请教一个STM32F103芯片CAN的问题。
4887|6
 楼主| xzq1019 发表于 2009-11-2 23:08 | 显示全部楼层 |阅读模式
我所用的开发板为STM32F103V100
上位机调试工具及软件为周立功的USBCAN I
现在单片机软件接收正常,但发送的数据上位机接收不到
好几天解决不了这个问题,请大虾帮我看一下。
int main(void)
#ifdef DEBUG
  debug();
#endif
  FLASH_Unlock();
  CAN_Boot_Init();
  while(1)
CAN_Test();
void CAN_Boot_Init()
  RCC_Configuration(); //时钟的配置,系统时钟为8MHz, CAN时钟为4MHz。
  GPIO_Configuration(); //IO口初始化。
  NVIC_Configuration();  //中断向量的初始化
  CAN_Initiation();   //CAN通信初始化, 波特率250K。
void CAN_Test()
  CanTxMsg TxMessage;
u8 TransmitMailbox;
CanRxMsg RxMessage;
// u8 MsgPendingNum;
u8 i;
while(CAN_MessagePending(CAN_FIFO0)<1);//等待接收到数据
    RxMessage.StdId=0x00;
    RxMessage.ExtId=0x00;
    RxMessage.IDE=0;
    RxMessage.DLC=0;
    RxMessage.FMI=0;  //CAN接收消息通过的过滤器索引
    RxMessage.Data[0]=0x00;
    RxMessage.Data[1]=0x00;
    CAN_Receive(CAN_FIFO0, &RxMessage);
TxMessage.StdId=RxMessage.StdId;
    TxMessage.RTR=CAN_RTR_DATA;
    TxMessage.IDE=RxMessage.IDE; //用来区分标准CAN和扩展CAN
    TxMessage.DLC=RxMessage.DLC;
for(i=0;i<8;i++)
TxMessage.Data[i]=RxMessage.Data[i];
    TransmitMailbox=CAN_Transmit(&TxMessage);
while(CAN_TransmitStatus(TransmitMailbox)!=CANTXOK);//等待CAN发送成功。
void RCC_Configuration(void)
  /* RCC system reset(for debug purpose) */
  RCC_DeInit();
  /* Enable HSE */
  RCC_HSEConfig(RCC_HSE_ON);
  /* Wait till HSE is ready */
  HSEStartUpStatus = RCC_WaitForHSEStartUp();
  if(HSEStartUpStatus == SUCCESS)
    /* HCLK = SYSCLK */
    RCC_HCLKConfig(RCC_SYSCLK_Div1);
    /* PCLK2 = HCLK */
    RCC_PCLK2Config(RCC_HCLK_Div1);
    /* PCLK1 = HCLK/2 */
    RCC_PCLK1Config(RCC_HCLK_Div2);
    /* Enable Prefetch Buffer */
    FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
    /* Select HSE as system clock source */
    RCC_SYSCLKConfig(RCC_SYSCLKSource_HSE);
    /* Wait till HSE is used as system clock source */
    while(RCC_GetSYSCLKSource() != 0x04)
  /* GPIOA and GPIOC clock enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA  | RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOD | RCC_APB2Periph_AFIO, ENABLE);
  /* CAN Periph clock enable */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN, ENABLE);
* Function Name  : GPIO_Configuration
* Description    : Configures the different GPIO ports.
* Input          : None
* Output         : None
* Return         : None
void GPIO_Configuration(void)
  GPIO_PinRemapConfig(GPIO_Remap2_CAN,ENABLE);
  /* Configure PC.06, PC.07, PC.08 and PC.09 as Output push-pull */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
  /* Configure CAN pin: RX */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
  /* Configure CAN pin: TX */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
* Function Name  : NVIC_Configuration
* Description    : Configures the NVIC and Vector Table base address.
