紧急,有偿求助93LC46
2790|2
 楼主| lfchh 发表于 2009-10-30 10:38 | 显示全部楼层 |阅读模式
AN, AD, TE, WRITE, rc
以前一直用24C02,后来客户说用93LC46,本来觉得很简单,但折腾了一下午还没完成,郁闷啊。按 data sheet 写了以下程序,可是每次读出数据都为00H。还有D0好象一直低电平,那就一直BUSY吗?请各位大侠帮忙查查原因在哪里?今天内要解决,如何那位大侠愿意帮忙,留个联系方式。
;MCU:SAMSUNG S3C8XXX
;---------define-------
P1_CLK   EQU 00000001B  ;93LC46B clock
P1_CS   EQU 00000010B  ;chip select
P1_DI   EQU 00000100B  ;data input
P0_DO   EQU 01000000B  ;data output
P1_CLK_Clr  EQU 11111110B
P1_CS_Clr  EQU 11111101B
P1_DI_Clr  EQU 11111011B
P0_DO_Clr  EQU 10111111B
sub_init:
NOP
AND P1, #P1_CS_Clr  ;clear CS
NOP
AND P1, #P1_DI_Clr  ;clear DI
NOP
AND P1, #P1_CLK_Clr  ;clear CLK
NOP
RET
sub_start:
NOP
OR P1, #P1_CS   ;set CS
NOP
OR P1, #P1_DI   ;set DI
NOP
OR P1, #P1_CLK   ;set CLK
NOP
NOP
NOP
NOP
NOP
NOP
RET
sub_write_command:    ;input R1
NOP
LD R0, #8
entry0:
RLC     R1
JR NC, entry1
        JR     entry2
entry1:
entry2:
        NOP
        NOP
        NOP
        NOP
        NOP
        NOP
        NOP
        NOP
        DEC R0
        JR NZ, entry0
        NOP
        RET
sub_erase_write_enable:    ;EWEN :10011xxxx
NOP
CALL sub_start   ;1xxxxxxxx
NOP
LD R1, #00110000B  ;x0011xxxx
CALL sub_write_command
        NOP
        NOP
        RET
;--------------------------------------  ;address R2; data R3 R4; R0 shift
sub_write:     ;WRITE 101AAAAAA
NOP
LD R0, #00111111B
AND R0, R2
RCF
ADD R0, #01000000B  ;x01AAAAAA
LD R1, R0
        NOP     ;R3 R4:16 bit data
        LD R1, R3
        LD R1, R4
        NOP
        AND P1, #P1_CS_Clr
        NOP
        RET
sub_write_eeprom_data:
NOP
CALL sub_init
NOP
CALL sub_erase_write_enable
NOP
LD R2, #00H
CLR R3
LD R4, Data1
CALL sub_write
LD R2, #02H
CLR R3
LD R4, Data2
CALL sub_write
LD R2, #04H
CLR R3
LD R4, Data3
CALL sub_write
RET
;-------------------------------------------- ;input address R2; output data R3 R4; R0 shift
sub_read:     ;READ 110AAAAAA
NOP
LD R0, #00111111B
AND R0, R2
RCF
ADD R0, #10000000B  ;x10AAAAAA
LD R1, R0
LD R1, #0
CALL sub_read_data
LD R3, R1
LD R1, #0
CALL sub_read_data
LD R4, R1
NOP
        NOP
RET
sub_read_data:
NOP
LD R0, #8
sread0:
NOP
NOP
NOP
NOP
NOP
NOP
TM P0, #P0_DO   ;test D0
JP Z, sread1
SCF     ;
JP sread2
sread1:
RCF
NOP
NOP
NOP
NOP
sread2:
RLC R1
DEC R0
JP NZ, sread0
NOP
古道热肠 发表于 2009-10-30 12:40 | 显示全部楼层
哈哈,这个都搞不定呀,是思路不对吧.
1.先用编程器写内容,用程序读,不成功时,查硬件连接并换几个芯片试试关系.
2.然后测试写数据,用编程器读是否正确.
贴个参考程序,是用C语言写的,您可以用您自己最熟悉的单片机来测试硬件,再移植到您这三星单片机上.调硬件时要保证软件是好的,调软件时要保证硬件是无故障的.
 楼主| lfchh 发表于 2009-10-30 15:59 | 显示全部楼层
谢谢古道热肠,按上述方法测试了,要写三个16BIT数据,用编程器读出来,只用第一个16BIT数据写进去了。
