GPIO_PinAFConfig(GPIOD, GPIO_PinSource5, GPIO_AF_FSMC);
    //GPIO_PinAFConfig(GPIOD, GPIO_PinSource8, GPIO_AF_FSMC);
    //GPIO_PinAFConfig(GPIOD, GPIO_PinSource9, GPIO_AF_FSMC);
    //GPIO_PinAFConfig(GPIOD, GPIO_PinSource10, GPIO_AF_FSMC);
    GPIO_PinAFConfig(GPIOD, GPIO_PinSource14, GPIO_AF_FSMC);
    GPIO_PinAFConfig(GPIOD, GPIO_PinSource15, GPIO_AF_FSMC); //PD15,AF12
    GPIO_PinAFConfig(GPIOE, GPIO_PinSource7, GPIO_AF_FSMC); //PE7,AF12
    GPIO_PinAFConfig(GPIOE, GPIO_PinSource8, GPIO_AF_FSMC);
    GPIO_PinAFConfig(GPIOE, GPIO_PinSource9, GPIO_AF_FSMC);
    GPIO_PinAFConfig(GPIOE, GPIO_PinSource10, GPIO_AF_FSMC);
    //GPIO_PinAFConfig(GPIOE, GPIO_PinSource11, GPIO_AF_FSMC);
    //GPIO_PinAFConfig(GPIOE, GPIO_PinSource12, GPIO_AF_FSMC);
    //GPIO_PinAFConfig(GPIOE, GPIO_PinSource13, GPIO_AF_FSMC);
    //GPIO_PinAFConfig(GPIOE, GPIO_PinSource14, GPIO_AF_FSMC);
    //GPIO_PinAFConfig(GPIOE, GPIO_PinSource15, GPIO_AF_FSMC); //PE15,AF12
    //GPIO_PinAFConfig(GPIOF, GPIO_PinSource12, GPIO_AF_FSMC); //PF12,AF12
    GPIO_PinAFConfig(GPIOG, GPIO_PinSource10, GPIO_AF_FSMC);
    readWriteTiming.FSMC_AddressSetupTime = 0x0f;         //地址建立时间(ADDSET)为16个HCLK 1/168M=6ns*16=96ns
    readWriteTiming.FSMC_AddressHoldTime = 0x00;         //地址保持时间(ADDHLD)模式A未用到
    readWriteTiming.FSMC_DataSetupTime = 0x3c;                        //数据保存时间为60个HCLK        =6*60=360ns
    readWriteTiming.FSMC_BusTurnAroundDuration = 0x00;
    readWriteTiming.FSMC_CLKDivision = 0x00;
    readWriteTiming.FSMC_DataLatency = 0x00;
    readWriteTiming.FSMC_AccessMode = FSMC_AccessMode_B;         //模式A
    writeTiming.FSMC_AddressSetupTime = 0x0f;             //地址建立时间(ADDSET)为16个HCLK 1/168M=6ns*16=96ns
    writeTiming.FSMC_AddressHoldTime = 0x00;         //地址保持时间(A
    writeTiming.FSMC_DataSetupTime = 0x3c;                 //数据保存时间为60个HCLK        =6*60=360ns
    writeTiming.FSMC_BusTurnAroundDuration = 0x00;
    writeTiming.FSMC_CLKDivision = 0x00;
    writeTiming.FSMC_DataLatency = 0x00;
    writeTiming.FSMC_AccessMode = FSMC_AccessMode_B;         //模式A
    FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM3;//
    FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Enable; // 复用数据地址
    FSMC_NORSRAMInitStructure.FSMC_MemoryType = FSMC_MemoryType_NOR; //
    FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_8b;//
    FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode = FSMC_BurstAccessMode_Disable; //
    FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low;
    FSMC_NORSRAMInitStructure.FSMC_AsynchronousWait = FSMC_AsynchronousWait_Disable;
    FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable;
    FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState;
    FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable;        //  存储器写使能
    FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Disable;
    FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Enable; // 读写使用不同的时序
    FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable;
    FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &readWriteTiming; //读写时序
    FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &writeTiming;  //写时序
    FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure);  //初始化FSMC配置
    FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM3, ENABLE);  // 使能BANK1
版主,麻烦帮忙看一下,这段代码为什么NAVD没有任何变化呢?用示波器检测,无任何变化
地址用的是  0X68000000
