- #include<reg52.h>
- #define uchar unsigned char
- sbit DQ=P1^4;
- uchar data temp_data[2]={0x00,0x00};
- uchar data display[5]={0x00,0x00,0x00,0x00,0x00};
- unsigned char code ditab[16] ={0x00,0x01,0x01,0x02,0x03,0x03,0x04,0x04,
- 0x05,0x06,0x06,0x07,0x08,0x08,0x09,0x09} ;
- //共阴数码管
- uchar code table[11] ={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x00};// 0,1,2,3,4,5 ,6,7,8,9,百位或当最高位十位为0时不显示
- uchar code table1[10]={0xbf,0x86,0xdb,0xcf,0xe6,0xed,0xfd,0x87,0xff,0xef};// 0.,1.,2.,3.,4.,5.,6.,7.,8.,9.各位带有小数点的显示
- //以下为水位显示区域
- #define uint unsigned int
- #define ulong unsigned long
- #define _rrca_() CY = ACC & 0x01 //产生RRC A指令
- #define _rlca_() CY = ACC & 0x80 //产生RLC A指令
- sbit bADcs=P1^7;
- sbit bADcl=P1^6;
- sbit bADda=P1^5;
- sbit flag=P1^3;
- //sbit str=P2^7;
- //sbit d=P2^6;
- //sbit clk=P2^5;
- bit choose=0;
- unsigned char data1;
- unsigned char count;
- unsigned char cycle;
- uint ge,xiao1,xiao2;
- unsigned long data2;
- unsigned char code tablewe[]=
- 0xFE,0xFD,0xFB,0xF7,
- 0xEF,0xDF,0xBF,0x7F
- };//自己写的
- void delay_18b20(unsigned int i)
- while(i--);
- //函数区域水位
- void Delayus(uchar i)
- while(--i);
- void ad(void)
- { uchar i;
- //data1=0;
- bADcs = 0;//当ADC0832未工作时其CS输入端应为高电平,此时芯片禁用.
- bADcl=0;
- bADda=1;
- bADcl=1;
- bADcl=0;//i down
- bADda=1;
- bADcl=1;
- bADcl=0; // 2 down
- bADda=0;
- bADcl=1;
- bADcl=0; // 3 down
- bADda=1;
- bADcl=1;
- bADcl=0; // 4 down
- for(i=8;i>0;i--)
- data1<<=1;
- bADcl=0;
- bADcl=1;
- if(bADda==1) data1|=0x01;
- bADda=1;
- bADcs=1;
- void cal()
- data2=((ulong)data1*493)/252.5;
- ge=data2/100;
- xiao1=(data2%100)/10;
- xiao2=data2%10;
- display2()
- P2=tablewe[4]; //P2口低四位位选
- P0=0x00; //P0口数码管段选第五个数码管不用
- delay_18b20(50);
- P2=tablewe[5];
- P0=table1[ge];
- delay_18b20(50);
- P2=tablewe[6];
- P0=table[xiao1];
- delay_18b20(50);
- P2=tablewe[7];
- P0=table[xiao2];
- //以上为水位函数
- //初始化函数
- Init_DS18B20(void)
- unsigned char x=0;
- DQ=1; //DQ复位
- delay_18b20(8); //稍做延时
- DQ=0; //单片机将DQ拉低
- delay_18b20(80); //精确延时 大于 480us
- DQ=1; //拉高总线
- delay_18b20(14);
- x=DQ; //稍做延时后 如果x=0则初始化成功 x=1则初始化失败
- delay_18b20(20);
- ReadOneChar(void)
- unsigned char i=0;
- unsigned char dat=0;
- for(i=8;i>0;i--)
- DQ=0; // 给脉冲信号
- dat>>=1;
- DQ=1; // 给脉冲信号
- if(DQ)
- dat|=0x80 ;
- delay_18b20(4) ;
- return (dat) ;
- WriteOneChar(unsigned char dat)
- for(i=8;i>0;i--)
- DQ=0;
- DQ=dat&0x01;
- delay_18b20(5);
- DQ=1;
- dat>>=1;
- Read_Temperature(void)
- Init_DS18B20() ;
- WriteOneChar(0xCC) ; // 跳过读序号列号的操作
- WriteOneChar(0x44) ; // 启动温度转换
- Init_DS18B20() ;
- WriteOneChar(0xCC) ; //跳过读序号列号的操作
- WriteOneChar(0xBE) ; //读取温度寄存器
- temp_data[0] = ReadOneChar(); //温度低8位
- temp_data[1] = ReadOneChar(); //温度高8位
- Disp_Temperature()
- display[4]=temp_data[0]&0x0f;
- display[0]=ditab[display[4]]; //查表得小数位的值
- display[4]=((temp_data[0]&0xf0)>>4)|((temp_data[1]&0x0f)<<4);
- display[3]=display[4]/100 ;
- display[1]=display[4]%100 ;
- display[2]=display[1]/10;
- display[1]=display[1]%10;
- if(display[3]==0) //高位为0,不显示
- display[3]=10 ;
- if(display[2]==0) //次高位为0,不显示
- display[2]=10 ;
- display1()
- P2=tablewe[0]; //P2口低四位位选
- P0=table[display[3]]; //P0口数码管段选
- delay_18b20(50);
- P2=tablewe[1];
- P0=table[display[2]];
- delay_18b20(50);
- P2=tablewe[2];
- P0=table1[display[1]];
- delay_18b20(50);
- P2=tablewe[3];
- P0=table[display[0]];
- void main()
- while(1)
- { Read_Temperature();
- Disp_Temperature();
- display1();
- ad();
- cal();
- display2();