* Input          : None
* Output         : None
* Return         : None
void NVIC_Configuration(void)
  NVIC_InitTypeDef NVIC_InitStructure;
#ifdef  VECT_TAB_RAM
  /* Set the Vector Table base location at 0x20000000 */
  NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else  /* VECT_TAB_FLASH  */
  /* Set the Vector Table base location at 0x08000000 */
  NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
  /* enabling interrupt */
  NVIC_InitStructure.NVIC_IRQChannel=USB_LP_CAN_RX0_IRQChannel;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
* Function Name  : CAN_Initiation
* Description    : 初始化CAN控制器,250K波特率,并初始化CAN的滤波器。
* Input          : None
* Output         : None
* Return         : None
void CAN_Initiation(void)
CAN_InitTypeDef        CAN_InitStructure;
  CAN_FilterInitTypeDef  CAN_FilterInitStructure;
/* CAN register init */
  CAN_DeInit();
  CAN_StructInit(&CAN_InitStructure);
   /* CAN cell init */
  // CAN_InitStructure.CAN_TTCM=ENABLE;
   CAN_InitStructure.CAN_TTCM=DISABLE;
  //  CAN_InitStructure.CAN_ABOM=DISABLE;
  // CAN_InitStructure.CAN_ABOM=ENABLE;
  // CAN_InitStructure.CAN_AWUM=ENABLE;
   CAN_InitStructure.CAN_AWUM=DISABLE;
   CAN_InitStructure.CAN_NART=DISABLE;
   CAN_InitStructure.CAN_RFLM=DISABLE;
   CAN_InitStructure.CAN_TXFP=ENABLE;
  // CAN_InitStructure.CAN_TXFP=DISABLE;
   CAN_InitStructure.CAN_Mode=CAN_Mode_Normal;
   CAN_InitStructure.CAN_SJW=CAN_SJW_1tq;
   CAN_InitStructure.CAN_BS1=CAN_BS1_8tq;
   CAN_InitStructure.CAN_BS2=CAN_BS2_7tq;
   CAN_InitStructure.CAN_Prescaler=1;
   CAN_Init(&CAN_InitStructure);
   /* CAN filter init */
   CAN_FilterInitStructure.CAN_FilterNumber=0;
   CAN_FilterInitStructure.CAN_FilterMode=CAN_FilterMode_IdMask;
   CAN_FilterInitStructure.CAN_FilterScale=CAN_FilterScale_32bit;
   CAN_FilterInitStructure.CAN_FilterIdHigh=0x0000;
   CAN_FilterInitStructure.CAN_FilterIdLow=0x0000;
   CAN_FilterInitStructure.CAN_FilterMaskIdHigh=0x0000;
   CAN_FilterInitStructure.CAN_FilterMaskIdLow=0x0000;
   CAN_FilterInitStructure.CAN_FilterFIFOAssignment=0;
   CAN_FilterInitStructure.CAN_FilterActivation=ENABLE;
   CAN_FilterInit(&CAN_FilterInitStructure);
 楼主| xzq1019 发表于 2009-11-2 23:10 | 显示全部楼层
现在的情况是能单片机仿真器设断点能看到接收的数据,且是正确的
但是单片机发给上位机的却是看不见的。
 楼主| xzq1019 发表于 2009-11-2 23:11 | 显示全部楼层
单片机里显示发送成功,寄存器TXOK也变为1
但在上位机端就是看不到数据,奇怪啊
有意思 发表于 2009-11-2 23:13 | 显示全部楼层
用ZLG的东西,直接问他们的技术支持萨,快捷
jiqimao2010 发表于 2010-3-5 16:56 | 显示全部楼层
请问楼主,这里能实现多帧的传输么?
yybj 发表于 2010-3-5 20:59 | 显示全部楼层
换个USBCAN的硬件试下,或者看高低是不是接的对的,或者看波特率设置是不是对的
秋天落叶 发表于 2010-3-5 21:27 | 显示全部楼层
用串口看看,看有没数据,如果确定数据发出去了,应该就是波特率的设置了,也可能是匹配电阻的问题
